E-Pattern RX battery
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> E-Pattern RX battery
Page: [1]
Login
E-Pattern RX battery - 8/22/2005 7:42:29 PM
Neo02
Status: offline
Hello to all,
I just wanted to say that since I went the electric route I consistently put between 70 to 90 mAh back into my RX battery. That is with 4 digital servos (2x Hitec 5625, 2x Hitec 5245) on my Eclipse. I switched from a 1500 mAh (about 60g) lipo battery to a smaller 700 mAh (about 30g), and I'm sure it will last more than enough time. I purchased a Graupner Lipo Charger 4 and I'm very happy with it. I could go lower, say, to a 450 mAh, but does it bring any benefit?
What RX battery size do you fly?
Regards
-Fabrizio
_____________________________
Fabrizio Albonico
SUI 36291
       Post #: 1
RE: E-Pattern RX battery - 8/22/2005 11:04:58 PM
BJM
Status: offline
I am using the 730 pack. My Impact meets the weigh limit and the Hacker has the power. I don't plan to go lower.
Billy
(in reply to Neo02)
       Post #: 2
RE: E-Pattern RX battery - 8/22/2005 11:46:30 PM
toddblose
Status: offline
I am using a Thunder Power 860 7.4V. I can get 8 to 10 flights no problem
http://toddblose.homestead.com
Team Futaba,FlightPower,Hacker,CA Models,Hobbico, PowerMaster,HydeMounts,ModelGlasses
(in reply to BJM)
       Post #: 3
RE: E-Pattern RX battery - 8/23/2005 1:13:43 AM
rm
Status: offline
I run a ubec, don't have to worry about the extra charging.
(in reply to toddblose)
       Post #: 4
RE: E-Pattern RX battery - 8/23/2005 9:07:30 AM
Magne
Status: offline
I use 700 mAh E-tec, Jaccio 5,7V regulator.
I typically put back 35-45 mAh per flight.
5 digital JR servos.
It is probably possible to use an even smaller pack (e.g. 450 mAh) but I think that the weight reduction would be insignificant. (about 12 grams.)
Magne
(in reply to rm)
       Post #: 5
RE: E-Pattern RX battery - 8/24/2005 11:04:27 PM
Neo02
Status: offline
Uh.. forgot to mention that I use a 5.5V Voltage regulator from Alewings.it (Alessandro Torri).
Will stick to the 700 mAh based on your experience (and thought I was flying a 1500 5-cell NiCd on my older design Topline, weight ~ 100g... How things change...
Thanks for the feedback, very appreciated!
-Fabrizio
Fabrizio Albonico
SUI 36291
(in reply to Magne)
       Post #: 6
RE: E-Pattern RX battery - 9/21/2005 5:16:08 PM
kepople
Status: offline
I use a regulator and a 2cell tp 2100 gen Ii lipo
kirby
(in reply to Neo02)
       Post #: 7
RE: E-Pattern RX battery - 9/22/2005 8:38:06 AM
Malcolm H
Status: offline
Flightpower 2S 1050 mAHr with Duralite 5.5v regulator, 5 JR digitals and 70-90 mAHr/flight. Magne you aren't moving the sticks enough! When are you going to come and fly electric F3A with Steve Burgess and me?
Malcolm
(in reply to kepople)
       Post #: 8
RE: E-Pattern RX battery - 9/27/2005 2:51:01 PM
Magne
Status: offline
Malcolm.
I have found that the less I stir the sticks, the better the plane goes.
Magne
(in reply to Malcolm H)
       Post #: 9
RE: E-Pattern RX battery - 9/27/2005 3:40:21 PM
Malcolm H
Status: offline
Can't argue with that!
Malcolm
(in reply to Magne)
       Post #: 10
RE: E-Pattern RX battery - 9/28/2005 12:11:23 AM
rcprecision
Status: offline
Todd,
Which regulator are you using?
Glen Watson
http://glenwatson.blogspot.com/
       Post #: 11
RE: E-Pattern RX battery - 9/29/2005 3:19:09 PM
JAS
Status: online
All 3 of my Impacts are 730 2-cell Thunder Powers with Shulman Aviation 6V Regulators. After 6 flights I've used about 300 mAh.
Uncle JAS
Shulman Aviation
(in reply to rcprecision)
       Post #: 12
RE: E-Pattern RX battery - 9/29/2005 3:24:00 PM
darkvader
Status: offline
I use :
Kokam 2S1P, 640mAh
Jaccio 5.1V regulator
5 Digital Servos ( 3JR + 2 Hitec )
250 mAh / 4 P05 flights, in average
Best Regards
DV
       Post #: 13
RE: E-Pattern RX battery - 9/30/2005 2:03:20 AM
toddblose
Status: offline
Glen,
I am running the DURALITE 5.6 regulator
(in reply to darkvader)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
