RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
Users viewing this topic: JohnB96041, dynomanca, FNQFLYER
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  815 816 [817] 818 819 820 821 822 823 824   next >   >>
Login
RE: Welcome to Club SAITO ! - 8/25/2011 5:19 AM
FNQFLYER
Score: 110
Last Login: 6/18/2013
Status: online
As I said run it as rich as it will stand on full throttle.  This usually results in a Saito 65 for example running at around 4000rpm. At this RPM with a very rich mixture the engine doesn't get hot at all.  With the throttle wide open you then increase the rpm by leaning it.  This method gives max cooling, max lubrication for the first run.  Then you start with the ups and downs etc with the second and successive runs
This works for us, BTB it is a modification (slightly) to the instructions given in our data.
I am puzzled by the difference in operating instructions.  Ours come from Saito and the US ones appear to be generated by Horizon Hobbies.  This opens another can of worms when one starts playing with the gas engines but that is another matter totally on which I cannot yet comment based on experience that is
_____________________________
Club Saito member 710
Hide Signatures
(in reply to Hobbsy)
       Post #: 20401
RE: Welcome to Club SAITO ! - 8/25/2011 12:52 PM
Hobbsy
Score: 650
Last Login: 6/19/2013
Status: online
There is nothing in a Saitos construction that can benefit from heat cycling, also its much better to have the engine components close to their normal operating temp to seat in to each other at normal tolerances.
< Message edited by Hobbsy -- 8/25/2011 1:49 PM >
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to FNQFLYER)
       Post #: 20402
RE: Welcome to Club SAITO ! - 8/25/2011 1:30 PM
Old Fart
Score: 158
Status: offline
Hello guys and many many thanks for your comments,they were good and easier to understand
Watch out for the ground eh?
Hide Signatures
       Post #: 20403
RE: Welcome to Club SAITO ! - 8/25/2011 1:50 PM
Hobbsy
Score: 650
Status: online
OF, are you being just a might facitious?
Hide Signatures
(in reply to Old Fart)
       Post #: 20404
RE: Welcome to Club SAITO ! - 8/25/2011 4:06 PM
blw
Score: 655
Status: offline
The only hard rule I go by is to keep the engine at, or below 4k on the first tank. It is already wearing, changing balances, tolerances, etc and getting everything mated together.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
       Post #: 20405
RE: Welcome to Club SAITO ! - 8/25/2011 7:59 PM
Daniel-EL
Score: 118
Status: online
The 0.015 decompression shims for the Saito 150 were once offered by C&H Electronics, but they are no longer in business. Anybody have a suggestion where they might now be found now and purchased?
I don''t necessarily believe everything I say
...Marshall McLuhan...
Hide Signatures
(in reply to blw)
       Post #: 20406
RE: Welcome to Club SAITO ! - 8/25/2011 9:02 PM
w8ye
Score: 318
Status: offline
It is not a critical area.
You can make a gasket from gasket material from the auto parts.
Trim out the i.d. mount the cylinder and then trim off the outside with a #11 Exacto blade.
< Message edited by w8ye -- 8/25/2011 11:23 PM >
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to Daniel-EL)
       Post #: 20407
RE: Welcome to Club SAITO ! - 8/25/2011 10:49 PM
Old Fart
Score: 158
Status: offline
ME?
Hide Signatures
       Post #: 20408
RE: Welcome to Club SAITO ! - 8/26/2011 7:02 AM
JariV
Score: 110
Last Login: 4/25/2013
Status: offline
Hello,
if someone is having trouble with Saito radial engines dropping a cylinder during flight then there is a cure for that. I had this problem with my FA90R3 radial dropping a cylinder during flight and with throttle positions from half throttle to full throttle. I am using Keleo exhaust ring. The reason is that the engine is not getting enough fuel in high rpms. I added a Perry oscillating fuel pump and adjusted the fuel pressure and the trouble is completely gone. Works very well and full power available all the time. Just to let you guys know if someone has the same problem. First I thought it was glowplug related problem but I tested that extensively with many different plug sets.
