Ed Cregger
GA, USA Status: offline
quote:
ORIGINAL: vasek Jeff, I have a new ST 60 Blue head (just broke it in) and was wondering if it would be any good for speed plane application... lets say a Patriot (40). The blue head is fairly small & light, it would make a nice fit! How much RPM can I squeeze out of it? what prop & tunepipe? ----------- I obtained a very used G60 Bluehead from a friend in the early nineties. It is ringed, but not a Dykes ring. While it does not produce power in the same range as many of today's hot .61's, it only weighs 20 ozs. without muffler and it really wails when swinging an 11x6 prop. Yes, I know. That is a small prop for a G60, but you should see the attention it gets when blowing notes through an open front Mac's muffler and when mounted on my own design forty sized model (Hail Razor). One fellow walked up to me and said, "Ed, that model doesn't takeoff from the ground. It explodes!". Sometimes we old farts enjoy messing with folks' heads a bit by psyching them out with sight and sound. There was a construction crew working on a very nearby school one day. They had a big diesel driven air compressor and other noisey equipment going full time. After the first flight of the day, every time I would begin fueling up the Hail Razor, you would hear all of the equipment drop back to idle as the construction crew waited to view the coming flight. It was an early Fall day and the air was crisp without being too cold. Obviously, school was out that day. Engines love days like this and it also makes sound travel crisply to boot. It makes you feel good when you perform a flight of high speed aerobatics and when you throttle back to land, you get a round of applause from the construction crew. That was a bigger high than placing or winning in any pattern contest - not that I had all that many wins to brag about. My health is such now that those days are relegated to the past. But at least I had a few days like that! Thank you, Lord. <G>
_____________________________
Artisan "Flying models since the Fifties - I'll get the hang of this yet!!!"
