RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
Users viewing this topic: Quikturn, blw, SrTelemaster150
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  865 866 [867] 868 869 870 871 872 873 874   next >   >>
Login
RE: Welcome to Club SAITO ! - 4/22/2012 6:34 AM
Ernie Misner
Score: 130
Last Login: 5/25/2013
Status: offline
If the throttle is closed all the way tight, when the piston goes down on the intake stroke it can't suck any air, fuel, or anything at all in - so it just creates a vacuum in the combustion chamber. Then when the piston goes up for the "compression stroke", no compression will be made because there is merely a vacuum in there. Making sense now? I puzzled over that a few times myself! Another "gotcha" is when it will have compression when you turn it one way, but not the other. Anyone know why?
Ernie Misner
Hide Signatures
(in reply to orthobird)
       Post #: 21651
RE: Welcome to Club SAITO ! - 4/22/2012 8:44 AM
FNQFLYER
Score: 110
Status: offline
Old Fart, my big hammer is a 15 pound sledge hammer head on a piece of steam pipe used on engine abusers, errant cats and the odd snake (water python) that wanders into the shed.  I have acquired a Blacksmiths "training anvil"  (that is what is says on the side.
Re props, I am hearing that some one is producing Bolly clones, do you have any info.
I am also trying to locate some Sherlock props but am having no success from my WA contact can you advise??
Good day today, appears as if wet season has passed us by up here, just lots of blue sky, eagles and a new club to join at Mareeba.
Catch ya later
_____________________________
Club Saito member 710
Hide Signatures
(in reply to Ernie Misner)
       Post #: 21652
RE: Welcome to Club SAITO ! - 4/22/2012 11:40 AM
Old Fart
Score: 158
Last Login: 5/26/2013
Status: offline
Hi mate do you think an 18x8@8000 is a bit fast,earoplane wise i mean.My 82 runs a 14x6@8400 it really scoots along
Watch out for the ground eh?
Hide Signatures
       Post #: 21653
RE: Welcome to Club SAITO ! - 4/22/2012 11:41 AM
Old Fart
Score: 158
Status: offline
I'll check here and pm you.
Hide Signatures
(in reply to FNQFLYER)
       Post #: 21654
RE: Welcome to Club SAITO ! - 4/22/2012 12:32 PM
orthobird
Score: 105
Status: offline
the decathlon weighs in at 18 pounds.  it is very very slow right now.
avoid crashing!!
Hide Signatures
(in reply to Old Fart)
       Post #: 21655
RE: Welcome to Club SAITO ! - 4/22/2012 4:37 PM
flycatch
Score: 118
Status: offline
For all those who own a Saito 220 4S that won't idle I believe I have found the problem. Check your valve clearence after break-in and then again after thrity minutes of air time. What I found amazed me.
Hide Signatures
       Post #: 21656
RE: Welcome to Club SAITO ! - 4/22/2012 9:45 PM
rexracer
Score: 100
Last Login: 11/5/2012
Status: offline
I don't have a 220, but do tell...what was it?
Club Saito member #173
Hide Signatures
(in reply to flycatch)
       Post #: 21657
RE: Welcome to Club SAITO ! - 4/22/2012 9:53 PM
ChrisFlysRC
Score: 100
Last Login: 5/22/2013
Status: offline
I have a Saito 82 and the muffler keeps loosening up during any flights I make on my Pawnee. I recently got a new Saito muffler and plan on adding locktite to keep the muffler on and not from loosening up cause engine failure in flight. Has anyone has the same problems. Also the muffler extension from Dubro wont stay on the muffler with the tie included from Dubro. Any recommendations other than locktite for the muffler?
Chris
Hide Signatures
(in reply to rexracer)
       Post #: 21658
RE: Welcome to Club SAITO ! - 4/22/2012 10:19 PM
w8ye
Score: 318
Status: offline
Back when the Saito 62 first came out, there was a guy on here with one that kept breaking the exhaust pipe.
So he placed it for sale in the RCU Market Place. I bought it.
It came with a new exhaust pipe - I put it on a Ultra Stick 40 and have been using it for three years and have never had any trouble with the exhaust pipe or muffler.
In the package, he included the spinner and adapter that he had on the plane. The aluminum spinner had been forced down over the prop without making the prop reliefs bigger and had warped it. Needless to say, I used a new spinner that was cut out for the 13 X 6 prop I was using.
