RE: Welcome to Club SAITO !
Tower Hobbies
Logged in as Guest
Users viewing this topic: Shack, Mikecam, Lidman, TimC
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Welcome to Club SAITO ! - 8/31/2005 7:17:10 PM
IronCross
Status: offline
Thanks for clarifying it Bill... Always an education reading your posts FYI the early .72 also had a very weak (plastic) backplate on it also... The replacement I bought for it was much sturdier and has yet to break... They keep changing these dang mufflers and it is hard to get the earlier replacements... To use the latest ones (cast) requires a new cowl on a few of my planes... Kind of frustrating..
_____________________________
Inside every older person is a younger person wondering what the hell happened
(in reply to William Robison)
       Post #: 51
RE: Welcome to Club SAITO ! - 8/31/2005 7:28:47 PM
William Robison
Status: offline
IronCross:
Sorry, intended to include this last time.
The 10mm thread is a few thousandths of an inch larger than 3/8", the 12mm is a hair smaller than 1/2", and the 14mm is 9/16" diameter. Hope this helps your ID of the pipes.
Bill.
PS: Thanks for the kind words. wr.
EDIT: And the plastic back plates do not help to keep the intake pipes held firmly. The later ones are better, but the pipes are still prone to vibrate and destroy the upper seal. wr.
< Message edited by William Robison -- 8/31/2005 7:31:32 PM >
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
(in reply to IronCross)
       Post #: 52
RE: Welcome to Club SAITO ! - 9/1/2005 10:07:57 AM
tukkus
Status: offline
Is anyone running a .82 with 30% heli fuel and what prop are you using?....i have a UCD .46 propped with a 14wx4 on 15% COOLPOWER and i was wondering what prop to use with 30%
This is a HOBBY so we don't need no steeenkin' reasons to use four stroke engines.
       Post #: 53
RE: Welcome to Club SAITO ! - 9/4/2005 12:12:14 PM
SigMan
Status: offline
Your in Like Flynn, Donkey Doctor !
Club Saito Member #1
,Sig Kadet Senior,Multiplex FJ, Evader ST,Billy Hell Sabre 35, Magnum 70
(in reply to donkey doctor)
       Post #: 54
RE: Welcome to Club SAITO ! - 9/5/2005 2:26:09 AM
seanychen
Status: offline
quote:
ORIGINAL: tukkus
See my rpm and thrust data in this thread:
http://www.rcuniverse.com/forum/m_3311178/tm.htm
I recommend APC 14x6.
E_Total = M*G*H + 1/2 M*V^2
When H=0, all of airplane's velocity becomes crash energy!
(in reply to tukkus)
       Post #: 55
RE: Welcome to Club SAITO ! - 9/5/2005 2:31:14 AM
Hobbsy
Status: offline
Sean, that is about 1,100 rpm faster than my .82 gets on 10% WildCat and an APC 14x6, you done good.
Giant Saito, 73.2 Cu. In., 70.5HP @ 5,800 rpm, 79 ft. lbs torque @ 3,500 rpm, 57 mpg, 3.50 bore, 3.81 stroke. 563 lbs.
(in reply to seanychen)
       Post #: 56
RE: Welcome to Club SAITO ! - 9/5/2005 2:38:03 AM
seanychen
Status: offline
quote:
ORIGINAL: hobbsy
Saitos this size gains about 500 rpm for each 10% nitro added.
I think using low nitro on Saito is like putting a stock muffler on a 2 stroke: getting less power for your $.
(in reply to Hobbsy)
       Post #: 57
RE: Welcome to Club SAITO ! - 9/5/2005 4:41:24 AM
khodges
Status: offline
Just added another Saito to my flock, herd, covey, whatever; a FA-91S. One question: it's called Special (the "S" after .91). What's special about it? I don't see that designation after any of the other models. It's not made of gold, there's no supercharger, it doesn't have anything on it the other Saitos don't have; so, what's special?
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
       Post #: 58
RE: Welcome to Club SAITO ! - 9/5/2005 4:47:10 AM
William Robison
Status: offline
The "S" versions usually have hotter cams, more peak power, and worse idle than the older ones.
Saito claims they idle as well as the older ones, that has not been my experience.
Bill.
(in reply to khodges)
       Post #: 59
RE: Welcome to Club SAITO ! - 9/6/2005 9:34:54 PM
Ernie Misner
Status: offline
Bill, great info as usual. Thanks! Now..... which type of silicone for the intake o-ring.... red? And how do you make a restrictor for your restricted straight pipes???
Thanks again,
Ernie
       Post #: 60
RE: Welcome to Club SAITO ! - 9/6/2005 10:24:12 PM
William Robison
Status: offline
Ernie:
I normally uise the plain blue RTV for a couplle reasons. One, it's the most common and easiest to find, and two (the main one) it's the least expensive and I'm cheap.
Two ways to form a restrictor in an exhaust pipe that wont come loose and fall off. Put a steel bar in a heavy vise, sized about 1/2 the diameter of the pipe. Then use the bar as a mandrel and using a hammer, just peen the end while turning the pipe on the mandrel.
The second way, if you have full access to the pipe all around, is using a tubing cutter with a very dull cutting wheel. Instead of cutting the pipe the wheen will bend a circumfrential groove in the pipe. When it's as far in as you want it you can cut the pipe normally at the outlet end of the groove, or right in the bottom of the groove.
I'm working up a post/thread about making inlet stacks for any engine, not just Saito, I show the peening with a mandrel there. If it's unclear here, and you can't wait, I'll post on it h
