RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
Users viewing this topic: spaceworm, rcrichman, smkrcflyer, Quikturn
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  896 897 [898] 899 900 901 902 903 904 905   next >   >>
Login
RE: Welcome to Club SAITO ! - 7/21/2012 1:05 PM
earlwb
Score: 584
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: Ernie Misner
Hey Hobbsy, I thought I was the only one that didn't like cowlings. They do look nice but I like to clean the engine exterior with a toothbrush and acetone when I get home..... guess they have medicine for people like me......
Ernie Misner
Clean the engine? Why? I usually don't bother much with the outside of the engine, until I need to move the engine to a new plane after it wears out the current plane.
Using a cowl is easy. What I do is use some large wide pieces of masking tape. I put the tape on the fuselage amd lay it forward over the engine. Then mark where I want the holes at for the engine, etc. Then I loop the tape back out of the way, remove the engine, then fit the cowl in place. Then unloop the tape and stick it to the cowl. Then I can remove the cowl and the marks on the tape stuck to the cowl are my guides for the holes needed.
Now this old bipe of mine uses old fashioned methods of taking large blocks of balsa and carving and sanding and dremeling until you get it shaped into a cowl., No plastic or fibreglass for the front end on this old bipe. The engine was getting pretty tired, so I did have to clean all the gunk off before I could rebuild it though.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Hobbsy -- 8/23/2012 7:14 PM >
_____________________________
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to Ernie Misner)
       Post #: 22426
RE: Welcome to Club SAITO ! - 7/21/2012 1:43 PM
lopflyers
Score: 140
Status: offline
Clean the exterior of the engine? I bet the plane itself is pristine then. You will have a heart attack if you fly out of grass
Keep your wings level
Club Saito Member #693
Hide Signatures
(in reply to earlwb)
       Post #: 22427
RE: Welcome to Club SAITO ! - 7/21/2012 4:46 PM
riadh
Score: 100
Last Login: 3/4/2013
Status: offline
Hi blw ,count me in in the Club Saito please. I think I am eligible ,I have a Saito 82 A sitting in a H9 Pawnee and flies it 100% scale like. Last week I got myself a Saito 220 which will go in a World Models Spitfire 160 ;80 inch wing span. This would be to me a new dimension to deal with as to date the 82 is the biggest engine I own. Knowing that the Club Saitos Gurus are around I am sure I wont run astray dealing with this new engine. Cheers
Hide Signatures
(in reply to blw)
       Post #: 22428
RE: Welcome to Club SAITO ! - 7/22/2012 3:15 AM
svenska3
Score: 100
Last Login: 5/5/2013
Status: offline
I have this beautiful 125 I need to find a plane for. I'm a intermediate pilot. I don't fly 3-D. Any suggestions???
Walt
Hide Signatures
(in reply to SigMan)
       Post #: 22429
RE: Welcome to Club SAITO ! - 7/22/2012 3:55 AM
earlwb
Score: 584
Status: offline
quote:
ORIGINAL: svenska3
Walt
Just about any .60  size plane would work with the engine. Even the .60 to .91 two stroke size planes would work. A Great Planes Escapade might be a good choice as it can handle a wide variety of engines. But you have many choices to fit your desires in that size range.
AMA # 928076
Hide Signatures
(in reply to svenska3)
       Post #: 22430
RE: Welcome to Club SAITO ! - 7/22/2012 3:59 AM
Cougar429
Score: 128
Last Login: 5/17/2013
Status: offline
Earlwb, I found a better method of marking cowls for motor cutouts a while ago.
I had originally used stiff cardboard and working slowly carved the opening to fit over the motor, then folded it away till the motor was removed and the cowl bolted on. Taping the cardboard back onto the cowl then showed the area to be removed. This was a time consuming and laborious process that many times required starting again.
