RE: Welcome to Club SAITO !
Tower Hobbies
Logged in as Guest
Users viewing this topic: stallwart, AJsToyz, mbrennan1, les kuntar, retransit
  Printable Version
Saito FA-180 GK
Seller:  RCadmin
Details:   $375.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: Welcome to Club SAITO ! - 9/22/2005 9:24:44 PM
William Robison
Status: offline
Led:
With no vent the crank case pressure will rise to the point that there is no amount of oil getting past the ring. In other words, yes, the plugged vent could have given you a problem.
Bill.
_____________________________
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
(in reply to ledsled)
       Post #: 226
RE: Welcome to Club SAITO ! - 9/23/2005 1:57:05 AM
p-51@charter.net
Status: offline
have a .91 on a shoestring, a 1.00 on a sportsman waco,and a new 1.80 on a funtana LOVE EM ALL tried at first to resist the 4 strokes , but saito has made me a convert!
(in reply to balsa brain)
       Post #: 227
RE: Welcome to Club SAITO ! - 9/23/2005 2:15:05 AM
gjeffers
Status: offline
quote:
ORIGINAL: a340
#60 here,
I have my Saito82 mounted side winder in an acrowot, the exhust looks very vulnerable to catching the ground if I nose over, could be a very costly repair. Does anyone do a shorter header pipe?
By the way this engine is great, still running rich as it sucked a 14oz tank dry in just under 10 mins, and when I say dry I mean every last drop. Not many engines can do that!
Leigh.
a340, ive had my header hit the dirt twice and bent it a little each time and didnt cost any, i just cut it at the bend and cleaned up the threads a little and it worked great,i like them a little shorter anyway
Gary----- club saito#23
its your thang....do what ya wanna do
(in reply to a340)
       Post #: 228
RE: Welcome to Club SAITO ! - 9/23/2005 2:33:46 AM
William Robison
Status: offline
All:
New, welcome #63, p-51@charter.net to the asylum.
Bill.
(in reply to gjeffers)
       Post #: 229
RE: Welcome to Club SAITO ! - 9/23/2005 8:22:56 AM
a340
Status: offline
Cheers William, gjeffers,
I was a bit worried that it would damage the head/barrel. I may take gjeffers sugestion and cut the pipe down a bit. If I wanted to extend the thread a bit do u think just running a 12mm die down the pipe would work?
(in reply to William Robison)
       Post #: 230
RE: Welcome to Club SAITO ! - 9/23/2005 8:51:44 AM
William Robison
Status: offline
Airbus:
Sorry, I (and I suppose Gary) assumed you had the later exhaust, the straight pipe that is threaded full length. Talking about extending the thread, yours must be the curved pipe.
So long as you have a really food quality 12 mm die with a 1.0 mm pitch you should be able to cut more threads on it, but be careful and use a good cutting oil. The pipes are very hard, a "Harbor Freight" die will probably break before it cuts anything.
You might do better getting the SAI8075B straight 12 mm pipe for $9.75, it's long enough that if you cut it in half both pieces will be long enough to mount the muffler. If yours is the cast muffler you can still rotate it out of the way.
Bill.
(in reply to a340)
       Post #: 231
RE: Welcome to Club SAITO ! - 9/23/2005 10:01:57 AM
a340
Status: offline
William,gjeffers,
sorry for not explaining myself properly .It is the curved pipe and what looks like a 2 piece cast muffeler.
Thanks again for the advice,
Leigh.
       Post #: 232
RE: Welcome to Club SAITO ! - 9/23/2005 10:18:02 AM
William Robison
Status: offline
Leigh:
Here's the straight pipe I was talking about.
Bill.
Click to see fullsize image.
Click for fullsize
(in reply to a340)
       Post #: 233
RE: Welcome to Club SAITO ! - 9/25/2005 7:56:48 PM
dpcrowne
Status: offline
Hi all,
I just acquired a Saito 90T Mark II. It's sufficiently different from the 90TS that the TS manual isn't of great help. Does anyone have a 90T manual they'd be willing to photocopy for me (I'd reimburse and pay shipping)?
Doug
(in reply to SigMan)
