RE: Welcome to Club SAITO !
Tower Hobbies
Logged in as Guest
Users viewing this topic: davidgeorge212, Tom Jones, AeroFinn, RC Specialties, Vince J, Michaelh, isaacslaw, GaGeeBees
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  414 415 [416] 417 418 419 420 421 422 423   next >   >>
Login
RE: Welcome to Club SAITO ! - 4/8/2008 5:05:36 PM
TheDenter
Status: offline
Hi A
_____________________________
Club Saito #589 AMA #845846
W M P-51 Mustang
(in reply to rexracer)
       Post #: 10376
RE: Welcome to Club SAITO ! - 4/8/2008 5:09:28 PM
TheDenter
Status: offline
Hi All,
Do I need to ask my question here or somewhere else? About the 90 elbow and securing muffler.
W M P-51 Mustang
       Post #: 10377
RE: Welcome to Club SAITO ! - 4/8/2008 5:21:40 PM
RPMcK
Status: online
Rex, How have you got your regulator mounted? I just got mine and the instructions say it needs to be placed 3/4 to 1 inch from carberator. That's pretty close. Do you have it mounted solid someway or just supported by the fuel lines? Ron
Ron, Club Saito #564. AMA #861323
More is always better,---- and Way Too Much is Perfect!!!
       Post #: 10378
RE: Welcome to Club SAITO ! - 4/8/2008 5:31:18 PM
rexracer
Status: offline
It just hangs on the lines. I would say that the nipple on the Cline and the carb are about 1/4" apart inside the line. It's actually pretty close to the exhaust manifold, but I'll just keep an eye on it through the first dozen flights and look for signs of rubbing. If it does rub, I'll probably just zip tie the line from the tank to hold it away from anything. I love the idle and transition with the regulator on. I actually had it idling at less than 1400 rpm for over a minute, if I remember right. It's smooth at 1800.
Club Saito member #173
(in reply to RPMcK)
       Post #: 10379
RE: Welcome to Club SAITO ! - 4/8/2008 5:47:32 PM
RC Specialties
Status: online
Denter.
The muffler should not be secured with zip ties. The Saito 90 degree adapter in known for breaking when the stock muffler is attached.
Jim
RC Specialties, LLC "Home of the TurboHeader Muffler"
(in reply to TheDenter)
       Post #: 10380
RE: Welcome to Club SAITO ! - 4/8/2008 6:15:37 PM
scratchonly
Status: offline
I have a tank in my zero that is 2 1/4 inches too high; Jim at cline assured me his regulator would fix it. Haven't tried it yet, spring is coming late up here .
Real planes have two wings and round engines
(in reply to Upnet)
       Post #: 10381
RE: Welcome to Club SAITO ! - 4/8/2008 6:15:56 PM
RPMcK
Status: online
Thanks Rex. I think supporting the regulator on the fuel lines should work for me too. Mine is probably about the same distence from the carb. as yours. Ron
       Post #: 10382
RE: Welcome to Club SAITO ! - 4/8/2008 6:24:48 PM
RPMcK
Status: online
We'er having the same problem here in Montana scratchonly. I been wantin' to try my new Cline reglulator but spring is draggin' it's feet getting here. In fact it's snowing right now ARGGG!
(in reply to scratchonly)
       Post #: 10383
RE: Welcome to Club SAITO ! - 4/8/2008 9:26:22 PM
AJsToyz
Status: offline
Hi folks,
Just a quick question , how low should a .72 idle ?? I purchased mine used and am having a little trouble keeping it running around 2000 rpms . It will idle all day around 2300 rpms . Should I reset the carb to the stock settings and start over or is this about normal ?? Running YS 20/20 Wildcat turning 9900 rpms with an APC 14x4W and thats set rich. It actually runs really well with 10% Omega also, about 9500 rpms , just can't get the idle any lower.
Andy
I go out , I crash , I fix .....
Club Saito member #590
(in reply to RPMcK)
       Post #: 10384