The newer versions of the Saito cast mufflers have been machined on the outlet to be straight on the outside with a groove machined in it with a knot out on the end for the Dubro extension strap to have something to grab against. The part number for the one on the 82 is SAI6574D.   Notice the "D" out on the end. This is the machined one.
This link should get you to the Saito 82 and you will have to look at the parts  http://www.horizonhobby.com/products/82-aac-with-muffler-new-case-ab-SAIE082B
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to ChrisFlysRC)
       Post #: 21659
RE: Welcome to Club SAITO ! - 4/22/2012 11:45 PM
blw
Score: 655
Status: online
Teflon tape works well from what people say. Ive never had problems with Saito mufflers.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to w8ye)
       Post #: 21660
RE: Welcome to Club SAITO ! - 4/23/2012 12:39 AM
Hobbsy
Score: 650
Status: offline
Jim, my .62 has never turned anything but a Graupner 12x7, it electric motor smooth, it has never loosened the stock muffler nor a TurboHeader. I may be able to fly in a couple of weeks, my RCM 40 is ready with the .62.
This also qualifies as training to play the bagpipes.
Click to see fullsize image.
Click for fullsize
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to w8ye)
       Post #: 21661
RE: Welcome to Club SAITO ! - 4/23/2012 1:16 AM
mike109
Score: 148
Status: offline
G'day
Dave - I don't think that anyone has ever managed to really learn to play the pipes
On another Saito note, I took my little Tiger Moth bi-plane out for an airing yesterday. It has not been out for about 12 months. It is powered by a Saito 40a. It took a little while to get it to start as I think there was some fuel residue in the carby but once running we were into the air. I had forgotten just what a nice quiet, powerful little engine the 40a is. I had a long flight even doing some very un-scale loops and inverted flight. Even managed a passable roll. It was fun on a stick.
Cheers
Mike in Oz
"I just had no control. Must be the radio." Club Saito #597 Kadet Brotherhood #66
Hide Signatures
(in reply to Hobbsy)
       Post #: 21662
RE: Welcome to Club SAITO ! - 4/23/2012 2:56 AM
radial1951
Score: 105
Last Login: 5/24/2013
Status: offline
Hi mike
"...un-scale loops and inverted flight. Even managed a passable roll..."  ???  Really?  With a Tigger?
I wasn't sure what a Tiger Moth could actually do, being an old fashioned bi-plane and all... BUT it seems there isn't much it can't do!!
Worth a look:
Must be Saito powered...
Regards RossG
radial1951
_____________
quote:
ORIGINAL: mike109
G'day
Cheers
Mike in Oz
Hide Signatures
(in reply to mike109)
       Post #: 21663
RE: Welcome to Club SAITO ! - 4/23/2012 3:35 AM
hsukaria
Score: 185
Status: online
quote:
ORIGINAL: radial1951
Hi mike
''...un-scale loops and inverted flight. Even managed a passable roll...''  ???  Really?  With a Tigger?
Worth a look:
Regards RossG
radial1951
_____________
quote:
ORIGINAL: mike109
G'day
Cheers
Mike in Oz
That must be a really big Saito on that plane!!!
Content, but not Complacent.
Saito Club Member #765
Hide Signatures
(in reply to radial1951)
       Post #: 21664
RE: Welcome to Club SAITO ! - 4/23/2012 12:49 PM
mike109
Score: 148
Status: offline
G'day
The DH82 Tiger Moth used to be very common in our skys. The British and Commonwealth airforces used thousands of them to train beginning pilots. There were several training schools not far from where I now live in Dubbo in country New South Wales. After WWII, thousands of them were sold into private hands and I remember seeing them quit often flying over our house in Sydney. These days they are still around but have become collector's items rather than day to day planes.
After watching that video, I must have a go at getting it to spin. It was just so majestic.
A Tiger will do a loop but it needs a bit of help in the form of a small dive to get a little extra airspeed. My model, with the Saito 40a, is probably overpowered compared to the originals as it will loop from level flight.
The video above shows just how aerobatic they were and still are. They are said to be "easy to fly" but " not easy to fly well" and instructors liked them as they tended to weed out inept students quickly. It would have had a Gypsy Major inverted air cooled four cylinder engine of 130HP. They are unusual in that they rotate the opposite way to most aero engines and the opposite of our Saitos. Top speed? 109 mph. Cruise speed? 67 mph. And in the 1930s, people flew the earlier DH 60 Gipsy Moth from England to Australia. At least you would see the scenery. Slowly.
