RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  940 941 [942] 943 944 945 946 947 948 949   next >   >>
Login
RE: Welcome to Club SAITO ! - 12/15/2012 2:42 AM
Old Fart
Score: 158
Last Login: 5/20/2013
Status: offline
Was going to say nope but i think the carpet is axminster then i changed my mind
Dave have you ever recorded the temp difference between those rocker covers and the standard ones at the head?
_____________________________
Watch out for the ground eh?
Hide Signatures
(in reply to Hobbsy)
       Post #: 23526
RE: Welcome to Club SAITO ! - 12/15/2012 2:01 PM  1 votes
Hobbsy
Score: 650
Last Login: 5/21/2013
Status: offline
Thanks Jim, where you been bro?
OF, I don't fool around with checking temperatures, to me that is a total waste of time.
Gunny, my Dad tried a Poly Choke once on a Remington shot gun. He soon realised that it was a waste of money and the barrel was ruined when they cut a couple of inches off of it.
Saitos are so straight forward that very few gadgets and gizmos effect them, the TurboHeader is one that is a worthwhile addition. This velocity stack I made to replace the intake horn I chopped off to clear the firewall on a RCM 40 did notheing for performance, it did not change the performance either.
Click to see fullsize image.
Click for fullsize
Click for fullsize
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to Old Fart)
       Post #: 23527
RE: Welcome to Club SAITO ! - 12/15/2012 3:09 PM
greatlakesgunny
Score: 100
Last Login: 4/12/2013
Status: offline
Ah yes the good ol polychoke, sometimes I think it was a decent idea, then I wake up....
Hide Signatures
       Post #: 23528
RE: Welcome to Club SAITO ! - 12/15/2012 3:16 PM  1 votes
Hobbsy
Score: 650
Status: offline
This idea didn't work eithe, nor did moving the crankcase vent to the cam cover. I guess that makes it an idea whose time never came.
Click for fullsize
Hide Signatures
(in reply to greatlakesgunny)
       Post #: 23529
RE: Welcome to Club SAITO ! - 12/15/2012 4:13 PM  1 votes
blw
Score: 655
Status: offline
Gunny, you are on to something.
You only put bayonets, bigger clips, and scopes on guns. (slings count as being part of the rifle)
You only put velocity stacks and turboheaders on Saitos. And props.
You can put girls on motorcycles, but only on the back of them. No windscreens, saddlebags, extra lights, etc.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
       Post #: 23530
RE: Welcome to Club SAITO ! - 12/15/2012 4:55 PM
earlwb
Score: 584
Status: offline
Hobbsy, yeah that crankcase vent on the cambox looks good. But it may or may not work as expected.  But that fitting is a good idea, as you can use it to squirt some oil into the cambox from time to time.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to blw)
       Post #: 23531
RE: Welcome to Club SAITO ! - 12/16/2012 1:21 AM
Old Fart
Score: 158
Status: offline
Well those finned rocker covers may have the right amount of bling for some,was thinking if they do have a cooling affect i'd fit them to my gas twin to help with exhaust gas temps.Also have a couple of tightly cowled glo saito's that may benefit some.
Hide Signatures
(in reply to earlwb)
       Post #: 23532
RE: Welcome to Club SAITO ! - 12/16/2012 1:55 AM
FNQFLYER
Score: 110
Status: offline
I have been wondering about those "pretty" rocker covers.  One might be moved to do some tests however I think red rocker covers on my competition models would get me laughed of the field and be a demerit point or 2 on the scale jobs with the cylinder hanging in the breeze (out of the cowl)
Club Saito member 710
Hide Signatures
       Post #: 23533
RE: Welcome to Club SAITO ! - 12/16/2012 2:04 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: earlwb
If you put an inlet check in the back cover & an outlet check on the cam case it does a wondefrful job of forcing fresh lube over the main craink bearing & the cam lobes.
A similar system is used on the 300TTDP for fuel pumping as well as the 220 Big Bore Carb.
Even on 15 Cool Power I saw significant throttle response & prop spool up improvents W/the 220 BB Carb W/pump in my FA180HC/CDIBBC engine. It made 3.95HP W/an 18x10 Dynathrust @ 8950RPM burning O'Donnels 30% Speed Blend 8% oil.
Even @ 8% lube the pump forced plenty of oil through the cam housing.
BTW, the (brand name) Poly-Chokes worked OK. They just looked like crap & were supplanted by the screw-in choketubes.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 23534
Old Fart
Score: 158
Status: offline
Yes i'm going to hide mine in the cowl if i can.Hoping somone here has tested them re heat dissipation...sr telemaster??
Hide Signatures
(in reply to FNQFLYER)
       Post #: 23535
RE: Welcome to Club SAITO ! - 12/16/2012 3:36 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Old Fart
I don't think heat dissapation would be significantly changed, but sludge formation should be reduced tremendously by thwe positive exchange of crankcase gases. I still have slight WOTsurge while the fuel level is high & I won't be able to do any more testing for a while.
I had my right knee sawed off last monday for a total replacemnt so right now I'm in the "old folks home" for rehab. Took me 3 days to get imternet clearance, still no youtube or FaceBook!
They said they didn't like my looks & disruptive attitude!
Hide Signatures
       Post #: 23536
RE: Welcome to Club SAITO ! - 12/16/2012 4:29 AM
triumphman49
Score: 110
Status: offline
Did LMAO, Sr,
So sorry to hear of your surgery, and am praying your recouperative powers are as stout as your wit.
