CCRC1
MD, USA Status: offline
OK the transmitter is narrow band so its OK to use. Give me a few minutes I want to check a few things on the rest of the parts. OK I am back. The Futaba servos are at least 20 years old or better. The transmitter is OK if it has the gold sticker, that indicates it has been updated to narrow band specs. Does the receiver have a similar gold sticker? If it does not you may have to do some checking. You did not indicate what channel this system is on. If the RX is still a wide band RX, it will receive and fuction with the TX. The problem is that it also will receive signals from the channels next to it as well. (For example, if the RX is a wide band RX on channel 50, it will receive signals on 49, 50, 51 all at the same time.) The easiest way to test this is get someone with a transmitter on the channel next to the one your system is on and test the RX to see if it will receive the signal. Dude, To be honest with you, there aint no way I would have paid $85.00 for that stuff. I sold a bunch of those old two digit "G" series Futaba servos that were brand new and never used at my last swap meet for $2 a piece!! In the future, before you buy anything like that, write down the specs and post it here for feedback. All of the folks here have been giving you very good, honest advice. For about 40 bucks more you could have purchased a brand new Futaba Skysport system complete with 4 servos. I am willing to bet that you will spend an extra 30 bucks just to update that old system with fresh NiCads. At least you know the TX is legal to use. The RX, if it is wide band, is not illegal to use but you are far more likely to get interferance. If you fly at a club, you would have to pull several frequency pins when you fly just to make sure someone doesn't turn on with the channel(s) next to yours. If the RX has a gold sticker on it you should be OK and won't have to worry about anything. Please, before you give any more of your hard earned dough to your local crook, uh,........ I mean hobby shop, just ask for some feedback here first.
< Message edited by CCRC1 -- 9/13/2005 7:28:32 AM >