Since then I found clear and stiff binder protector pages provide a much easier method. As with cardboard you provide a fold line in the plastic sheet and once taped to the fuse, hold it over the motor. Using a sharpie I can mark the area to be removed with greater accuracy the first time. Some shifting may be required to account for angles if the head/cylinder protrude a lot, but in the end it works first time and is a lot more accurate, (the edge is a lot sharper than cardboard or heavy paper).
Club Saito Member # 787
FA91, 100, 2 X 125a, 150
Hide Signatures
(in reply to riadh)
       Post #: 22431
RE: Welcome to Club SAITO ! - 7/22/2012 8:46 AM
rowdyjoe
Score: 105
Last Login: 5/18/2013
Status: offline
I use semi-flexible clear plastic to make a template when mounting an engine.  I make it by cutting the plastic to the size of the firewall and finding the direct center of both.  Once the center is located it's a simple process to set the engine mount on it and mark the hole locations.  Then align the plastic pattern on the firewall and transfer the hole locations.
It works great but, be sure to measure twice and cut once.
RJ
Rowdyjoe
Saito 783
Hide Signatures
(in reply to Cougar429)
       Post #: 22432
RE: Welcome to Club SAITO ! - 7/22/2012 12:04 PM
Old Fart
Score: 158
Status: offline
quote:
ORIGINAL: svenska3
Walt
Hi walt yes i do have a suggestion.Stick the 125 in a cmpro midget mustang.They don't like flying anywhere near 3d and go like a bat out of hell keeps you focused and it's a lot of fun mate..trust me on this one
Watch out for the ground eh?
Hide Signatures
       Post #: 22433
RE: Welcome to Club SAITO ! - 7/22/2012 1:23 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Cougar429
My Wingsmaker (World Models) 1/5 Piper J-3 Cub came W/a clear plastic cowl layover to do the engine cut outs.
It would be nice if all models came W/one of those.
I'm thinking that one could use a 2 liter bottle shrunk over the cowl to make a similar layover for smaller cowls.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 22434
RE: Welcome to Club SAITO ! - 7/22/2012 5:20 PM
CH Ignitions
Score: 420
Last Login: 5/6/2013
Status: offline
My first Saito was the FG20 in 2009.
Now I have Fa 30, 45,91,125,120,150,180,220 ,Twins130, 270,300.
FG 20,30 I love the sound of the 4 stroke Saito engines, and I try to improve the performance by convert tem to CDI  glow or to gasoline.
I will like to join the club.
Adrian
Click for fullsize
Click for fullsize
www.ch-ignitions.com
Hide Signatures
(in reply to balsa brain)
       Post #: 22435
RE: Welcome to Club SAITO ! - 7/22/2012 5:46 PM
triumphman49
Score: 110
Status: offline
Welcome aboard Adrian, great to hear from you
T-man49 in Al
Club Saito 723
Spitfire Bro 19
Hide Signatures
(in reply to CH Ignitions)
       Post #: 22436
RE: Welcome to Club SAITO ! - 7/22/2012 6:33 PM
the pope
Score: 101
Status: offline
quote:
ORIGINAL: SrTelemaster150
quote:
ORIGINAL: Cougar429
Be nice if my world models airplane came with wings that wernt twisted like a pretzel and had the right amount of glue in the right places and even nicer if their customer service was worth a hoot ! Cheers the pope
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 22437
RE: Welcome to Club SAITO ! - 7/23/2012 1:26 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: the pope
quote:
ORIGINAL: Cougar429
Maybe you should have bought it from Wingsmaker. They have spare parts in stock, but my Cub looks perfect aside from a small pinhead drop of epoxy on the top cabin window. (not enough to worry about IMO)
$179 shipped too. Can't beat that.
Hide Signatures
(in reply to the pope)
       Post #: 22438
RE: Welcome to Club SAITO ! - 7/23/2012 1:31 AM
N1EDM
Score: 125
Status: offline
Hi everyone,
I dropped my Saito .82 into my H9 Cub and flew it today with a 14x6 prop and 10% nitro. The plane seemed to leave an awfully heavy smoke trail - more than normal. After I brought it down, I started to hear mechanical sounds in the engine.
At first I was wondering if the valves were out of kilter but they seem OK. The engine hasn't got that much time on it and it hasn't been abused.
I haven't pulled the head off to inspect the piston but I might. Being a Cub, I was being pretty easy on the throttle, by the way.
I was also considering that it might be the LSN setting, but am not sure.
Before I go tearing into things, I was just wondering if anyone else has encountered this and where I should be directing my diagnostics
Bob
Club Saito #61 Cub Brotherhood #107
Spitfire Brotherhood #143
Hide Signatures
       Post #: 22439
RE: Welcome to Club SAITO ! - 7/23/2012 1:33 AM
rowdyjoe
Score: 105
Status: offline
More on the overheating problem ....
I tried the 13x8 prop thinking I could get more RPM and less load on the engine.  Well, that was wrong as the 14x6 turned 9400 vs 8800 for the 13x8.  I left the 14x6 on and started from at the factory needle positions ...I was evidently missing the step where your supposed to adjust the high end again after adjusting the low end.  As it turned out, I was running the low end far too lean and it was definately affecting the high end (duh).  I have a steady idle at 2000 to 2100 rpm and a WOT RPM at 8800 RPM.  I tuned it a bit rich to keep it cooler in the hotter weather.
I havn't run it yet with the cowl on and that will be the acid test.  I've added one more baffle to direct the air flow over the cylinder.  It's a piece of stiff but, flexible clear plastic protruding perpendicular from the middle fo the cowl to force the air over the cylinder rather than blowing past it.  I'd take a picture but, you wouldn't be able to see it because it's clear.
I didn't close off more of the grill I installed an actual baffle to direct the air.
Hope you can make sense out of what I said.
RJ
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 22440
RE: Welcome to Club SAITO ! - 7/23/2012 2:22 AM
Cougar429
Score: 128
Status: offline
I did and it sounds like you are working in the right direction.
N1EDM, do you know your top end RPM? It may keep the RPM down with the larger diameter prop, but I find the Saito chart a bit on the aggressive side and also when working the larger diameters in their chart the torque effects when doing 3D are more pronounced.
The heavier smoke trail usually indicates a richer mixture. I don't have any problem running mine that way and except for a bit more mess actually prefer it that way to ensure good lubrication.
Hide Signatures
(in reply to rowdyjoe)
       Post #: 22441
RE: Welcome to Club SAITO ! - 7/23/2012 2:41 AM
N1EDM
Score: 125
Status: offline
Hi Cougar,
I didn't tach it but she seemed to be up there with normal RPM. She was just breaking into a 2-stroke scream before I backed her off. She survived the pinch test OK but I could not lean her out much after that.
I know enough to suspect that compression might be an issue but she feels pretty good and, as I said before, she hasn't been abused. So far, the only thing I've done is to pop off the rocker arm covers and check the play. I also realize that in a 4S, the LSN has a greater influence on the midrange (correct me if I'm wrong, guys) but I didn't touch that because the engine was running OK. Plug was an OS Type F, by the way.
Any other ideas from anyone???
Thanks for the reply,
Bob
Hide Signatures
       Post #: 22442
RE: Welcome to Club SAITO ! - 7/23/2012 3:10 AM
blw
Score: 655
Status: offline
Bob,
A large smoke trail on a Saito usually indicates a lsn set too rich. The lsn controls something like 75% of the throttle. You may find some nice things on your 82 if leaned out.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to N1EDM)
       Post #: 22443
RE: Welcome to Club SAITO ! - 7/23/2012 3:18 AM
Hobbsy
Score: 650
Status: online
Ok Garry, since the HS needle has a fixed seat its best to set the HS at full peak and leave it there while adjusting the LS needle, this eliminates one variable You always want the LS needle a little on the rich side when the setting the HS needle the first time, Once the ZLS needle is set, it will be a long time before it needs attention again if ever. A too lean LS needle renders the HS needle ineffective.
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
       Post #: 22444
RE: Welcome to Club SAITO ! - 7/23/2012 4:14 AM
frets24
Score: 148
Status: offline
Who here has experience with the FA-200Ti?
I haven't ever needed a glow driver with any of my Saito twins or any singles when inverted; Just wondering if maybe I should plan on using the McDaniels on this one since it will be inverted when mounted and the single carby twins seem to run rich on one cyl or the other. All of my -R3's need a driver at low rpm on at least the lower left cyl(front view). Have been told that's common....have yet to hear different.
Also how smooth is it? It's an offset crank twin which typically provides the smoothest operation on an opposed set-up but how does that translate to inline/vee type configuration. Always loved the Saito's though the 91s was so vibratory I had to shelf it 'til I find a more suitable air frame for it. Shook the gunsight off its mounts and the pilot bust loose on too numerous occasions. Hoping the 200Ti isn't inherently similar.
And lastly; any tips on proping this thing for the best performance on a 14lbs Zero (72")
TIA
Club Saito #770
"The American taxpayer has always been politicaly deceived. Its their Birthright!"
Lord Mountjoy, The Mouse on the Moon
Hide Signatures
(in reply to Hobbsy)
       Post #: 22445
RE: Welcome to Club SAITO ! - 7/23/2012 4:28 AM
Cougar429
Score: 128
Status: offline
I'm a bit surprised your 91 was so bad. Mine is extremely smooth with either 2 or 3-blade props.
Hide Signatures
(in reply to frets24)
       Post #: 22446
RE: Welcome to Club SAITO ! - 7/23/2012 5:52 AM
frets24
Score: 148
Status: offline
I had replaced the bearings and the ring (Frank bowman ring) immediatly upon receiving it (used) even though it felt great and looked perfect inside and out...just my normal MO. Came from an estate and appeared to have very little, if any time on it at all. Definitely no damage.
The thing runs great...lots of power; just a lot of vibration at 3/4 thru full throttle. Same with several props; 2 blade various mfgs and 3 blade Graupners.
Probably going on a .60 Super Sportster on floats...The vibes won't be an issue there.
Hide Signatures
       Post #: 22447
RE: Welcome to Club SAITO ! - 7/23/2012 6:08 AM
rowdyjoe
Score: 105
Status: offline
quote:
ORIGINAL: Hobbsy
OK Dave,  I understand what you're saying and I have learned more about the relationship between the two today.  The LS is still rich as is evident by the pinch test at idle (rpm rises when pinched).  There's a lot of smoke when transitioning to higher rpm and there's a light smoke trail at high rpm.  I don't know if that's an indicator of anything other than the amount of lube that's in the fuel.  I'm using 30% nitro/23% lube heli fuel at the moment.  The engine seems to like it but, it sure smokes a lot.  One or two neighbors may have thought my garage was on fire but, nobody called the FD ...thank God.
I'll put the plane on the run-up bench again tomorrow and see if I can reach a better setting between the two.  At the moment, transition is smooth, idle is OK, and high speed is good with no excessive heat.  However, I don't think I left the HS needle at max. rpm while adjusting the LS.  I'm pretty sure I adjusted it about 500 or 600 rpm down from peak and then adjusted the LS.  I'll try to correct that tomorrow.
Thanks again,
Garry
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 22448
RE: Welcome to Club SAITO ! - 7/23/2012 6:16 AM
Ernie Misner
Score: 130
Status: offline
Ohhh I won't sleep well after seeing that dirty engine. Don't they run better when they're clean and shiny?
Hide Signatures
(in reply to riadh)
       Post #: 22449
RE: Welcome to Club SAITO ! - 7/23/2012 8:35 AM
jamesroutledge
Score: 100
Status: offline
Hi Fretts
I had a similar problem losing cylinders on an inverted 200ti. I then mounted it upright on a 120 Ultrastick and ran a couple of gallons of fuel through it.
It now behaves inverted with no onboard glow.
James
SAMAA 5409
Club Saito Member #766
Hide Signatures
       Post #: 22450
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.719RCU1
