RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  859 860 [861] 862 863 864 865 866 867 868   next >   >>
Login
RE: Welcome to Club SAITO ! - 3/26/2012 3:04 PM
Old Fart
Score: 158
Last Login: 5/25/2013
Status: offline
C'mon you guys it's the nitro that puts the bark in the dog,hang the extra fuel cost tomorrow may never come
_____________________________
Watch out for the ground eh?
Hide Signatures
(in reply to KenD)
       Post #: 21501
RE: Welcome to Club SAITO ! - 3/26/2012 5:57 PM
flycatch
Score: 118
Status: offline
I recently purchased a Saito 220 NIB and it has a problem. I'm not new to Saitos but have never experienced this particular problem and need some advice. The problem is when I move the throttle past 1/2 it backfires and throws the prop assembly. NV setting is according to the instructions for break-in and it idles fine and runs up to half throttle with no problem.
Hide Signatures
(in reply to SigMan)
       Post #: 21502
RE: Welcome to Club SAITO ! - 3/26/2012 6:02 PM
Garthwood
Score: 100
Last Login: 5/12/2013
Status: offline
quote:
ORIGINAL: Old Fart
So true......................if you don't spend it your kids will after we're gone.
Last week i ran in my SAITO 125A the one that seized up on me last fall. Got it back from Horizon......it is installed on a TF Sea Fury. With a 3-Blade Graupner it tached around 7000-7200 rpms. It still needs more running in. The high speed needle is 3 full turns out. The idle speed needle has not been touched yet, but it sitting 1mm below from flush. The weather turned cold again, so it will be a while for the next run.
Total weight of the Sea Fury (empty) is between 13-14 lbs. I'm wondering if at those rpms/prop combination if it will be able to take off. What is the formula if there's any ? This prop generates more torque. Any comments from the warbirds guys ?
WACO Brotherhood # 87
Carl Goldberg Ultimate 10-300 Brotherhood # 61
Hide Signatures
(in reply to Old Fart)
       Post #: 21503
RE: Welcome to Club SAITO ! - 3/26/2012 8:26 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: KenD
What's the chance of seeing some pics of your 150 with the ignition pickup installed?
Pretty good actually.
In fact, I have PIX of installing the hall sensor & trigger ring. (this is an old C&H unit that I ran back in '97-'98) I also got shots of my homemade pointer as well as the 3 steps involved in finding TDC.
I'll have to get them downloaded to Photobucket this evening & then I can post them.
Just converting to EI increaed RPM by 4% & decreased fuel consumption by 19% when using the same 15% Cool Power. This was W/an 18X8 prop that was a bit of overload for static. I did a consupsion test way back W/a 16X8 prop & the fuel consumption dropped dramatically more.
C&H is no longer in business, but ST Engines makes a conversion based on the same type of easy adjust trigger ring & cam housing mounted hall sensor. Their unit is engineered much better than the old C&H, but it is just as user friendly.
Here is a clip that shows the complete gas conversion. It shows the ease of the ingnition conversion that is a much better set up for adjusting the ignition timeing than the Saito OEM system. The Saito system relys on accurate placement of the trigger magnet in the prop hub & making fine adjusments via the hall sensor. the C&H as well as ST Engines system allows infinite adjustment of the trigger ring.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to KenD)
       Post #: 21504
RE: Welcome to Club SAITO ! - 3/26/2012 10:09 PM
KenD
Score: 100
Last Login: 5/24/2013
Status: online
Thanks, I have the complete conversion setup, just wondered how the pickup assembly was installed because of the splines near the prop hub. BTW CH ignitions are alive and well and being producted by a different person.
KenD
Club Saito Member #773
AMA 64943
IMAA 23743
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 21505
RE: Welcome to Club SAITO ! - 3/26/2012 10:12 PM
hsukaria
Score: 185
Status: offline
Where would you buy this conversion kit shown in the video? How much $$$? Is that with a Walbro pumper carb that can run gasoline?
THANKS.
Content, but not Complacent.
Saito Club Member #765
Hide Signatures
       Post #: 21506
RE: Welcome to Club SAITO ! - 3/26/2012 10:15 PM
hsukaria
Score: 185
Status: offline
quote:
ORIGINAL: Garthwood
quote:
ORIGINAL: Old Fart
I have a Great Planes Giant Stick with a Saito 1.8 that weighs 14 lbs. I wish I had more power or that the plane weighed less.
Hide Signatures
(in reply to Garthwood)
       Post #: 21507
RE: Welcome to Club SAITO ! - 3/28/2012 12:10 AM
Ernie Misner
Score: 130
Status: offline
flycatch, it's going lean for some reason, could be dangerous until you figure it out, wear your safety equipment. As soon as a 4-stroke goes lean the combustion timing advances radically and..... BAM. Souds like fuel flow is restricted somewhat, air leak at intake O-ring, or whatever. Richen the needles up drastically and see if it still does it. Good luck, keep us posted.
Ernie Misner
Hide Signatures
(in reply to flycatch)
       Post #: 21508
RE: Welcome to Club SAITO ! - 3/28/2012 12:22 AM
RC Specialties
Score: 100
Last Login: 5/7/2013
Status: offline
Garthwood
You have that 125 loaded up with the Graupner. You should be up around the low 9K's. At that weight the airplane will fly but may be sluggish. Unload it and let it work. Follow the normal tuning process with a different prop.
Jim
RC Specialties, LLC, Four Stroke Mufflers and 90 Degree Exhaust Adapters
Hide Signatures
       Post #: 21509
RE: Welcome to Club SAITO ! - 3/28/2012 3:14 AM
mvarzoni
Score: 100
Last Login: 5/19/2013
Status: offline
Dear all,
I'm not a club member, but I would love be...
