RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
Users viewing this topic: Old Fart, tkline
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  931 932 [933] 934 935 936 937 938 939 940   next >   >>
Login
RE: Welcome to Club SAITO ! - 11/6/2012 11:24 PM
blw
Score: 655
Last Login: 5/23/2013
Status: offline
Mike,
If you have to use the plastic backplate there are a few things that decrease or eliminate the problem. First, use flat washers under the screws to spread the load. The plastic compresses and deforms quite a bit. Next, use thread locker in the crankcase screw threads. And, put a good bead of rtv under and around the metal washer at the manifold intake.
Mine ran great with those 'fixes'.
_____________________________
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to FNQFLYER)
       Post #: 23301
RE: Welcome to Club SAITO ! - 11/6/2012 11:32 PM
Ernie Misner
Score: 130
Last Login: 5/22/2013
Status: offline
High temp, red RTV would probably be best.
Hide Signatures
(in reply to blw)
       Post #: 23302
RE: Welcome to Club SAITO ! - 11/6/2012 11:42 PM
FNQFLYER
Score: 110
Status: offline
High temp (red ) RTV or SQ 32 (also known as Hylomar) is also good.  The later was developed by Rolls Royce as a case sealent for the Dart engine compressor to turbine split.  Aslo very good on fuel lines (disolves in any known fuel that we use) and I used it on head gaskets (and rocker cover gaskets) on heaps of cars over the years.
Club Saito member 710
Hide Signatures
(in reply to Ernie Misner)
       Post #: 23303
RE: Welcome to Club SAITO ! - 11/7/2012 12:18 AM
tarcure
Score: 100
Status: offline
 Thank you all for the input. Simply fantastic. I am going to order the metal back plate tomorrow. But, a few questions remain.
1. Does the carb upgrade kit help? What's different from stock?
2. Do I need a gasket with the metal plate?
3. Previous post says to replace carb screws with those from a 92 - why?
Again, thank you all.
Hide Signatures
       Post #: 23304
RE: Welcome to Club SAITO ! - 11/7/2012 2:00 AM
Cougar429
Score: 128
Status: offline
blw, your recommendation for Loctite on any fasteners into metal components is good, but I have a couple of concerns when the casting is alloy.
First is to use a low strength as anything more aggressive is not necessary and can tend to damage the threads upon removal. On that note, unless the threads are cleaned out with a tap before reinstallation the remaining old Loctite can cause more problems.
Secondly, Loctite and plastic do not mix, so unless there is some way to prevent the two coming together during installation, the disadvantages may outweigh using it in the first place.
I have been rebuilding and resurrecting engines for a LONG time now and rarely ever find the need for thread lock. I only had the exhaust adapter come loose once on my 91, and once I shaved a wrench to provide better access when tightening it never happened again.
On that note, one thing I found with engines I grab was that in some cases it was thought Loctite a substitute for worn or partially stripped threads. This is not a good, long-term solution. In those cases I would look at moving to the next larger fastener, even if standard size. If done properly it would return the fastener to full strength.
Club Saito Member # 787
FA91, 100, 2 X 125a, 150
Hide Signatures
       Post #: 23305
RE: Welcome to Club SAITO ! - 11/7/2012 2:09 AM
blw
Score: 655
Status: offline
Some Saitos ship with a thread lock of some kind. 2 new style plastic backplates deformed quickly for me. The screws loosened in mere minutes every time. I cleaned the screws and threads and swabbed the crankcase threads with epoxy, and let it dry. That ended problems for good. I know what you mean about resorting to other ways first. I rarely use anything.
Coach Pat Dye
Hide Signatures
(in reply to Cougar429)
       Post #: 23306
RE: Welcome to Club SAITO ! - 11/7/2012 4:56 AM
Ernie Misner
Score: 130
Status: offline
I don't think there is a gasket for the Saito backplates. You may get some oil slowly weeping out in some areas after you use lots of ARO but it doesn't hurt anything. The crankcase is vented anyway which wouldn't be good at all on a 2-stroke. Note that your 2 carb screws will have to be a different type from what is used on the plastic back plate, a metric thread like was mentioned earlier.
