Cox Fuel
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Cox Fuel
Page: [1]
Login
Cox Fuel - 8/21/2005 4:10:17 PM
CRASHANBURN1
Status: offline
I found a can of real old fuel. It is a Pint can an it says it is Cox Thimble-Drone Glow-Fuel. Have I struck it rich or what.
       Post #: 1
RE: Cox Fuel - 8/21/2005 7:14:28 PM
RaceCity
Status: offline
Don't call the boss and quit your job just yet. What you have is little more than an old can of fuel. Cox pumped these out by the zillions.
The contents are probably of questionable usefulness, but the can itself...if in really good condition (no dents, rust, scratches) might be worth 5 bucks to a collector in a generous mood.
There ya go....
'Race
< Message edited by RaceCity -- 8/21/2005 7:15:54 PM >
_____________________________
AMA 63990
(in reply to CRASHANBURN1)
       Post #: 2
RE: Cox Fuel - 8/23/2005 1:34:54 PM
gcb
Status: offline
CRASHANBURN1,
Cox fuel has 15% nitro and ~20% castor oil. Should work well in your 1/2A engines. Cox also makes "Cox Racing Fuel" which, I think, has 25% nitro. Cox fuels use (or used) 100% castor lube because it is good for the ball socket at the upper end of the connecting rod.
Use it with much enjoyment. Put the empty can on "the bay".
Speaking of old cans, I have some Topsol diesel fuel from "way back when". I may add some ether and use it up also.
George
(in reply to RaceCity)
       Post #: 3
RE: Cox Fuel - 9/22/2005 5:11:06 PM
N1EDM
Status: offline
I found a can of Cox fuel that I had stashed away about 20 years ago and forgotten about.
The can was unopened, so the fuel worked just fine for me. I'll bet a little of the nitro might have evaporated through the can sides, but overall, it was OK... I don't think you'll hurt anything if you try it out.
Bob
< Message edited by N1EDM -- 9/22/2005 5:19:49 PM >
An expert is someone who has been doing it for 15 minutes longer than you.
(in reply to gcb)
       Post #: 4
RE: Cox Fuel - 9/23/2005 4:05:35 AM
wizard4sure
Status: offline
<I'll bet a little of the nitro might have evaporated through the can sides,
Not possible....so don't worry about that.
(in reply to N1EDM)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
