Hobbsy
VA, USA Status: offline
D, you need to forget all about the turns and using your tach slowly, (starting rich) lean the HS needle until the engine slows a little frombeing lean. Change to needle setting one click at a time slowly, fourstrokes don't respond to needle changes instantly, give it time to stabilize at each change. Are you familiar with Apex Hobbies over in Tazewell, that's where I buy everything.
_____________________________
Giant Saito, 73.2 Cu. In., 70.5HP @ 5,800 rpm, 79 ft. lbs torque @ 3,500 rpm, 57 mpg, 3.50 bore, 3.81 stroke. 563 lbs.
