RE: Welcome to Club SAITO !
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  428 429 [430] 431 432 433 434 435 436 437   next >   >>
Login
RE: Welcome to Club SAITO ! - 5/18/2008 5:00:37 AM
ILv2Xlr8
Status: offline
Thanks for the advice! An 82 sounds big to me for the wing loading on this aircraft, but I guess you can't have too much power for 3D. I did a comparison, and the 72 and 82 engines are listed at the same 16oz weight, so might as well go with the 82.
I am still curious what size wide 3D prop could you spin on a Saito 56 or a Saito 72? I have these engines on other aircraft, and wanted to know what 3D props you recommend?
< Message edited by ILv2Xlr8 -- 5/18/2008 5:02:15 AM >
(in reply to Michaelh)
       Post #: 10726
RE: Welcome to Club SAITO ! - 5/18/2008 5:04:32 AM
Michaelh
Status: offline
Yeah its the same so might as well ehh. I also posted to the BEC thread. Ive done much of the lightweight hunting already for my plane. You can cut that RX pack down to 1200 2s Lipoly also. Think they are like 2.3-2.6 ounces if you can find the older Ecotec packs.
Have Fun !
Mike
_____________________________
More info on Saito's http://saito-engines.info/
Club Saito #542
(in reply to ILv2Xlr8)
       Post #: 10727
RE: Welcome to Club SAITO ! - 5/18/2008 1:41:03 PM
AJsToyz
Status: offline
I have a 72 on a Nitro Models Yak with an APC 14x4W prop , it gets 9450 with 10% and will run 9700 rpms with 20/20 and that is on the rich side ! The plane ways in @ 6 lbs 1 oz .
Andy
I go out , I crash , I fix .....
Club Saito member #590
       Post #: 10728
RE: Welcome to Club SAITO ! - 5/18/2008 4:19:02 PM
jb86
Status: offline
the miracle switch (regulated switch) from MPI (6v version) plus a 2s lipo around 1000mah will easily save a couple of ounces. you have to use a regulator of some type w/a lipo. the rx doesn't want anymore than 6v, not 6.1 or 6.2v, ect. the 5cell nicad/nimh runs well over 6v when charged, not good for the rx. the miracle switch has a safety that if something goes wrong w/the switch, it just stays on, instead of loosing contact and connection.
< Message edited by jb86 -- 5/18/2008 4:21:16 PM >
saito club #235
       Post #: 10729
RE: Welcome to Club SAITO ! - 5/18/2008 5:22:01 PM
bzizzi
Status: offline
I recently purchased a Saito 91s and am going to put it on this plane,will it be enough ????
http://www.horizonhobby.com/Products/Default.aspx?ProdID=SEA5050
(in reply to William Robison)
       Post #: 10730
RE: Welcome to Club SAITO ! - 5/18/2008 5:38:24 PM
jb86
Status: offline
it's minimum for a 10lb a/c. i had an edge 540 @ 7lb w/os 91FS pumped w/apc 14x6 @ 10k. flew great but not unlimited vertical. saito 1.00 w/14x8 would probably been perfect. they give a range of engines, if you can go to the highest, you can always throttle back. @ 10lbs, it needs more muscle to do any good aerobatics. the bipe has lots of lift, it will climb, but for vertical you need power. the 1.25 w/16x6 or 15x8 (if you need ground clearance). or ys fz 1.10-s if you can, that would definitely be hot.
saito club #235
(in reply to bzizzi)
       Post #: 10731
RE: Welcome to Club SAITO ! - 5/19/2008 12:13:46 AM
EdgewordMI
Status: offline
Several questions. Does any Admin. have an actual list of Club Saito numbers?? I had one once..... Can anyone say what their Saito 72 idle screw is set at and what it tachs @?? I run Wildcat 15% and 18% syn., I had to readjust linkage and fouled up the idle setting and didn't write down...
Thanks guys
Club Saito No. 587
If it jams force it, if it breaks it needed replacing anyway.
(in reply to jb86)
       Post #: 10732
RE: Welcome to Club SAITO ! - 5/19/2008 12:42:07 AM
w8ye
Status: offline
On the Saito 72 the idle screw usually adjusts close to being .040" below the surface of the throttle arm.
The engine will generally idle better with a plastic prop.
The needle valves are made adjustable so they can be positioned for the best compromise between idle and acceleration.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to EdgewordMI)
       Post #: 10733
RE: Welcome to Club SAITO ! - 5/19/2008 1:46:52 AM
ILv2Xlr8
Status: offline
quote:
ORIGINAL: jb86
Thanks for the tip. Where do you get the MPI switches?
Most of the spektrum receivers can take up to 9.6v.
(in reply to jb86)
       Post #: 10734
RE: Welcome to Club SAITO ! - 5/19/2008 2:02:29 AM
Michaelh
