otrcman
CA, USA Status: offline
I just bought a new rear bearing for my Saito 80. Need advice on the best way to install the bearing in the case. Also, I've noticed that the old bearing is unshielded, whereas the new bearing is shielded on both sides. Is this just a running design change or are there two different bearings depending on engine series? By the way, Horizon was friendly, helpful, and very fast on delivery. Thanks in advance, Dick Fischer
