RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
Users viewing this topic: Wagon1, KenD, retransit, the pope, TestCrasher, JohnB96041, dynomanca
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  946 947 [948] 949 950 951 952 953 954 955   next >   >>
Login
RE: Welcome to Club SAITO ! - 1/13/2013 11:39 AM
Old Fart
Score: 158
Last Login: 5/20/2013
Status: offline
Hi rye if you smoke rollies grab a paper out and use it,about one and a half thou don't know how you say that in metric.We used to use that method free floating sporting firearm barrels.I know there's plenty of apps around for converting af to metric re thread sizes but everytime you look at the chart it leaves you with a vague headache,man i wish and am going to tool up so i can cut some half decent threads for my saito exhaust systems!!
_____________________________
Watch out for the ground eh?
Hide Signatures
(in reply to rye)
       Post #: 23676
RE: Welcome to Club SAITO ! - 1/13/2013 2:29 PM  1 votes
Hobbsy
Score: 650
Status: offline
http://www.horizonhobby.com/products/56-aac-with-muffler-ii-SAIE056#t4 go about 2/3 the way down the page.
If you pick a set of guages at NAPA make sure it has a .004 inch feeler in it.
Click to see fullsize image.
Click for fullsize
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to rye)
       Post #: 23677
RE: Welcome to Club SAITO ! - 1/13/2013 2:42 PM
rye
Score: 110
Status: online
thankyou sir
Hide Signatures
(in reply to Hobbsy)
       Post #: 23678
RE: Welcome to Club SAITO ! - 1/13/2013 6:41 PM
Tom Haley
Score: 100
Last Login: 5/12/2013
Status: offline
I have a saito 72 on a nex star I want to put a 3 bladed prop on. I have been running an 11x7 2 blade. What would be a 3 blade recommendation.
Hide Signatures
(in reply to rye)
       Post #: 23679
RE: Welcome to Club SAITO ! - 1/13/2013 7:47 PM
mike early
Score: 125
Last Login: 5/19/2013
Status: offline
12x6 or 12x8 3-blader
I imagine you had the engine under-propped with the 11x7 two blade
Saito Club Member #578
P-40 Brotherhood #62
Hide Signatures
(in reply to Tom Haley)
       Post #: 23680
RE: Welcome to Club SAITO ! - 1/13/2013 8:18 PM
SrTelemaster150
Score: 229
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: Quikturn
Hobbsy, thanks for the info! I have a Saito 91 that turned out to be not such a good deal. I was going to clean it up before I used it and came across discrepancies. One of them being a stripped out screw on the lower left rear cover plate. I believe those are 3mm screws. The cylinder hold down screws are slightly larger at 3.5mm so I thought I would re-tap the stripped out screw for a 3.5mm one. Initially, I wanted to modify a 3.5mm screw into a tap using a cutting wheel but a purpose made tap would be better. I would hate to mess up a crankcase with something not up to the job. I just wanted to be sure which tap I need to order.
Joe
The stock rear cover screws do not go all the way to the bottom of the hole in the case. (at least not on te FA150)
There may be enough thread left to use a longer screw. I think I used the length screw that was used in the FA150 cam housing.
Anyway, check the depth of the hole against the length of the OEM rear cover screw. If there is enough depth, try a srew that is 1mm longer or better yet instal a stud in the hole. No dangerv of bottoming out & breaking off a screw W/a stud.
A "bottom tap" may also get you enough additional threads to get a better hold.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to Quikturn)
       Post #: 23681
RE: Welcome to Club SAITO ! - 1/14/2013 1:08 AM  1 votes
blw
Score: 655
Status: offline
I bet that 72 screams with a 11x7 prop.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 23682
RE: Welcome to Club SAITO ! - 1/14/2013 3:25 AM
Quikturn
Score: 118
Status: offline
quote:
ORIGINAL: SrTelemaster150
A ''bottom tap'' may also get you enough additional threads to get a better hold.
Thanks for the idea. I'll take a look at it and see if it's the same on the 91. It would certainly be an easier repair.
In the event it won't work out, I beleive there is enough material in the crankcase to re-tap to a larger size.