Hide Signatures
       Post #: 20409
RE: Welcome to Club SAITO ! - 8/26/2011 1:36 PM
clytle374
Score: 100
Last Login: 6/15/2013
Status: offline
I'm subscribed to this thread, but quit getting emails.
I removed the previous exhaust system, and just used the rcspecialties 90 and the 15 deg manifold. I gained a another 300 rpm and can now lean it out to 9000rpm.
I think the exhaust with a flair and a nut like and OS would work great with my cowl, any of the OS ones fit the 100? I'd still need a pressure tap. Here's a picture of the 90 with the hole drilled. Any ideas on how to test if I'm getting any pressure? I wanted to tap the flat side of the 90, but it was too thin to hold imo.
Cory
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to JariV)
       Post #: 20410
RE: Welcome to Club SAITO ! - 8/26/2011 2:01 PM
w8ye
Score: 318
Status: offline
Nothing "OS" will fit anything "Saito 100"
Original AMA #31261
Hide Signatures
(in reply to clytle374)
       Post #: 20411
RE: Welcome to Club SAITO ! - 8/26/2011 3:08 PM
hsukaria
Score: 185
Status: offline
I am not sure this is the correct forum to ask this question, but it has to do with my Saito 180 nitro engine.
I acquired it used but have not started it yet. I plan on starting it this weekend (tomorrow). I heard from here that I should add some light oil into the pushrod tubes before starting it. In the past, I used Automatic Transmission Fluid (ATF) to store other engines. Will ATF work ok to pre-lube a Saito before starting from storage? Is there a maximum limit to how much oil there should be in the engine before cranking it with a starter to avoid hydrolock?
Thanks.
Content, but not Complacent.
Saito Club Member #765
Hide Signatures
(in reply to w8ye)
       Post #: 20412
RE: Welcome to Club SAITO ! - 8/26/2011 3:42 PM
w8ye
Score: 318
Status: offline
ATF will be fine
Check the engine for hydro lock by turning it over by hand before applying the starter.
It is going to take a big starter
Original AMA #31261
Hide Signatures
(in reply to hsukaria)
       Post #: 20413
RE: Welcome to Club SAITO ! - 8/26/2011 4:26 PM
blw
Score: 655
Status: offline
We have new members:
770 frets24
771 Daniel-el
772 boates25
It's good to have these guys around. Anyone else???
Coach Pat Dye
Hide Signatures
(in reply to w8ye)
       Post #: 20414
RE: Welcome to Club SAITO ! - 8/26/2011 4:53 PM
KenD
Score: 100
Status: offline
Yesssss me KenD
KenD
Club Saito Member #773
AMA 64943
IMAA 23743
Hide Signatures
(in reply to blw)
       Post #: 20415
RE: Welcome to Club SAITO ! - 8/26/2011 5:05 PM
hsukaria
Score: 185
Status: offline
quote:
ORIGINAL: w8ye
ATF will be fine
Yes, I read with dread about the starters some of you guys are using. My standard starter with a big 12V lead acid gel battery turns the 180 over slowly. We'll see.
Hide Signatures
(in reply to w8ye)
       Post #: 20416
RE: Welcome to Club SAITO ! - 8/26/2011 7:25 PM
clytle374
Score: 100
Status: offline
quote:
ORIGINAL: blw
770 frets24
771 Daniel-el
772 boates25
I'd like in, if the dues are not too high
Cory
Hide Signatures
(in reply to blw)
       Post #: 20417
RE: Welcome to Club SAITO ! - 8/27/2011 1:26 AM
Hobbsy
Score: 650
Status: online
Jim, I pulled the backplate on my older .80 today and after 22 years it is still shiny and new looking inside. I partly learned to fly with this engine in about 1990. It has rarely turned anything but a Scimitar 13x6 and was run on Fox 15% fuel with 20% castor for its first two seasons./ Since that time it has run on WildCat 10% Premium Extra almost exclusively except for some PM about 4 years ago when I found 6 gallons for 58 bucks. Its whole life has been spent with a Fox Miracle plug in it. The only thing changed has been to the upgraded spraybar and a new cast muffler. Sorry about the lousy picture but it does show the shiny stuff.
