RE: Welcome to Club SAITO !
Tower Hobbies
Logged in as Guest
Users viewing this topic: johnS555
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  426 427 [428] 429 430 431 432 433 434 435   next >   >>
Login
RE: Welcome to Club SAITO ! - 5/14/2008 1:31:43 AM
Hobbsy
Status: offline
Mike, is there enough room for a TurboHeader?
Click to see fullsize image.
Click for fullsize
_____________________________
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
(in reply to mike early)
       Post #: 10676
RE: Welcome to Club SAITO ! - 5/14/2008 3:10:12 AM
mike early
Status: offline
No...I have only 3/4" from threads to cowl. I even had to grind down the 90º fitting to get it working.
(in reply to Hobbsy)
       Post #: 10677
RE: Welcome to Club SAITO ! - 5/14/2008 4:10:24 AM
Shack
Status: offline
quote:
ORIGINAL: mike early
The flex pipe broke on me today. POS. There was maybe 10º of deflection in it. Not like I was making a right angle with it or anything. Only ran it about 6 times. 44 dollars.
In an earlier post I said w/a flex pipe you need to anchor it near the end to keep it from vibrating [metal fatigue]. Put some kind of heatproof rubber around it & use an adel clamp [Lowe's has them.] I have seen two break when not anchored.
Shack
       Post #: 10678
RE: Welcome to Club SAITO ! - 5/14/2008 2:01:13 PM
Hobbsy
Status: offline
Mike, this is the difference between the Horizon 90 and the RCSpecialties 90, the RCS being the compact one, I am not trying to be a salesman and I'm net even sure Jim makes the 13mm 90 yet. This is the 14mm one.
Click for fullsize
Click for fullsize
< Message edited by Hobbsy -- 5/14/2008 2:04:45 PM >
       Post #: 10679
RE: Welcome to Club SAITO ! - 5/14/2008 2:04:32 PM
RC Specialties
Status: offline
Hobbsy & Mike,
I do offer 10, 11, 12, 13, and 14mm size adapters.
Jim
RC Specialties, LLC "Home of the TurboHeader Muffler"
       Post #: 10680
RE: Welcome to Club SAITO ! - 5/14/2008 2:06:01 PM
Hobbsy
Status: offline
Excellent, I wasn't sure of the 13, Thanks Jim
(in reply to RC Specialties)
       Post #: 10681
RE: Welcome to Club SAITO ! - 5/14/2008 5:29:07 PM
blw
Status: offline
Mike- are you getting a lot of visible smoke in your exhaust when you run the engine? Those are low numbers. The first thing I would look at would be for rich settings, especially on the low end.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
       Post #: 10682
RE: Welcome to Club SAITO ! - 5/14/2008 7:57:19 PM
Hobbsy
Status: offline
Mike, I tried to come up with some comparable props for my 1.25 to get some numbers, I don't have very many APCs as I don't fly them.
Saito 1.25/stock exhaust
WildCat 15% fuel with 18% 80/20 blend
Fox Miracle plug
MasterAirscrew Classic 16x6===9,450 rpm
MasterAirscrew K 15x8======8,975
Graupner 15x8===========8,795
And, just for kicks
Enya 1.20 GP
WildCat 5% fuel with 16% lube and 3 oz of castor added
Enya #3 plug
Graupner 15x8======9,050 rpm, not too shabby for 5% nitro.
< Message edited by Hobbsy -- 5/14/2008 11:28:35 PM >
       Post #: 10683
RE: Welcome to Club SAITO ! - 5/14/2008 9:29:02 PM
jdr43
Status: offline
"I tried to come up with some comparable props for my 1.25 to get some numbers, I don't have very many APCs as i don't fly them. "
Hobbsy, just curious why don't you use APC Props ?
Jim R
AMA # 731132
Saito Club #510
