Aileron Throws CompARF Extra 2,6m
Tower Hobbies
Logged in as Guest
  Printable Version
F-16C 1/6 LARGE JetLegend (Now available in THUNDERBIRD ..(We offer Building & C - ARF
Seller:  FlyingboyD
Details:   $2,960.00   |  8/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> Aileron Throws CompARF Extra 2,6m
Page: [1]
Login
Aileron Throws CompARF Extra 2,6m - 8/23/2005 9:31:58 PM
Zeb_Macahan
Status: offline
I have a new Composite-ARF Extra 2,6 m and I think the 10% dif. between up- and downthrows ( on the aileron) that the instruction says can´t be right.
My Extra is not rolling nice when I use these throws. Has anyone got it dead on right???
       Post #: 1
RE: Aileron Throws CompARF Extra 2,6m - 8/23/2005 10:02:06 PM
John Murdoch
Status: offline
Make sure you're using 10% NEGATIVE differential... That may be your problem.. You want the "down" side to go down 10% more than the "up" side.
< Message edited by John Murdoch -- 8/23/2005 10:04:36 PM >
_____________________________
~Growing Old Is Mandatory~
~Growing Up Is Optional~
(in reply to Zeb_Macahan)
       Post #: 2
RE: Aileron Throws CompARF Extra 2,6m - 8/23/2005 10:13:32 PM
Zeb_Macahan
Status: offline
Thanx John. Yes I have more down throw than up, but the vertical rolls look like crap. Of course I can try different amount of % but I use Hitec programmable servos and I already have max ATV on my radio so I have to reprogram my servos. I would be extremely happy if anyone had a number that seems to work so I only would have to programme she servos one more time. YES I´m LAZY
(in reply to John Murdoch)
       Post #: 3
RE: Aileron Throws CompARF Extra 2,6m - 8/23/2005 10:16:46 PM
John Murdoch
Status: offline
Zeb.. I had mine set at 10%.. Then I tried 11% and 12%. I went back to 10% for the most axial roll and it worked best there. Are you setting your end points on the high or low rate?
       Post #: 4
RE: Aileron Throws CompARF Extra 2,6m - 8/23/2005 10:23:34 PM
Zeb_Macahan
Status: offline
I have the 10% at maximum throws. I have not measured the % at lowrate , but I suppose that I have 10% there also.?.?.
       Post #: 5
RE: Aileron Throws CompARF Extra 2,6m - 8/23/2005 10:30:50 PM
John Murdoch
Status: offline
Zeb.. I'm not sure what to tell you. By the way you've described your setup, it should be correct and negative 10% is the magic number. Or at least is was with the 2.6's I've flown.
       Post #: 6
RE: Aileron Throws CompARF Extra 2,6m - 8/23/2005 10:35:45 PM
Zeb_Macahan
Status: offline
John, if you are still there, did you ever try with same down and up throw? Or at least a smaller difference than 10%?
       Post #: 7
RE: Aileron Throws CompARF Extra 2,6m - 8/23/2005 10:37:35 PM
John Murdoch
Status: offline
Nope.. Started with 10% and then adjusted just for the fun of it to see what it would do. Rolls were ALWAYS better at the negative 10% setting.
       Post #: 8
RE: Aileron Throws CompARF Extra 2,6m - 8/23/2005 10:43:35 PM
Zeb_Macahan
Status: offline
Thanks for your help John. I have to check again that I have my 10%. That must work if you say so. Thanks again!
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.500RCU1
