RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
Users viewing this topic: KenD, SrTelemaster150, AeroFinn, smkrcflyer, JohnB96041
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  924 925 [926] 927 928 929 930 931 932 933   next >   >>
Login
RE: Welcome to Club SAITO ! - 10/15/2012 12:06 PM
SrTelemaster150
Score: 229
Last Login: 5/20/2013
Status: online
quote:
ORIGINAL: jkr_1100
quote:
ORIGINAL: SrTelemaster150
quote:
ORIGINAL: Hobbsy
I have about 250 various Saito picture and was looking for a picture of the ''fire hose nozzle'' muffler that came with my 1.50. I may have deleted the picture since I only run a TurboHeader on it now. I
What the heck does a ''fire hose nozzle muffler'' look like?
It is my favorite kind. this one has a few dents and needs a nipple repaired, thats what happens when they get older. Right Old Fart?
Ahah! That's the muffler that was on my 1st 150.
It vibrated loose in mid flight over standing corn & was never seen (or heard from) again.
_____________________________
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to jkr_1100)
       Post #: 23126
RE: Welcome to Club SAITO ! - 10/15/2012 6:53 PM
airborne14830
Score: 100
Last Login: 4/1/2013
Status: offline
has anyone attached a perry fuel pump to an sa100? I attached it per the diagram, and my question is did you have to do a lot of adjustment to the pump to get hte right pressure?
airborne crazy
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 23127
RE: Welcome to Club SAITO ! - 10/15/2012 8:12 PM
SrTelemaster150
Score: 229
Status: online
quote:
ORIGINAL: airborne14830
I run one of the ocsilatimg Perry pumps on an FA150 because the tank is remotely located over the CG.
Are you talking about the ocsilating pump or the 1 that operates from engine crankcase pulse?
Hide Signatures
(in reply to airborne14830)
       Post #: 23128
RE: Welcome to Club SAITO ! - 10/15/2012 11:56 PM
Old Fart
Score: 158
Status: offline
quote:
ORIGINAL: jkr_1100
just finished reading it all, 23,120 posts, 925 pages.
I now know what the reward is. - being able to contribute and reply as part of the current discussion.
I was taking my 5 year old daughter to school, she is in Kindergarten at a Lutheran church here, on the wall is a baptismal chart listing names. one caught my eye. William L. Robison
Cheers.
Nice post jkr.I've saved that picture of the apple sauce?? undercarriage wheel,it's funny.Hows the prop torque?
Watch out for the ground eh?
Hide Signatures
       Post #: 23129
RE: Welcome to Club SAITO ! - 10/16/2012 12:56 AM
jkr_1100
Score: 105
Last Login: 5/7/2013
Status: offline
quote:
ORIGINAL: Old Fart
quote:
ORIGINAL: jkr_1100
Cheers.
well you stick a rod in the hole on the prop nut. then hold the prop and twist like h3LL
AMA 414878 - Cub brotherhood - Tiger Club #1
Club Saito #789 - 50,91,125,125,150S,180
Hide Signatures
(in reply to Old Fart)
       Post #: 23130
RE: Welcome to Club SAITO ! - 10/16/2012 3:32 AM
captinjohn
Score: 247
Status: offline
Club Saito....I love them all !     Capt,n
I never met a engine I did not like !
Hide Signatures
       Post #: 23131
RE: Welcome to Club SAITO ! - 10/16/2012 4:36 AM
Cougar429
Score: 128
Last Login: 5/17/2013
Status: offline
Are you running the VP-20 shaker or -30 pulse pump? If you have the -20 you need to have it mounted horizontal.
Club Saito Member # 787
FA91, 100, 2 X 125a, 150
Hide Signatures
       Post #: 23132
RE: Welcome to Club SAITO ! - 10/16/2012 6:28 AM
Vyciukas3045
Score: 100
Last Login: 3/21/2013
Status: offline
Which version of 270 twin is of a newer design - the one with intake and exhaust ports looking back and carb on the back?