Ultrasport Brotherhood #45
P-40 Brotherhood #35
Hide Signatures
       Post #: 23683
RE: Welcome to Club SAITO ! - 1/14/2013 2:50 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Quikturn
The rear cover screws don't need a lot of torque. They are not containg any type of force. They just hold the rear cover in place. If you can get 3-4 threads to bite, use a stud W/red locctite.
I went ahead & installed studs in both bottom holes to mount a bracket for a Perry V-20 Pump.
Hide Signatures
       Post #: 23684
RE: Welcome to Club SAITO ! - 1/15/2013 4:18 AM
rowdyjoe
Score: 105
Last Login: 5/18/2013
Status: offline
I finally got to start my used FA-91SGK.  It starts and runs like a jewel and the sound is great.  Although, that muffler looks like a plumbing fixture.  I could use a little extra RPM so, it looks like I'll be picking up a Turbo-Header soon.  I haven't checked the peak RPM on it yet because it got dark before I thought about it.  The 13x8 prop was running at a pretty good clip and I expect it to tach high.  I may want to try a deeper pitch but, won't be able to tell until I fly it and see how she performs.
This engine is mounted inverted on a World Models Intruder 90R that I plan to use in SPA competitions.  We  established the "SPA West" division last year and had a great turnout at almost all of the events held west of the Mississippi.  The SPA West "Ft. Worth Open" was flown at my home field this year ....The Ft. Worth Thunderbirds facility on Benbrook Lake.
The Intruder is a good flying plane and is capable of winning contests as has been demonstrated several times in SPA contests.  I'm looking forward to a great season with this plane and the outstanding engine mounted on it.
RJ
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 23685
RE: Welcome to Club SAITO ! - 1/15/2013 5:07 AM
JWQ500RC
Score: 100
Status: offline
I have a Saito 82. I just replaced the cylinder, adjusted the valves and now it runs ok, but the high speed needle is only bout a 1/4 turn from being completly closed. It ideels fine, and seams to run a high speed ok. BUt the high needle setting seams to be way to closed. Shouldn't it bee open somewhere around 1-1/2 turns? Any ideas?
Jim
Jim Williams
Club Saito Menber #621
Hide Signatures
(in reply to rowdyjoe)
       Post #: 23686
RE: Welcome to Club SAITO ! - 1/15/2013 1:40 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: JWQ500RC
Jim
LSN a bit rich affecting the HSN?
Hide Signatures
(in reply to JWQ500RC)
       Post #: 23687
RE: Welcome to Club SAITO ! - 1/15/2013 5:07 PM
JWQ500RC
Score: 100
Status: offline
Sr. Telemaster
Maybe, but I don't think so. Transision is good from idel to high speed. I'll take a look at the LS needle tonite when I get home.
Jim
Jim Williams
Hide Signatures
       Post #: 23688
RE: Welcome to Club SAITO ! - 1/15/2013 9:09 PM
Mein Duff
Score: 105
Status: offline
quote:
ORIGINAL: rowdyjoe
  We  established the ''SPA West'' division last year and had a great turnout at almost all of the events held west of the Mississippi.  The SPA West ''Ft. Worth Open'' was flown at my home field this year ....The Ft. Worth Thunderbirds facility on Benbrook Lake.
The Intruder is a good flying plane and is capable of winning contests as has been demonstrated several times in SPA contests. .
RJ
What is an SPA competition ????
Fleet Brotherhood #5
Half A Wing, Three Engines and A Prayer
Hide Signatures
       Post #: 23689
RE: Welcome to Club SAITO ! - 1/15/2013 10:50 PM  1 votes
blw
Score: 655
Status: offline
Senior Pattern Association. There is a cutoff date for models to compete. I think it is only open to models available no later than 1975.
Coach Pat Dye
Hide Signatures
(in reply to Mein Duff)
       Post #: 23690
RE: Welcome to Club SAITO ! - 1/16/2013 2:13 PM  1 votes
Hobbsy
Score: 650
Status: offline
Jim, the LS needle will only effect the HS needle when the LS needle is too lean, since the HS needle has a fixed seat, set it at peak before you attempt to set the LS needle. Setting the HS needle at full peak eliminates one variable.