Hide Signatures
(in reply to blw)
       Post #: 23307
RE: Welcome to Club SAITO ! - 11/7/2012 5:30 AM
the pope
Score: 101
Status: offline
quote:
ORIGINAL: tarcure
1.I think the carb screws. 2. yes and u can make your own if you want or use high temp silicon ( i havent done this but think it would be o.k as long as the back plate dosent hit on anything eg the conrod . Perhaps a gaskit would be best now that I think of it .) . 3. The original screws have a thread that screws into plastic instead of metal threads . Cheers the pope
Hide Signatures
(in reply to tarcure)
       Post #: 23308
RE: Welcome to Club SAITO ! - 11/7/2012 5:35 AM
the pope
Score: 101
Status: offline
quote:
ORIGINAL: Ernie Misner
Hi Ernie the 82b has a gasket on the backplate but not the a version . No gasket on the jugs . Cheers the pope
Hide Signatures
       Post #: 23309
RE: Welcome to Club SAITO ! - 11/7/2012 1:01 PM
mike early
Score: 125
Last Login: 5/19/2013
Status: offline
Did we agree that the Carb Upgrade Kit is for engines made more than 7 years ago?
Saito Club Member #578
P-40 Brotherhood #62
Hide Signatures
(in reply to the pope)
       Post #: 23310
RE: Welcome to Club SAITO ! - 11/9/2012 2:16 PM
mike early
Score: 125
Status: offline
I am getting ready to change bearings on a Saito 100Twin that has been sitting for a few years.
I have changed lots of bearings on single cylinder Saitos.
Any tips or things to look out for on my first twin surgery?
Hide Signatures
(in reply to mike early)
       Post #: 23311
RE: Welcome to Club SAITO ! - 11/10/2012 1:52 PM
Hobbsy
Score: 650
Status: online
Saito gents, I am thinking of doing a comparo between the Saito .62 and a new Saito .65, both are just past broken in. There is a difference in the recommended props, the .62s recommended prop is a 13x6 APC at 9,900 and the .65s recommended prop is an 11x7.75", no specified rpm. As to whether this is worth doing is up in the air. Maybe somone is interested how well the .62 replaces the .65. I'm gonna find out with stock exhaust and with a TurboHeader.
< Message edited by Hobbsy -- 11/10/2012 3:39 PM >
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
       Post #: 23312
RE: Welcome to Club SAITO ! - 11/10/2012 2:58 PM
Quikturn
Score: 118
Status: online
Hobbsy,
I would be interested in what you find out in terms of power. I have a Saito 65 on a Kyosho P-40. I like it very much but it is a heavier design. My understanding is the 62 has the same power but much lighter.
Ultrasport Brotherhood #45
P-40 Brotherhood #35
Hide Signatures
(in reply to Hobbsy)
       Post #: 23313
RE: Welcome to Club SAITO ! - 11/10/2012 3:21 PM
Charley
Score: 100
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: Hobbsy
Saito gents, I am thing of doing a comparo between the Saito .62 and a new Saito .65, both are just past broken in. There is a difference in the recommended props, the .62s recommended prop is a 13x6 APC at 9,900 and the .65s recommended prop is an 11x7.75'', no specified rpm. As to whether this is worth doing is up in the air. Maybe somone is interested how well the .62 replaces the .65. I'm gonna find out with stock exhaust and with a TurboHeader.
The .62 is more oversquare (higher bore/stroke ratio) than the .65 so you'd expect it to produce its max HP at higher RPM, hence less pitch for some applications. Doesn't look like one is a direct replacement for the other. Here's a Saito small-medium engine manual, containing all the dope: http://www.horizonhobby.com/pdf/SAITO_Small-Medium_single_cylinder_Manual.pdf
CR
Charley
ccrobins@ktc.com
Hide Signatures
       Post #: 23314
RE: Welcome to Club SAITO ! - 11/10/2012 5:53 PM
Hobbsy
Score: 650
Status: online
OK, I should have predicted these results, that way folks would think I am a deviner of sorts.
Fuel for both engines===WildCat 15% Premium Extra
Prop for both============= APC 13x6
Saito .65/stock muffler, rpm====9,800, rpm/TurboHeader==10,000
Saito .62/stock muffler, rpm====9,780, rpm/TurboHeader===9,990
My assumption is that Horizon got their 9,900 rpm for the .62 using 30% fuel, that seems to be their standard.