What are other design and technical differences between these two?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Cougar429)
       Post #: 23133
RE: Welcome to Club SAITO ! - 10/16/2012 12:50 PM
Old Fart
Score: 158
Status: offline
If he's running the shaker you should have tuned the engine by now and then add the pump.Reason being is the pump is just run at slight pressure when you move the tank back,it's an aid not a bandaid for tuning problems you may already have.They are very reliable too.
Hide Signatures
       Post #: 23134
RE: Welcome to Club SAITO ! - 10/16/2012 3:31 PM
SrTelemaster150
Score: 229
Status: online
quote:
ORIGINAL: Old Fart
I still use the muffler tap pressure W/the pump adjustment turned in so there is, as you say, slight pressure.
I have used that set-up for many flights in my 89" Dyynaflite PT-19. I never had any issues W/fuel delivery.
The fuel tank is centered above the CG. The C&H ignition module & battery for same is located in the compartment behind the engine. Locating the tank over the CG not only made room for these components, the CG never changes W/the amount of fuel in the tank. It also makes access to the tank fittings & fuel lines easier to access.
All the pump does is maintain a consistant fuel delivery to the carburetor. The muffler tap pressure is pushing the fuel, the oscelating pump pulling.
< Message edited by SrTelemaster150 -- 10/17/2012 1:03 AM >
Hide Signatures
       Post #: 23135
RE: Welcome to Club SAITO ! - 10/16/2012 3:33 PM
SrTelemaster150
Score: 229
Status: online
quote:
ORIGINAL: Vyciukas3045
The 1st question you answered yourself. They still use that configuration on the FA300T that replaced the 270.
I was never aware of the other type FA270T.
From the looks of the pictures, it seems like the only difference would be the cylinders as well as the intake manifold. The cam housings on both are the newer high case style.
Hide Signatures
(in reply to Vyciukas3045)
       Post #: 23136
RE: Welcome to Club SAITO ! - 10/16/2012 5:38 PM
mike early
Score: 125
Last Login: 5/19/2013
Status: offline
Anyone have that Saito 57cc Twin?
Is it as sweet as I have to assume it must be?
How wonderful would it be in the 50cc Revolver? Very wonderful? I agree.
Saito Club Member #578
P-40 Brotherhood #62
Hide Signatures
(in reply to balsa brain)
       Post #: 23137
RE: Welcome to Club SAITO ! - 10/16/2012 7:06 PM
airborne14830
Score: 100
Status: offline
Mine is a Perry VP-30 that runs from the crankcase.
airborne crazy
Hide Signatures
(in reply to mike early)
       Post #: 23138
RE: Welcome to Club SAITO ! - 10/16/2012 7:47 PM
SrTelemaster150
Score: 229
Status: online
quote:
ORIGINAL: mike early
There is A THREAD DIDICATED TO THE FG57 over on the gas engine forum.
< Message edited by SrTelemaster150 -- 10/16/2012 8:45 PM >
Hide Signatures
       Post #: 23139
RE: Welcome to Club SAITO ! - 10/16/2012 7:50 PM
swify
Score: 100
Status: offline
I have a saito 90 TS twin i bought a while back, was looking at taking out the glo plugs but my wrench doesn't fit too in the head too well, was using an OS long reach glo plug wrench. Is there some sort of special plug wrench for saito engines?
Hide Signatures
       Post #: 23140
RE: Welcome to Club SAITO ! - 10/16/2012 8:44 PM
SrTelemaster150
Score: 229
Status: online
quote:
ORIGINAL: swify
A thin wall 1/4" drive 5/16" or 8MM socket will get in where a glow plug wrench won't.
Hide Signatures
(in reply to swify)
       Post #: 23141
RE: Welcome to Club SAITO ! - 10/16/2012 11:37 PM
Hobbsy
Score: 650
Status: offline
I use the Fox four way plug wrench, it also has 3/8, 7/16 and .5".