Hide Signatures
       Post #: 23691
RE: Welcome to Club SAITO ! - 1/17/2013 12:11 AM
tbone4343
Score: 100
Last Login: 4/30/2013
Status: offline
need rocker arm pin or screw for a saito 50 the 56 part will work also horizon does not have it and at a loss
any one out there have one as i sure could use it
thanks
Stephen
Hide Signatures
(in reply to Broken Wings)
       Post #: 23692
RE: Welcome to Club SAITO ! - 1/17/2013 12:19 AM
FNQFLYER
Score: 110
Status: offline
Check out Hobby Headquarters in OZ or go direct to Japan
Club Saito member 710
Hide Signatures
(in reply to tbone4343)
       Post #: 23693
RE: Welcome to Club SAITO ! - 1/17/2013 1:10 PM
Old Fart
Score: 158
Status: offline
Probably save him a bit of time too.Many bushfires up your way?:
Hide Signatures
(in reply to FNQFLYER)
       Post #: 23694
RE: Welcome to Club SAITO ! - 1/17/2013 2:13 PM
Quikturn
Score: 118
Status: offline
quote:
ORIGINAL: tbone4343
thanks
Here, I think this is what you're looking for.
http://www.gravesrc.com/mobile/default.aspx#P37340
Joe
Hide Signatures
       Post #: 23695
RE: Welcome to Club SAITO ! - 1/17/2013 4:01 PM
barry wetherell
Score: 100
Status: offline
Tbone, if you get stuck, use the end of a drill bit, the rocker cover will hold it in place
Barry
everyday you wake up is a good day
Hide Signatures
       Post #: 23696
RE: Welcome to Club SAITO ! - 1/17/2013 7:11 PM
SRQFlyer
Score: 100
Status: offline
Tbone,
I have just what you need - sent you a PM earlier today.
Jim
AMA 106594, CG Ult 10-300 Bro #38, Club Saito #699 (45, 50, 56, 2x72, 82, 91, 120, 2x 150)
Hide Signatures
       Post #: 23697
RE: Welcome to Club SAITO ! - 1/17/2013 9:36 PM
FNQFLYER
Score: 110
Status: offline
Old Fart, no bush fires up here, if the greenies get in the way of the winter cool burns we burn them as well.
I lived trough the Ash Wednesday fires (Mt Macedon in Victoria) and I used to hunt in the high country where the current fires are in Vic (Mt Baw Baw) and since our "savers of everything" have been let loose and stopped sensible management of the forestry et al we continue to see scenes like te Camberra fires etc.  The lessons of the past were learnt and then discarded.  And the idiots in the fire services still will not use the water bombers they useelsewhere in the world.  I have watched a fire being fought in similar teritory to the Vic Alpine area with only air assetts they put it out and 2 years later almost all traces of the fire were obliterated
As a wise person once said "when you seek to save everything you end up loosing the lot"
As for me give me a cyclone any day over the fies down south
Hide Signatures
(in reply to SRQFlyer)
       Post #: 23698
RE: Welcome to Club SAITO ! - 1/18/2013 3:16 AM
rowdyjoe
Score: 105
Status: offline
quote:
ORIGINAL: Mein Duff
http://www.seniorpattern.com/
"Senior" refers to the planes and not necessarily the pilots.
Take a look at the web site and learn all about it.  It involves flying planes that were built/designed and flown in aerobatics competition prior to 1 Jan. 1976 using the AMA rules that applied at that time.  It's a more affordable (and I think fun) venue than FAI hard core, multi $k equipment.  Engines are limited in size to .65 two stroke (or below) or .95 four stroke.  No pipes, superchargers, turbochargers, major airframe mods, etc. allowed.  Anyway, there are a few rules to keep the planes within plan-form of the originals.
Take a look.  I'll bet you'll like it.
Saitos are a popular engine in this venue.
RJ
SPA 516
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 23699
RE: Welcome to Club SAITO ! - 1/18/2013 3:58 AM  1 votes
blw
Score: 655
Status: offline
RJ,
That *may* be for your SPA area. It's good to know. We hosted the SPA for 2 years here in Alabama and it was 99% OS 91's. Everyone seemed to have dim views of Saitos.
Coach Pat Dye
Hide Signatures
       Post #: 23700
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.313RCU1