Click for fullsize
Hide Signatures
(in reply to w8ye)
       Post #: 20418
RE: Welcome to Club SAITO ! - 8/27/2011 1:56 AM
hsukaria
Score: 185
Status: offline
Hobbsy, I can also see all the Fox stuff in the background also . Are you trying to send subliminal messages through your pictures?
BTW, I started my Saito 180 (my first Saito ever) today for the first time. Bought used. The starter battery was dead, so I used a chicken stick. Flipped the prop backwards after priming for 2 revolutions. Easy start. Awesome throttle response. Ran for a few minutes at mid-throttle and very rich. Then leaned out and got 8500 RPM on a 16x8 prop while still fairly rich. Idle at 2000 RPM.
Fuel I used is Morgan 5% nitro, 15% synth, 5% castor (2-cycle fuel). After using the first gallon with this fuel, I plan on going to 5% nitro and all synth (2-cycle fuel), then after that I will go to 5% nitro with all synth 4-stroke blend.
Hide Signatures
       Post #: 20419
RE: Welcome to Club SAITO ! - 8/27/2011 1:58 AM
N1EDM
Score: 125
Status: offline
I've got a Saito 125 that I inadvertantly fiddled with the LSN. The engine hasn't been run yet.
Does anyone have an idea what the initial setting for the LSN should be on the 125?
Bob
Club Saito #61 Cub Brotherhood #107
Spitfire Brotherhood #143
Hide Signatures
       Post #: 20420
RE: Welcome to Club SAITO ! - 8/27/2011 2:03 AM
Hobbsy
Score: 650
Status: online
Bob, about 1/16th" below the flat surface of the throttle arm will make a good starting point.
Hide Signatures
(in reply to N1EDM)
       Post #: 20421
RE: Welcome to Club SAITO ! - 8/27/2011 2:07 AM
N1EDM
Score: 125
Status: offline
Thanks, Hobbsy
Bob
Hide Signatures
       Post #: 20422
RE: Welcome to Club SAITO ! - 8/27/2011 5:53 AM
clytle374
Score: 100
Status: offline
Took the engine off and was mounting the stack. The small end of the stack measures .315" and the carb is .335". It that enough to matter, or is it normal for the stack to be a bit smaller?
Also there is a gap between the stacks mounting plate and the carb due to the recessed area on the carb face. Should there be an o-ring or gasket there? Not having much luck finding an o-ring that fits.
quote:
ORIGINAL: w8ye
Nothing ''OS'' will fit anything ''Saito 100''
Thanks, I was using the OS pipe as an example of what I'm looking for. BTW the OS F plugs fit great
Cory
Funny thing I ran into was when I mounted originally I spaced the carb bolts to clear the firewall by .01". Adding the stack causes them to hit the firewall now. Remember thinking that could never be a problem.
Hide Signatures
(in reply to N1EDM)
       Post #: 20423
RE: Welcome to Club SAITO ! - 8/27/2011 11:55 AM
Paul_BB
Score: 100
Last Login: 6/16/2013
Status: offline
quote:
ORIGINAL: blw
770 frets24
771 Daniel-el
772 boates25
I would also like to be a member. I own a .72 and a 1.80 and I love these engines. Thanks.
"If it looks like a duck, swims like a duck, and quacks like a duck, then it probably is a duck."
Hide Signatures
(in reply to blw)
       Post #: 20424
RE: Welcome to Club SAITO ! - 8/27/2011 1:00 PM
Old Fart
Score: 158
Status: offline
Welcome mate what if anything have you guys got planned for the morning sunday and flying i hope.Sleep in for me and lazy scrambled egg and bacon brekky at the local cafe before bolting the 200r3 to the nearest fencepost at the club and opening the throttle right up.On full throttle this afternoon there is a noticable drop in rpm with the throttle wide open so guess this is the time to start leaning it off.
Hide Signatures
(in reply to Paul_BB)
       Post #: 20425
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.453RCU1