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
       Post #: 23142
RE: Welcome to Club SAITO ! - 10/17/2012 12:52 AM
DougB1
Score: 112
Status: offline
This afternoon I flew the Satio 180 on 5% fuel ( it's all I had, ran out of 15% ) that is in mt 150 size Hanger 9 P-51 It has an 18x6 Vess prop on it and turned 8045 rpm's ( the sweet spot ) not to rich and not to lean. Does this sound like a good rpm for this motor with the 18x6 prop on it ?
DougB1
Hide Signatures
(in reply to Hobbsy)
       Post #: 23143
RE: Welcome to Club SAITO ! - 10/17/2012 4:34 AM
Longtooth
Score: 100
Last Login: 1/19/2013
Status: offline
  Original FA-270T had an M-8X1.25 thread and Roll Pins on the Prop Shaft, and leatherette washers for the Prop Hub.
It  had a Muffler (with two straight parallel exhaust pipes) connected with flange nuts to the L-shaped exhaust pipes from the cylinders,
and two small tubes on the bottom (one for pressure, one for smoke). It also had two breather nipples on the bottom of the Case.
 The Intake Pipes were on the sides of the cylinders, and the X-shaped Engine Mount was about 10mm thick.
  Later version (mine is MK II with production code A embossed on the bottom of the Case near the backplate) has a 10-32 threaded shaft,
roll pins and leatherette washers, no muffler, two longer exhaust pipes (clamped together) with the two smaller tubes on one pipe, only one
breather nipple on the bottom of the case 30mm behind the Prop Hub, and the Engine Mount is only 3mm thick.
  Both of these have choke slide plates on the Carburetor, but no Velocity Stack or round Engine Mounts.
  Note: The Roll Pins on your Prop Hub appear to be bent (as mine were).  Take great care in removing them - lateral pressure on the Hub can
cause it to bind on the Shaft (as mine did).
  Note 2: On all engines not being used (no Prop on the Shaft), I use tubing between Hub and Washer to prevent loss of Woodruff Key.
Hide Signatures
       Post #: 23144
RE: Welcome to Club SAITO ! - 10/17/2012 5:04 AM
Ernie Misner
Score: 130
Status: offline
About what year would that have been with the leatherette prop hub washer? That is interesting.
Hide Signatures
(in reply to Longtooth)
       Post #: 23145
RE: Welcome to Club SAITO ! - 10/17/2012 11:08 AM
SrTelemaster150
Score: 229
Status: online
quote:
ORIGINAL: Ernie Misner
My FA300TTDP purchased in 1997 also had the leatherette prop hub washers.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 23146
RE: Welcome to Club SAITO ! - 10/17/2012 6:30 PM
kenh3497
Score: 115
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: kenh3497
quote:
ORIGINAL: Hobbsy
Ken, does it have a letter designator on the right lug, that will come closer to telling you when it was made. My very first gen 1.50 has no letter on the right lug nor does my first gen .80.
It has a letter ''F'' on the lug.
My search has turned up nothing. So where do i go to find out the age of my 120.
Ken
Sent from my Dry-Erase-Board
Hide Signatures
(in reply to kenh3497)
       Post #: 23147
RE: Welcome to Club SAITO ! - 10/17/2012 11:55 PM
Hobbsy
Score: 650
Status: offline
Do you know what color of box it came in, this .65 is an 80s engine, the .65 is later, maybe late 90s.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 23148
RE: Welcome to Club SAITO ! - 10/18/2012 2:35 AM
jkr_1100
Score: 105
Status: offline
quote:
ORIGINAL: Hobbsy
have you ever run that .65? that looks NIB
Hide Signatures
       Post #: 23149
RE: Welcome to Club SAITO ! - 10/18/2012 2:49 AM
Hobbsy
Score: 650
Status: offline
Yes, it is just broken in and now resides on an Alpha 60 that used to wear a Saito 1.00.
Click for fullsize
Hide Signatures
       Post #: 23150
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.189RCU1
