N1EDM
MA, USA Status: offline
It almost sounds like your LSN is set just a bit lean. And yes, the plug could be bad. I've had plugs go bad on brand new engines after a few runs, possibly because some machining by-product got into it and contaminated the element. Replace the plug and it runs OK. After checking all the issues such as tank position, etc., see if the LSN could be adjusted, only 1/8 or 1/16 turn at a time. Just my $.02 Bob
_____________________________
An expert is someone who has been doing it for 15 minutes longer than you.