The .65 wore an Enya A-3 plug
The .62 wore a Fox Miracle
Hide Signatures
(in reply to Charley)
       Post #: 23315
RE: Welcome to Club SAITO ! - 11/11/2012 6:43 AM
jeffie8696
Score: 120
Last Login: 5/15/2013
Status: offline
Any word on parts availablity? I see several parts I need are backordered, maybe problems at the factory? They did have a major event in that country after all.
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
       Post #: 23316
RE: Welcome to Club SAITO ! - 11/11/2012 8:12 AM
w8ye
Score: 318
Status: offline
You need to get on the band wagon with those back ordered parts.
Horizon doesn't figure their economic order quantities realistically.
You could possibly see the part remain on back order through several cycles.
For people who are on the back order list get their parts in the sequence purchased. Often the supply is depleated before all the back orders are filled.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to jeffie8696)
       Post #: 23317
RE: Welcome to Club SAITO ! - 11/11/2012 8:24 AM
w8ye
Score: 318
Status: offline
The Saito 62 is my favorite engine. I run a 13 X 6 APC prop.
I have two Golden Knights. One is still new in box. The one I use all the time was purchased in the RCU market place from a gentleman who could not keep the exhaust pipe from breaking. I put it on a plane and didn't do anything to it - not even adjust the needle valve.  Low and behold, the next spring, I got trash in the needle valve and had to remove the needle to flush the system. But for the next three years, it has been trouble free,
The 62 is the largest of the small block engines that evolved in the 40, 45, 50, 56, & 62 sizes. However, the 62 has the bigger rear bearing from the 72 and the bigger cam that is in the 65 through 125 engines.
The 62 reaches a good compromise between power and fuel economy. It fits in the 40 size planes and makes them really perform.
Original AMA #31261
Hide Signatures
(in reply to w8ye)
       Post #: 23318
RE: Welcome to Club SAITO ! - 11/11/2012 12:31 PM
Hobbsy
Score: 650
Status: online
The .62 will idle slower than the .65, that could be attributed to the fact that the .65 still has the pre-upgrade spraybar in it.
Hide Signatures
(in reply to w8ye)
       Post #: 23319
RE: Welcome to Club SAITO ! - 11/11/2012 3:29 PM
Quikturn
Score: 118
Status: online
I upgraded my 65 with the new spraybar but haven't noticed a lower idle. It only has about 1 gallon through it however.
Hide Signatures
       Post #: 23320
RE: Welcome to Club SAITO ! - 11/11/2012 5:05 PM
jeffie8696
Score: 120
Status: offline
My 62 is going on the front of my Epade, I have a pair of skis ordered . I took off the Magnum 52 RFS which pulled it along pretty well. So far I have a 45, 50 and 62 to play with. Too bad my 45 broke one of the valve adjusters yesterday and cant get the parts.
Hide Signatures
(in reply to Quikturn)
       Post #: 23321
RE: Welcome to Club SAITO ! - 11/11/2012 10:28 PM
mike early
Score: 125
Status: offline
I have read through a few 100T threads on RCU posted over several years.
Am trying to reach a consensus on the Air Pump Assembly and its value.
Seems some people have had a lot of problems with the 100T and lubrication...
I have the Air Pump Assembly on this 100T. I am getting ready to order bearings was wondering if I should order a new cam cover to remove the Air Pump altogether.
W8ye, I read where you stated that the Saito Twin manual is incorrect on the cam timing of the 100T. Have they fixed it over the years?
Hide Signatures
       Post #: 23322
RE: Welcome to Club SAITO ! - 11/11/2012 10:45 PM
AJsToyz
Score: 304
Status: offline
Has any one tried a 11x8 MA or Graupner on a 72? Trying to keep the prop size down for clearance .
Andy
www.Deathbychina.com
Hide Signatures
       Post #: 23323
RE: Welcome to Club SAITO ! - 11/11/2012 11:32 PM
jeffie8696
Score: 120
Status: offline
You could run a 3 blade
Hide Signatures
(in reply to AJsToyz)
       Post #: 23324
RE: Welcome to Club SAITO ! - 11/11/2012 11:38 PM
Garthwood
Score: 100
Last Login: 5/12/2013
Status: offline
BLW........................Forgot what my member's number is.
Charles.
WACO Brotherhood # 87
Carl Goldberg Ultimate 10-300 Brotherhood # 61
Hide Signatures
(in reply to blw)
       Post #: 23325
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.500RCU1
