Airfoil for Funtana    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Airfoil for Funtana
Page: [1]
Login
Airfoil for Funtana - 8/24/2005 11:04 AM
Fikus
Score: 100
Last Login: 11/14/2005
Status: offline
Before my question please sorry for my English
I building a 3D airplane Funtana from drawing of Exclusive Modellbau. But i have a problem with wing Airfolils. Which airfoil is used at the end of the Wing? Have you got somebody the original aurfoils from Sebastiano Silvestri? Thank you for all answers. Filip - Czech republic
Hide Signatures
       Post #: 1
RE: Airfoil for Funtana - 8/24/2005 9:10 PM
Tall Paul
Score: 134
Last Login: 4/23/2013
Status: offline
If memory serves, the tip airfoil is the same thickness as the root airfoil, just shorter in chord.
In a CAD or drawing program, take the root airfoil, and keeping the same thickness inthe y-dimension, change the chord by the percentage difference of the x-dimension between root and tip.
Click to see fullsize image.
Click for fullsize
< Message edited by Tall Paul -- 8/24/2005 9:22 PM >
_____________________________
Sparky Paul
http://www.angelfire.com/indie/aerostuff
Hide Signatures
(in reply to Fikus)
       Post #: 2
RE: Airfoil for Funtana - 8/25/2005 2:39 PM
Fikus
Score: 100
Status: offline
So that I can use for example NACA 0012 fot the root and NACA 0020 for the top of the wing. I´ve got a built plan prom Exclusive modelbau for funtana 2x2meters and the NACA 64-012A 14% is used at the root of wing. But the airfoil, which is used at the end is not described. I have a lot of photos and the most similar airfoil is EPLLER 476. Can I use a combination of these two Airfoils? Thanks.
Hide Signatures
(in reply to Tall Paul)
       Post #: 3
RE: Airfoil for Funtana - 9/27/2005 6:15 PM
Stoeptegel
Score: 100
Last Login: 5/10/2013
Status: offline
Hi,
Do you have a S or a Pro? In case of a Pro, the root airfoil has not the same thickness as the tip. The tip is 50 mm thick and the root rib is 72,5 mm. This delta thickness, don't know the english word for it, but this difference of thickness is distributed evenly over the ribs from root to tip. In case of a S, I don't know. I only have a Pro.
I just finished mine. Just have to wait for the right weather...
Goodluck with it!
Christiaan Vis
< Message edited by Chris flying Vis -- 9/27/2005 6:18 PM >
Hide Signatures
(in reply to Fikus)
       Post #: 4
RE: Airfoil for Funtana - 10/2/2005 10:49 AM
PropWrench
Score: 100
Last Login: 2/4/2013
Status: offline
Ficus,
Here is a PDF of a wing layout for a scaled Funtana Pro. I also a 2 Meter Exclusiv Modellbau and I reverse engineered it for a .50 size engine. This file has the exact profile used on the 2M bird. Hope this helps.
Click to see the file in new window.Attachment.pdf
Hide Signatures
(in reply to Stoeptegel)
       Post #: 5
RE: Airfoil for Funtana - 11/1/2005 4:05 PM
Fikus
Score: 100
Status: offline
Hi,
Thank you for your PDF airfoil. I´m very happy, because this airfoils are the same like my airfoils.
So one more thank you.
Filip, Czech Republic
Hide Signatures
(in reply to PropWrench)
       Post #: 6
RE: Airfoil for Funtana - 1/7/2006 12:24 AM
Jerry C
Score: 100
Last Login: 9/22/2008
Status: offline
Does anyone have a file for the wing ribs on a Funtana 140 Pro? I would like to have the ribs laser cut for my scratch build.
Jerry
Hide Signatures
(in reply to Fikus)
       Post #: 7
RE: Airfoil for Funtana - 2/1/2006 7:53 PM
highfly3D
Score: 100
Status: offline
Hi
Dose any one has a plan for 40 -50 size katana, please i need help i searched every were i didnt find one, i want to scratch build it. harrysupley@yahoo.com
Regards
Harry Supley.
I will say it only once Yak 54 the best aerobatic plane ever made.
Hide Signatures
(in reply to Jerry C)
       Post #: 8
RE: Airfoil for Funtana - 3/21/2006 9:35 PM
GmasterB
Score: 100
Last Login: 3/23/2006
Status: offline
HI All!
@PropWench: Is it possible to get yout 3D drawings of the Funtana?
I'd like to downscale the Funtana to a S90 one (1,4 meters wingspan)
Best regards, Frank
Hide Signatures
(in reply to highfly3D)
       Post #: 9
RE: Airfoil for Funtana - 3/22/2006 6:29 AM
highfly3D
Score: 100
Status: offline
hello
I am working on a katana 40 size plans wingspan about 55" it will be be ready soon, the ailerons are 1/4" built up like funfly plane but rest all is scale like the actual Katana.
Highfly3D.
Hide Signatures
(in reply to GmasterB)
       Post #: 10
RE: Airfoil for Funtana - 4/2/2006 7:06 AM
Av8er Tim
Score: 100
Last Login: 11/20/2012
Status: offline
PropWrench - What airfoil is used for the Funtana Pro in the PDF? Also, do you have the full plans? I'd like to do a big electric Funtana.
Tim
quote:
ORIGINAL: PropWrench
Ficus,
So many planes... So little time
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.703RCU1