I have a question.
Is there any bad if I mount the exaust pipe pointing up like showed on the picture?
Hide Signatures
(in reply to RC Specialties)
       Post #: 21510
RE: Welcome to Club SAITO ! - 3/28/2012 3:15 AM
w8ye
Score: 318
Status: offline
They run fine that way
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Original AMA #31261
Hide Signatures
(in reply to mvarzoni)
       Post #: 21511
RE: Welcome to Club SAITO ! - 3/28/2012 3:27 AM
mvarzoni
Score: 100
Status: offline
pic
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 21512
RE: Welcome to Club SAITO ! - 3/28/2012 3:43 AM
w8ye
Score: 318
Status: offline
I think it looks neat with the smoke coming out the top of the engine as the airplane flies along.
The engine does not care.
However, from a theory point of view, if the engine is flooded at starting, there is no way for the fuel to get out.
Original AMA #31261
Hide Signatures
       Post #: 21513
RE: Welcome to Club SAITO ! - 3/28/2012 3:47 AM
mike early
Score: 125
Status: offline
is that plane upside down?
Saito Club Member #578
P-40 Brotherhood #62
Hide Signatures
(in reply to w8ye)
       Post #: 21514
RE: Welcome to Club SAITO ! - 3/28/2012 6:27 AM
Ernie Misner
Score: 130
Status: offline
Some teflon tape on all the exhaust threads might keep her a little cleaner. I like a percentage of castor too.......
Ernie
Hide Signatures
(in reply to mike early)
       Post #: 21515
RE: Welcome to Club SAITO ! - 3/28/2012 8:58 AM
radial1951
Score: 105
Status: offline
Castor oil in gas (Petrol) OR is it nitro??  Is that an ignition sensor mount near the prop driver...? Where's the carby?
Regards, Ross
radial1951
_______________
quote:
ORIGINAL: Ernie Misner
Ernie
Hide Signatures
(in reply to Ernie Misner)
       Post #: 21516
RE: Welcome to Club SAITO ! - 3/28/2012 12:35 PM
Garthwood
Score: 100
Status: offline
quote:
ORIGINAL: RC Specialties
Garthwood
Jim
Jim......thank you. I know that the 3-blade prop is loading up. What you are saying is that first I should make the normal running in procedure with a 2-blade prop like a 16x8 . After that I can install back the 3-blade prop ?
With a 3-blade prop I was expecting only around 8000 rpms.
Hide Signatures
       Post #: 21517
RE: Welcome to Club SAITO ! - 3/29/2012 2:36 AM
Ernie Misner
Score: 130
Status: offline
Oops, it does look like a gasser, so probably no castor, sorry, ..... still might be leaking a bit at those joints.
Ernie
Hide Signatures
       Post #: 21518
RE: Welcome to Club SAITO ! - 3/29/2012 11:17 AM
RC Specialties
Score: 100
Status: offline
Gartwood,
You want to avoid loading up an engine too much in any case. Use a three blade that will keep your engine in a proper rpm range. I believe the one you have is too much prop for that engine, given the rpm you stated.
Jim
Hide Signatures
       Post #: 21519
RE: Welcome to Club SAITO ! - 3/29/2012 12:33 PM
Garthwood
Score: 100
Status: offline
Gartwood,
Jim
JIM..............Thanks. I'll probably switch to a 16x8 2-blade.
Hide Signatures
       Post #: 21520
RE: Welcome to Club SAITO ! - 3/29/2012 2:11 PM
Old Fart
Score: 158
Status: offline
Ernie it looks from the pic that it runs very hot around the exhaust header area,is this normal for a gas saito? how much hotter do they run compared to a nitro saito?
Hide Signatures
       Post #: 21521
RE: Welcome to Club SAITO ! - 3/29/2012 4:22 PM
spaceworm
Score: 143
Status: offline
quote:
ORIGINAL: Old Fart
I think gas does run hotter, but I think maybe that gunk around and on the muffler may be from before the glow to gas conversion? I would like to know as I am thinking to convert my FA 180 to gas or maybe to glow with spark ignition to improve fuel economy.
Sincerely, Richard
Hide Signatures
       Post #: 21522
RE: Welcome to Club SAITO ! - 3/30/2012 4:31 AM
Ernie Misner
Score: 130
Status: offline
Good question guys, maybe the owner of that gasser will chime in. We do know that gas can run a lot hotter without the cooling effect of all that alcohol going through. You get an equal amount of oxygen but the alcohol mixes at a ratio of approx.? 8 to one instead of 14 to 1 with gas. You can feel the cooling action of alcohol when it evaporates from your hand plus there's that much more going through the pipe line.
Ernie
Hide Signatures
(in reply to spaceworm)
       Post #: 21523
RE: Welcome to Club SAITO ! - 3/31/2012 3:45 PM
flyingt5150
Score: 100
Last Login: 1/3/2013
Status: offline
Hi Everyone,
I have a .65 Satio Golden Knight four stroke.  I put it on a H9 piper pawnee 40. It was very doggy.  I love this engine!  I want
to find a model for this engine.  I was thinking of a Sig Astro Hog, would this be a good fit for this great engine.
Thanks for any input
''''But who''s going to fly it kid, you?'''' Han Solo
Hide Signatures
       Post #: 21524
RE: Welcome to Club SAITO ! - 3/31/2012 8:38 PM  1 votes
GaGeeBees
Score: 313
Status: offline
Any of the 1/5 scale Cubs are a great match. Hangar 9, Great Planes, SIG...
...and then the unthinkable happened!
Hide Signatures
(in reply to flyingt5150)
       Post #: 21525
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