My brother-n-law was recently given a flight in one for his birthday. He really looked the part with a leather flying helmet.
Cheers
Mike in Oz
Hide Signatures
(in reply to hsukaria)
       Post #: 21665
RE: Welcome to Club SAITO ! - 4/23/2012 2:36 PM
hsukaria
Score: 185
Status: online
quote:
ORIGINAL: Hobbsy
Hobbsy, I know Saitos spin big props, but WOW!!! That must have been a big prop that whacked your arm.
< Message edited by hsukaria -- 4/23/2012 5:55 PM >
Hide Signatures
       Post #: 21666
RE: Welcome to Club SAITO ! - 4/23/2012 9:30 PM
w8ye
Score: 318
Status: offline
As you already know, you will really enjoy the Saito 62. They are a really fine engine.
Original AMA #31261
Hide Signatures
       Post #: 21667
RE: Welcome to Club SAITO ! - 4/23/2012 10:45 PM
Ernie Misner
Score: 130
Status: offline
If your dubro exhaust extention is coming off - use JBWeld and build up a little "ring" or high spot around the end of the muffler. When that sets up you can file it some if your shape didn't turn out just right. Also use a little red (high temp) silicone rubber when you zip tie the extention back on. It won't come off again.
Use a bit of teflon tape on the exhaust threads or plumbers thread compound that has teflon (high temp) in it. After you get the engine hot then re-tighten the lock nuts and that should do it. Make sure the prop is balanced too.
Ernie Misner
Hide Signatures
(in reply to w8ye)
       Post #: 21668
RE: Welcome to Club SAITO ! - 4/24/2012 2:33 AM
ckreef
Score: 105
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: Ernie Misner
I did that on a OS .40 LA and the exhaust hasn't come off since then
If you have an extension without a lip ("ring")  it will eventually fall off.
Hide Signatures
       Post #: 21669
RE: Welcome to Club SAITO ! - 4/24/2012 5:40 AM
Ernie Misner
Score: 130
Status: offline
If you want to make a perfect looking JBWeld ring on the end...... after putting the JBWeld on, stand the muffler up on its end with a piece of waxed paper between the ring end of the muffler and a hard surface. When dry file or sand the ring a bit and it will amaze you.
Ernie Misner
Hide Signatures
(in reply to ckreef)
       Post #: 21670
RE: Welcome to Club SAITO ! - 4/24/2012 8:38 AM
Kostas1
Score: 330
Status: offline
My recent test-run:
<==**Check my gallery for more pictures**
Club Saito member #706
Hide Signatures
       Post #: 21671
RE: Welcome to Club SAITO ! - 4/24/2012 1:21 PM
Old Fart
Score: 158
Status: offline
So THAT'S where you hide your hairy knuckles
Hide Signatures
       Post #: 21672
RE: Welcome to Club SAITO ! - 4/29/2012 4:17 AM
Tarasdad
Score: 135
Last Login: 3/31/2013
Status: offline
Thanks to the generosity of a fellow RCU forumite I now own two Saito FA-91s. Both need some TLC but hey, they were free so I can't complain! Both are rear vent but have the newer muffler. One has the letter "F" stamped on the right mounting lug, the other has nothing. I plan to do a careful cleaning and tear down of them to see what parts they will need.
I do love Saito, and now I own three!
Tarasdad
Club Saito #680; 2x Saito .91, Saito .80, Fox .50, Fox .25, Fox .19; Apprentice 15e; Tiger 60; Super Chipmunk
Hide Signatures
       Post #: 21673
RE: Welcome to Club SAITO ! - 4/29/2012 4:24 AM
w8ye
Score: 318
Status: offline
All the 91's have a rear vent
The one with no letter on the lug has a replacement crankcase.
Original AMA #31261
Hide Signatures
(in reply to Tarasdad)
       Post #: 21674
RE: Welcome to Club SAITO ! - 4/29/2012 4:30 AM
Tarasdad
Score: 135
Status: offline
Thanks for the info, I was wondering about the missing stamp. Going to be interesting to tear these down (one at a time, of course!) and see how they are. I'm hoping they'll just need a good cleaning but one may need bearings. Both are pretty dirty, especially the mufflers. I have a feeling both are pretty well gummed up with old castor. Fortunately I have some fresh fuel on hand to soak 'em in.
Tarasdad
Hide Signatures
(in reply to w8ye)
       Post #: 21675
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.766RCU1
