RE: Welcome to Club SAITO !
Tower Hobbies
Logged in as Guest
Users viewing this topic: Jerryballs, DurrellGehman, proptop, johnS555
  Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  420 421 [422] 423 424 425 426 427 428 429   next >   >>
Login
RE: Welcome to Club SAITO ! - 4/27/2008 10:16:13 PM
blw
Status: offline
quote:
ORIGINAL: mbrennan1
I bought a GP Venus to replace this Lark 70. I liked the way the Lark flew. but it was not the easiest plane to build.
Club Saito Member #591
Hmmmm, looks repairable maybe with a new nose section. I wouldn't toss it yet.
_____________________________
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
(in reply to mbrennan1)
       Post #: 10526
RE: Welcome to Club SAITO ! - 4/27/2008 11:03:03 PM
mbrennan1
Status: offline
I saved it. Maybe some rainy day I will start rebuilding it.
(in reply to blw)
       Post #: 10527
RE: Welcome to Club ... - 4/28/2008 2:36:38 AM
Wingspam
Status: offline
I have a Saito 180 and I keep having problems with the muffler coming loose at the muffler. I have tried blue lock tight and red. The red held longer but still came loose. I have rechecked the prop for balance and it is good.
Being tired of the stock muffler, where can I get a good after market muffler?
Do they make a 1 piece muffler for the 180?
Thanks in advance
Wingspam
(in reply to Kimhoff)
       Post #: 10528
RE: Welcome to Club ... - 4/28/2008 2:48:26 AM
Kmot
Status: offline
Is there a way to upload a PDF file onto the forum? I have something useful for Club Saito if there is a way.
Ahhh......screw it!
(in reply to Wingspam)
       Post #: 10529
RE: Welcome to Club SAITO ! - 4/28/2008 4:02:19 AM
clutchbob
Status: offline
I have just recently aquired my first 4 stroke - a Saito 72. I'm very pleased with this engine. It idles very slowly and transitions to WOT without a hiccup, and it's just barely broken in.
Have you tried tightening while the engine is hot?
Suffering joyfully
(in reply to Kmot)
       Post #: 10530
RE: Welcome to Club SAITO ! - 4/28/2008 4:11:03 AM
rexracer
Status: offline
Kmot, can't you just click on the link at the bottom of the message window like you do to upload pics?
Club Saito member #173
(in reply to clutchbob)
       Post #: 10531
RE: Welcome to Club SAITO ! - 4/28/2008 5:27:24 AM
Kmot
Status: offline
No, that dialog box does not support PDF.
Ahhh......screw it!
(in reply to rexracer)
       Post #: 10532
RE: Welcome to Club SAITO ! - 4/28/2008 5:59:22 AM
s10junky83
Status: offline
I'm having a horrible time setting my ls needle on a saito 100. My HS needle is peeked at 9000 on 30% coolpower and my LS has a very small "sweet spot" that is within 1/4 of a turn. Problem is if I lean it, it idles way to high then dies. If I richen it, it will run then die within a minute. It always starts immeadiatly after dying. Could the valves be too loose? If I put them on the feeler gauge the motor vibrates horribly. I need to add that this motor ran and idled great when it was sloppy rich but only peaked at 8100 rpm and that won't hover my 7 LBS plane. Please tell me what to do!!!!!!!!!!!!
Club Saito Member# 581
AMA# 888604
(in reply to Kmot)
       Post #: 10533
RE: Welcome to Club SAITO ! - 4/28/2008 7:07:17 AM
swixtt
Status: online
hey guys,
can someone post how they start their Saito 150's or 180's... i seem to always kick my prop nut(a dubro one). it is on a test stand... i prime with just one turn of the prop(manually) then either stick-it or use the starter. when i do prime it i believe it just draws too much fuel in the cylinder there by causing the kick-back when i go to start it.
(in reply to s10junky83)
       Post #: 10534
RE: Welcome to Club SAITO ! - 4/28/2008 2:37:16 PM
w8ye
Status: offline
I stick the electric starter to the engine and it starts.
Are you trying to start your engine by hand?
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to swixtt)
