RE: Welcome to Club SAITO !
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  11 12 [13] 14 15 16 17 18 19 20   next >   >>
Login
RE: Welcome to Club SAITO ! - 9/29/2005 2:50:03 PM
STG
Status: offline
This may seem like a stupid question...
I have a SA100 and I notice the throttle barrel is spring loaded to full open throttle. Why does Saito do that?
BTW, have 1 gal thru the motor on a 6.5 pound plane and has not skipped a beat.
_____________________________
Good Flying to you!
See Blog for RCU Video's
(in reply to PlaneKrazee)
       Post #: 301
RE: Welcome to Club SAITO ! - 9/29/2005 3:30:58 PM
flycfii
Status: offline
Dennis- yeah, it probably is just getting broken in! I know that my 82 is getting stronger and stronger, and it has probably more than 4 gallons thru it.
As far as outlawing these small piston engines....HA! I will mix my own fuel if necessary, until they outlaw all the component ingredients. I mean, what are they going to do- keep a full-time field monitor (cop) on duty just to keep tabs on us? What a brave new world we live in. Cops in the schools, cameras on the light poles, government computers listening to every phone conversation and watching every email. Be afraid! Cripes.... my wife and I are contemplating Australia.
EDIT: Sorry, hobbsy- sometimes I just gotta vent!
< Message edited by flycfii -- 9/29/2005 3:31:40 PM >
#26 Club Saito
RIP, W.R.
(in reply to STG)
       Post #: 302
RE: Welcome to Club SAITO ! - 9/29/2005 4:00:41 PM
STG
Status: offline
quote:
ORIGINAL: Skypilot_one
This is off topic but applies to where the thread has gone. NASA photos released yesterday show that 1/3rd of the polar ice cap has melted since 1970.
Hobbsy,
If you delete this please move it into the "special" place. People need to know.
You are not suggesting that the glow motors are contributing to this are you? Any motor has to run on some kind of power & unless you are recharging on wind or air power ect you may be using more energy than absolutely necessary.
Good Flying to you!
       Post #: 303
RE: Welcome to Club SAITO ! - 9/29/2005 4:05:08 PM
freeonthree
Status: offline
I won't use anything but a Saito.... Im spoiled !!!
I dont crash, I just land hard
       Post #: 304
RE: Welcome to Club SAITO ! - 9/29/2005 4:08:53 PM
freeonthree
Status: offline
I just started a Saito Yahoo Group in case anyone is interested...
http://groups.yahoo.com/group/saito4strokes/?yguid=193241926
       Post #: 305
RE: Welcome to Club SAITO ! - 9/29/2005 4:36:38 PM
William Robison
Status: offline
STG:
quote:
ORIGINAL: STG
It's not a stupid question. But it is a testimony to the excellent machine work in the Saito carb.
When you work the throttle lever you'll notice the throttle barrel also moves in and out of the carb body. This is what makes the metering (low speed) needle vary the mixture as the throttle setting changes. By moving nearer and farther off the LS needle the fuel port gets larger and smaller, changing the amount of fuel delivered.
Now, since we are depending on the consistency of the variation we have to be sure it changes only with turning the barrel, and not by the barrel moving straight in or out. The spring prevents this, keeping the barrel pushed toward the lever end.
Now we get to the excellent machine work. There is a screw, often the idle speed stop, that rides in a spiral groove on the throttle barrel. As the barrel turns, this is what makes it go in and out. With the outside of the barrel and its bore in the carb body smoothly finished, there is not much friction preventing the barrel's turning. Add the well finished side of the groove for the idle stop screw, the spring is easily able to push the barrel out of the carb body, thereby seeming to be spring loaded to full throttle.
All twin needle carbs except the cheapest possible ones, have this spring. But most others are rough enough in their production that you don't see the barrels being pushed out by the anti-rattle spring.
Please note that an ordinary air bleed carb does not need this spring. Saito air bleed carbs do have one, but they aren't ordinary air bleed carbs either. They could be the subject of another discussion if anyone is interested.
Bill.
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
(in reply to STG)
       Post #: 306
RE: Welcome to Club SAITO ! - 9/29/2005 6:02:24 PM
Hobbsy
Status: offline
Brian, I think my MDS 1.48 Diesel actually caused that, at full song turning a 16x8 three blade at 9,200 it makes some serious smoke.
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
       Post #: 307
RE: Welcome to Club SAITO ! - 9/29/2005 7:58:39 PM
FlyerInOKC
Status: offline
I receintly purchasea userd .80 Saito on RC Universe to install in a 1/5 scale Sig Cub I am building. Any recomedations from you experts on the care and feeding of this engine?
(in reply to balsa brain)
       Post #: 308
RE: Welcome to Club SAITO ! - 9/29/2005 8:31:05 PM
William Robison
Status: offline
With any four stroke engine new to you, always check the valve clearance.
The FA-80 has a metal back plate to mount the carb, intake leakage hasn't been a problem. But if you want to turn the carb around for needle access I'd replace the o-ring where the intake pipe goes into the cylinder.
Fuel? Omega or Powermaster 15%, vary the nitro percentage if you wish but stay with a fuel that has a castor oil blended lubricant. And always run the engine dry after your last flight of the day, and use after run oil.
Bill.
(in reply to FlyerInOKC)
       Post #: 309
