RE: favorite engine from the day
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> RE: favorite engine from the day
Page: <<   < prev  1 2 3 [4]
Login
RE: favorite engine from the day - 6/19/2008 6:52:40 PM
turbo.gst
Status: offline
martinoto,
If you don't mind building from plans, MAN has the Arrow( FSP06802). It would sure compliment that VF.
turbo
(in reply to martinoto)
       Post #: 76
RE: favorite engine from the day - 6/19/2008 6:58:32 PM
martinoto
Status: offline
Turbo,
I don't mind building from plans. But in the case of the Arrow, as far as I remember, the wing of the MAN's plans are foam. I just can't do a right and light foam wing, and I am quite good at wood wings..
Thats why I was looking for an MK Kit. If I could get an all-wood plan, I would go for it.
_____________________________
"Give me balsa and a cutter, and I will cut a little too much"
(in reply to turbo.gst)
       Post #: 77
RE: favorite engine from the day - 6/19/2008 7:23:33 PM
turbo.gst
Status: offline
Lets cut a foam wing out and then slice it to make the ribs..... I'll do it if I had the plans.....
turbo
       Post #: 78
RE: favorite engine from the day - 6/19/2008 7:42:40 PM
martinoto
Status: offline
I never thought on that one... I guess it could be done...
I could also figure the aproximate rib foil and then print the ribs with Profili...
I am going to take a look to the plans again...
Thanks and regards
       Post #: 79
RE: favorite engine from the day - 6/19/2008 8:13:35 PM
rainedave
Status: offline
I can generate a set of ribs in Profili using the root and tip templates, make a cutfile in cad and you can have sets of laser-cut ribs made. I've done this several times over the last year or so. It's quick, easy and relatively inexpensive.
Someone just needs to email me the templates (and the wing's exact dimensions). A digital copy of the plans would be best.
You need to put that VF to use.
David
< Message edited by rainedave -- 6/19/2008 8:15:45 PM >
       Post #: 80
RE: favorite engine from the day - 6/20/2008 12:00:01 AM
martinoto
Status: offline
David, thanks, I will.
I have Profili too. I will buy the plans fron MAN and let you , know (it will take few weeks to get here)
Definitely, it will be great to (finally) see the VF in the nose of an Arrow (don't ask for pictures, I am not as good as you building from plans )
Thanks and regards
(in reply to rainedave)
       Post #: 81
RE: favorite engine from the day - 6/20/2008 4:05:36 AM
dhal22
Status: offline
i have a vf in excellent condition, i've heard great things about it, but i've never ran it. someday.
david
       Post #: 82
RE: favorite engine from the day - 6/21/2008 9:20:31 PM
RCDENT
Status: offline
Great thread guys! Thanks for posting pics of some of the old engines. I started with the old Enya .60 II and was using YS .60's when I took a 10 year vacation from R/C. To a great extent, I think the available engines determined the development of pattern planes over the years 1965-90. I'm going to post some pics of older pattern radios that I think might be interesting. The Enya 60 II and III were fantastic engines. They always started on one flip, idled smooth as silk. As far as I know, parts are still available for them! I spoke about a year ago with a gentleman at MRC, and suggested they think about making a "Classic" or "Commemorative" run of these engines. He replied "I don't why Enya doesn't. I could sell every one they could make!" Phil Kraft used these in all of his famous designs up until about 1970 when the Webra Blackhead came out.
Gear up, and "on the pipe".
(in reply to ramcfarland)
       Post #: 83
RE: favorite engine from the day - 6/21/2008 9:33:30 PM
Ed Cregger
Status: offline
quote:
ORIGINAL: dhal22
david
The OS .61VF is a good engine. It was one of the first rear exhaust engines made for the average modeler, if that makes any sense. Mine ran acceptably well and was very reliable and long lasting.
I bought a used one not long ago. This one needs a good soaking in some warm antifreeze, but will look like new when cleaned and fitted with new bearings, etc. The piston/liner seem to be in very good condition. I do have a standby piston/liner for the engine, but am hoping to get some more use out of the original it came with.
Please keep in mind that while these engines throttle well for their intended use, they are not the type of engine one would use for 3D flying. In the "olden days", most flying was done at wide open throttle and as long as the engine remained running and did not stumble horribly while accelerating from idle, we were happy. Fuel draw with the stock carb was marginal. Most folks used a pump of one sort or another with these engines. Ditto the .61 FSR series, which was fitted with the same carb as the VF.
Ed Cregger
Artisan
"Flying models since the Fifties - I'll get the hang of this yet!!!"
(in reply to dhal22)
       Post #: 84
RE: favorite engine from the day - 6/21/2008 9:42:59 PM
Ed Cregger
Status: offline
quote:
ORIGINAL: dhal22
david
Ed Cregger
Artisan
       Post #: 85
Jump to:
