RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
Users viewing this topic: slofly1900
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  919 920 [921] 922 923 924 925 926 927 928   next >   >>
Login
RE: Welcome to Club SAITO ! - 10/8/2012 4:45 PM
captinjohn
Score: 247
Last Login: 5/19/2013
Status: offline
If toothpaste would damage a crome surface....I sure would like to see that....how about a photo ....from the guy that stated that!!!!!!
_____________________________
I never met a engine I did not like !
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 23001
RE: Welcome to Club SAITO ! - 10/8/2012 5:03 PM
TexasSkyPilot
Score: 438
Last Login: 5/17/2013
Status: offline
Maybe toothpaste delivered by way of some sort of a power tool. Otherwise, it would take you most of the day and WHOLE LOT of toothpaste. I think the rag or whatever you're applying it with would have just as much in the way of abrasive qualities, if not more.
There's a kind of toothpaste, used by Dental hygienists, called prophy paste. That actually has pumice in it. You could lap a valve with the heavier version of that stuff. That's why you have to rinse out your mouth (or why they rinse it out for you, depends on the dentist), and why you feel little bits of grit afterwards.
But regular toothpaste has not had pumice in it for decades now. Bicarb of soda, stuff like that. Nothing truly abrasive.
And yes, I am an expert witness when it comes to this.
~ Jim ~
J.M. Surra, author of AERODYNAMIC, and T.I.T.O.R. - In July of 1947, something crashed in Roswell, New Mexico. . .
Hide Signatures
(in reply to captinjohn)
       Post #: 23002
RE: Welcome to Club SAITO ! - 10/8/2012 5:35 PM
blw
Score: 655
Status: online
quote:
ORIGINAL: captinjohn
The point is that nobody ever said that. Go figure.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
       Post #: 23003
RE: Welcome to Club SAITO ! - 10/8/2012 7:55 PM  1 votes
SrTelemaster150
Score: 227
Status: online
quote:
ORIGINAL: TexasSkyPilot
~ Jim ~
You apply the toothpaste to the valve face, insert the valve into the guide & use your fingers to rotate the valve from the outside in a pulling, spinning motion. I does not "grind" or "lap" the valves as much as it cleans/polishes the surfaces thouroughly removing stubborn varnish.
Water cleans up all traces of the toothpaste.
We used to use toothpaste to burnish brass gear cogs in slot cars way back when. You could get the gears meshing so smoothly that they were nearly silent. The noise from the raw gear teeth was energy lost. The quieter gears allowed more power to go to the wheels.
There are still mild abrasives in tooth paste. The harsh abrasives were removed way back in the '60s.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to TexasSkyPilot)
       Post #: 23004
RE: Welcome to Club SAITO ! - 10/8/2012 8:19 PM
byjoe
Score: 100
Last Login: 5/1/2013
Status: offline
I have a Saito FA 30 4c that has open rocker arms.Trying to find out how old it is . .It looks like it may be one of their first 4c engines.
Hide Signatures
(in reply to SigMan)
       Post #: 23005
RE: Welcome to Club SAITO ! - 10/8/2012 8:53 PM
TexasSkyPilot
Score: 438
Status: offline
Sr Telemaster 150,
My brother lives about ten minutes from you, in Potsdam. Nice spot to live.
~ Jim ~
Hide Signatures
       Post #: 23006
RE: Welcome to Club SAITO ! - 10/8/2012 11:56 PM
SrTelemaster150
Score: 227
Status: online
Sr Telemaster 150,
~ Jim ~
Does he fly R/C?
Potsdam is more like 20 minutes away, 18 miles.
Hide Signatures
       Post #: 23007
RE: Welcome to Club SAITO ! - 10/9/2012 12:06 AM
TexasSkyPilot
Score: 438
Status: offline
I haven't seen any buildup on any Saito seats I ever had. I had a couple of valves lock up during one winter when I forgot to use after-run oil late in the fall.
They weren't frozen, so much as sticky. I put after-run oil in and worked them for a while. I'm sure some scale had developed over the winter. Fortunately, no lasting effects.
Compared to auto and motorcycle heads, the Saitos I work on are always pristine in comparison. I suppose a lot depends upon the conditions under which it was run. Cowled in without a lot of air, running hot for that reason or some other reason. The glows can get buildup from heat, that's for sure.
I'm all but out of the Saito club these days. One .72a, in my little Sig Sundancer Bipe. Powerful for a small 4-stroke!
I've gone to gassers for the rest. But my flying buddies will see to it that I still get to work on plenty of them! Phil brought a radial over the other day to troubleshoot. Once we took that dust cover off the venturi, it ran pretty good!
~ Jim ~
Hide Signatures
       Post #: 23008
RE: Welcome to Club SAITO ! - 10/9/2012 12:28 AM
TexasSkyPilot
Score: 438
Status: offline
No, he's a sports nut and does it from his armchair.
He works at the college there.
~ Jim ~
Hide Signatures
       Post #: 23009
RE: Welcome to Club SAITO ! - 10/9/2012 1:20 AM
rowdyjoe
Score: 105
Last Login: 5/18/2013
Status: offline
I want to put new bearings in my FA-80GK but, Boca offers 5 different types.  Which one do you guys recommend?
SAITO - FA-80, 80 Econo Power RC Engine Bearings
SAITO - FA-80, 80 High Performance RC Engine Bearings
SAITO - FA-80, 80 Stainless Steel RC Engine Bearings
SAITO - FA-80, 80 Ceramic Lightning Performance RC Engine Bearings
SAITO - FA-80, 80 Ceramic High Performance RC Engine Bearings
RJ
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 23010
RE: Welcome to Club SAITO ! - 10/9/2012 1:28 AM
alan0899
Score: 100
Last Login: 5/12/2013
Status: offline
G'day RJ,
I always prefer Stainless bearings, a lot less rust to worry about, & I know someone will disagree,
but with a 4 stroke, the revs are a lot less than a 2 stroke, so high performance is not an issue.
Just my 2 cents worth.
Cheers
Good Flyin Mate. Keep Thyne Airspeed up, lest the ground arise & smite thee,
Allan.
Hide Signatures
(in reply to rowdyjoe)
       Post #: 23011
RE: Welcome to Club SAITO ! - 10/9/2012 1:29 AM
barry wetherell
Score: 100
Status: offline
Rowdyjoe, ...I look at these factors ; 1 - how much am I going to use that engine
2 - what size model am I going to put it in
the econo bearings are ok, I have them in several engines, and at the other end of the scale, I dont believe there is anything gained from using the most expensive ones, so it really is a matter of choice
A.A. Barry
everyday you wake up is a good day
Hide Signatures
       Post #: 23012
RE: Welcome to Club SAITO ! - 10/9/2012 3:28 AM
rowdyjoe
Score: 105
Status: offline
Thanks guys. I went with the stainless bearings.  I figure they will outlast me and the plane.
RJ
Rowdyjoe
Saito 783
Hide Signatures
(in reply to barry wetherell)
       Post #: 23013
RE: Welcome to Club SAITO ! - 10/9/2012 4:33 AM
Ernie Misner
Score: 130
Status: offline
Just curious, I haven't heard of anyone ordering from RC Bearings lately. Aren't these FA 80 prices considerably cheaper?
http://www.rcbearings.com/saito-80-bearings/ Ask for Paul
Thanks, Ernie
Hide Signatures
       Post #: 23014
RE: Welcome to Club SAITO ! - 10/9/2012 4:48 AM
rowdyjoe
Score: 105
Status: offline
Ernie,
     Wasn't aware of RC Bearings until now.  Everyone recommends Boca so, that's where I bought mine.
Yes, the price does appear to be much cheaper at RC Bearings.  Assuming the quality is the same, it's a deal you can't refuse ....about 1/2 price.
RJ
Rowdyjoe
Saito 783
Hide Signatures
(in reply to Ernie Misner)
       Post #: 23015
RE: Welcome to Club SAITO ! - 10/9/2012 4:50 AM
Ernie Misner
Score: 130
Status: offline
Well keep Paul in mind. He used to be more active here at RCU but is keeping a lower profile now I guess. The bearings should be the same quality, ... hey ask Paul!
Hide Signatures
       Post #: 23016
RE: Welcome to Club SAITO ! - 10/9/2012 7:40 AM
frets24
Score: 148
Status: offline
Paul is just busy lately, it seems. Uptick in business? I still get promotional emails on a regular basis. Great people there at RCB and the bearings are all from high end, quality MFG's.
I like the SS bearings with the open phenolic cages...no worries on corrosion or pitting to slow them up and plenty of open space for the lube to get everywhere it needs to easily.
Club Saito #770
"The American taxpayer has always been politicaly deceived. Its their Birthright!"
Lord Mountjoy, The Mouse on the Moon
Hide Signatures
       Post #: 23017
RE: Welcome to Club SAITO ! - 10/9/2012 1:35 PM
Old Fart
Score: 158
Status: offline
You guys have got me worried,heaps of other folks too i'm bettin.Who says bearing quality beats how carefully you fit them?
Watch out for the ground eh?
Hide Signatures
(in reply to frets24)
       Post #: 23018
RE: Welcome to Club SAITO ! - 10/9/2012 5:18 PM
Frank Schwartz
Score: 100
Status: offline
Well, I only have a couple of Saitos, but found them to be superior engines. Some many years ago when they first came out with the .30 with exposed rockers, I bought one and put it in a swizzle stick and used it as a trainer. I ran it on stock 10% fuel which had some castor in it. I ran it many many hours. Finally I fouind the valve stems so worn that they looked like they would break if you touched one. I had to buy a complete head which had the valves etc in it as a unit.
When I took the engine down, it was clean inside and when I reassembled it with the new head/valves the compression was as new...I could not find any wear in the sleeve or piston....don't know what they used but that baby had many hours of running and still was as tight as new....
They make one fine and long lasting engine....the best!!!! I have an 80 of theirs in a Bruce Tharp Flyin' King and it pulls it with authority....
Regards to all,
Frank Schwartz AMA123
87 years young and still building and flying...........happiness, for sure.....
Frank Schwartz
Hide Signatures
(in reply to balsa brain)
       Post #: 23019
RE: Welcome to Club SAITO ! - 10/9/2012 5:38 PM
JNorton
Score: 149
Status: offline
You have to fit them carefully no matter what type of bearing you use. Ceramics are especially fussy when it come to installation. I like standard high performance steel bearings myself. I believe SS is softer than normal steels. Just my two cents.
John
Have desk ... Will Fly.... Saito Member #467
Ultimate Brotherhood #11, Ultra Sport Brotherhood #90
Hide Signatures
(in reply to Old Fart)
       Post #: 23020
RE: Welcome to Club SAITO ! - 10/9/2012 5:53 PM
blw
Score: 655
Status: online
Frank, we had a crazy club member who had a red Flying King and the 80 pulled it with stump pulling authority. I saw several dozen imminent crashes saved literally at the last second only by the sheer grunt power of the 80.
I also saw that this Flying King would fly perfectly fine with all of the covering peeled back from the whole fuselage side. Flapping back in the breeze like a streamer. Flight after flight.
Coach Pat Dye
Hide Signatures
(in reply to JNorton)
       Post #: 23021
RE: Welcome to Club SAITO ! - 10/9/2012 7:11 PM
lopflyers
Score: 140
Status: offline
What!!! , you are 87 and your AMA # is 123? I admire you and wish I will still be flying at that tender age. Keep it up sir.
Keep your wings level
Club Saito Member #693
Hide Signatures
(in reply to blw)
       Post #: 23022
RE: Welcome to Club SAITO ! - 10/9/2012 10:00 PM
rowdyjoe
Score: 105
Status: offline
Stainless is harder but, more brittle than other steel alloys.  I went with stainless to reduce the chance of corrosion.
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 23023
RE: Welcome to Club SAITO ! - 10/9/2012 10:09 PM
rowdyjoe
Score: 105
Status: offline
I ordered a gasket kit and a few other small items from Advantage Hobby.  They had everything I needed at a better price than Horizon and they are Saito parts ...not after-market.  I've called my experienced friend who has rebuilt many, many glow engines and he agreed to help me with my FA-80GK.  We'll do the deed as soon as the parts arrive.
OOOPs ....almost forgot to mention the results of the carb kit installation.  The engine is running much better now but, still haven't found the sweet spot.  I haven't been able to get the idle below 2400 and the max rpm is around 9100 with a 13x6 prop.  However, it's not running a steady rpm at full throttle.  It will vary by as much as 200 to 300 rpm when peaked. Before installing the kit, I saw as much as 10k rpm at full throttle with the same size prop.
Any ideas or opinions on what may be causing this variation at full throttle?
I'm getting a good transition now where I couldn't get one at all before.  I need to get the low end and high end tuned now.
Rowdyjoe
Saito 783
Hide Signatures
(in reply to lopflyers)
       Post #: 23024
RE: Welcome to Club SAITO ! - 10/10/2012 12:50 AM  1 votes
SrTelemaster150
Score: 227
Status: online
quote:
ORIGINAL: JNorton
John
quote:
ORIGINAL: rowdyjoe
JNorton was right. SS is softer than carbon steel, but it is tougher. It resists corrosion & in rifle barrels, it also resists errosion in the throat from hot gasses. It can also be harder to machine.
High carbon steel is harder & more brittle than SS. I much prefer high carbon steel to SS if knife blades. SS is harder to get a good edge on & it doesn't stay sharp as long . When corrosion is an issue, like razor blades, SS cutting edges last longer.
Hide Signatures
       Post #: 23025
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
4.734RCU1
