Niteowl7667
I've had my FF for a while now, and I've been through a lot with it. Before this, I had the Firebird Commander, which is MUCH easier to fly and seemingly more refined. That one got lost when I let someone else fly it, never to be seen again The next step up was the 3 channel Freedom. Out of the box, I noticed that it was much faster than the commander. Also, it didn't seem to have the gliding capability that the commander did. When I would let go of the throttle, it would kinda just drop. My first flight I didn't use the elevator much (didn't know how to really) and I managed not to crash it. The second flight though, I must have crashed it 10 times in one outing. I damaged it pretty decently, but nothing needed replacement. I think I finally figured out how to fly this thing when I realized that it flies around happily at about half throttle. It's been a while since I got it, and I'm finally mastering it. I haven't crashed it in several outings, and I've been learning to loop her too. The problem with the Freedom is that it's kind of hard to get it trimmed correctly. Once you have it trimmed though, it's okay. Also, when making turns, you NEED to give it some up elevator too, or else it loses altitude and might crash. I've found that when landing, it is hard to bring it around slowly on final approach, because it tends to lose altitude so fast at slow speeds. My solution has been to take it around, and then cut the throttle when it is still kind of high. At this point, use the elevator to drop it way down, and at the last second before it hits the ground, flare it up with the elevator. I have had success with this method. Overall, I love this plane. I didn't at first, and was thinking I wouldl probably lose or destroy it. However, neither has happened and I've learned to fly 3 channels on it. It's served it's purpose nicely. It just takes time to master this plane, but it's worth it once you have it down.
