jb86
VA, USA Status: offline
it's minimum for a 10lb a/c. i had an edge 540 @ 7lb w/os 91FS pumped w/apc 14x6 @ 10k. flew great but not unlimited vertical. saito 1.00 w/14x8 would probably been perfect. they give a range of engines, if you can go to the highest, you can always throttle back. @ 10lbs, it needs more muscle to do any good aerobatics. the bipe has lots of lift, it will climb, but for vertical you need power. the 1.25 w/16x6 or 15x8 (if you need ground clearance). or ys fz 1.10-s if you can, that would definitely be hot.
_____________________________
saito club #235
