receiver position
Tower Hobbies
Logged in as Guest
  Printable Version
Spektrum DX7 - FULL SYSTEM!
Seller:  Erick Royer
Details:   $325.00   |  7/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> receiver position
Page: [1]
Login
receiver position - 1/9/2002 8:46:51 PM
ogarrid
Status: offline
I have had several problems with radio installation in my c.g. freedom 20 trainer.
After changing the whole radio equipment( emitter and receiver) I would like to correct as well something I think could be incorrect.
Layout is:
Battery is just behind firewall and under the tank, (foam wrapped)
Behind this is located the receiver and the next is servo trail, so receiver antenna pass ( about 3" ) over or under the servos.
Is this ok?
       Post #: 1
receiver position - 1/9/2002 9:20:26 PM
mglavin
Status: offline
This should work fine, I have seen this done numerous times. However I would try and route the antenna wire away from all other wires, pushrods, servos, battery and switches. This is preferred method.
Do a range check with and without the engine running to verify range.
_____________________________
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
(in reply to ogarrid)
       Post #: 2
Wiring ? - 1/10/2002 10:49:42 AM
starzak
Status: offline
What Michael says is true. Just try and keep the receiver and it's antenna, seperated from all power, and servo wiring.
Your criteria should be a good range check. About 50 paces with your Tx antenna collapsed.
Jim Lynch - Forum Moderator
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