Take care & get home for the Holidays.
Merry Xmas
T-man49 in Al
Club Saito 723
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 23537
RE: Welcome to Club SAITO ! - 12/16/2012 6:21 AM
Ernie Misner
Score: 130
Status: offline
Hobbsy, do you get a few more rpm's with the Turbo Header or just the sound? I keep thinking about trying one.
Hide Signatures
       Post #: 23538
RE: Welcome to Club SAITO ! - 12/16/2012 12:47 PM  1 votes
Hobbsy
Score: 650
Status: offline
Ernie, on all the Saitos except for the 1.25 there is a gain of 190 to about 300 rpm depending on which one. For some reason the 1.25 does not respond to the TH. I've said often that the 1.25 is a 9,000 rpm thumper no matter what prop you put on it, within reason of course.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 23539
RE: Welcome to Club SAITO ! - 12/16/2012 1:26 PM
Old Fart
Score: 158
Status: offline
Ernie they are much lighter than the standard saito system,wait till you see the awesome tig welding
Hide Signatures
       Post #: 23540
RE: Welcome to Club SAITO ! - 12/16/2012 1:49 PM  1 votes
blw
Score: 655
Status: offline
Ernie, they sound good too.
Coach Pat Dye
Hide Signatures
       Post #: 23541
RE: Welcome to Club SAITO ! - 12/16/2012 2:18 PM
RC Specialties
Score: 100
Last Login: 5/7/2013
Status: offline
We have many happy customers. "Nothing sounds like a TurboHeader". Thank you for the kind words.
Merry Christmas to all.
Jim
RC Specialties, LLC, Four Stroke Mufflers and 90 Degree Exhaust Adapters
Hide Signatures
(in reply to blw)
       Post #: 23542
RE: Welcome to Club SAITO ! - 12/16/2012 10:07 PM
FNQFLYER
Score: 110
Status: offline
Comment o the mods I have seen lately.
The velocity stacks can improve fuel consumption.  Saitos tend to spit fuel at times, the velocity stack will retain those small amounts (very critical in Texaco events)
The staight line intake.  A measured intake length can improve rpm figures but it has to be very carefully matched to engine.  Has been done here on numerous OS four strokes however the increase isn't worth the effort on a Saito in my opinion.
On these turbo mufflers they look similar to the new mufflers that Saito is fitting to the current crop of engines.  Comments please.
Also in a local magazine it is said Saito is recommending a particular brand and type of oil, Klotz R50 principally for the gas engines but also for the "normal" 4 strokes.  It is a racing synthetic marketed by the local Saito agent (distributor)   Likewise comments please
Hide Signatures
(in reply to RC Specialties)
       Post #: 23543
RE: Welcome to Club SAITO ! - 12/16/2012 10:19 PM
108buzz
Score: 105
Status: offline
I have a new saito FG17 and I am having problems with it.  It runs for about five minutes then quits running.  I have sent it back twice, but Horizon says it bench tests fine.  I am running it inverted with a 14X7 3 blade MAS and a Keleo exhaust.  They bench test it upright with the stock exhaust and a 2 blade 14x8.  Anyone running this engine with a Keleo exhaust having this problem?  Also I got it back from them and the pickup was loose and could be slide from side to side.  Frustrated with saito as this is my first one.
Hide Signatures
       Post #: 23544
RE: Welcome to Club SAITO ! - 12/16/2012 11:43 PM
cperri
Score: 100
Last Login: 3/30/2013
Status: offline
saito motor are awesome....i fly 3 of them two 91's and a 100....and i'm in the market for another if anyone has a 72....80....it would of great help...thank you.....long live saito.....
Hide Signatures
(in reply to William Robison)
       Post #: 23545
RE: Welcome to Club SAITO ! - 12/16/2012 11:44 PM
mike early
Score: 125
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: cperri
First post: "Love Live Saito" Love it.
Saito Club Member #578
P-40 Brotherhood #62
Hide Signatures
(in reply to cperri)
       Post #: 23546
RE: Welcome to Club SAITO ! - 12/17/2012 1:22 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: 108buzz
Saito & RCEXEL's sensor design is so problem prone compared to the way C&H mounts the components.
In trying to make the set-up "idiot proof" they have merely raised the idiocy bar.
Hide Signatures
(in reply to 108buzz)
       Post #: 23547
RE: Welcome to Club SAITO ! - 12/17/2012 1:31 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: triumphman49
Did LMAO, Sr,
Merry Xmas
T-man49 in Al
Club Saito 723
I'll be down for the winter. I'll probably get home for Christmas, but as soon as I get limited use of the right knee, the left is going under the knife/saw.
In the mean time, I'm livening things up at the nursing home.
Hide Signatures
(in reply to triumphman49)
       Post #: 23548
RE: Welcome to Club SAITO ! - 12/17/2012 1:46 AM  1 votes
Hobbsy
Score: 650
Status: offline
I hope you don't get sentenced to seven months like I did. Keep us posted on the progress. Kick a nurse now and then with your good leg.
Hide Signatures
       Post #: 23549
RE: Welcome to Club SAITO ! - 12/17/2012 2:01 AM
Ernie Misner
Score: 130
Status: offline
Thats it.... gotta get a Turbo Header muffler or two! Thanks guys.
Hide Signatures
       Post #: 23550
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.672RCU1
