RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
Users viewing this topic: nextofkin
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  824 825 [826] 827 828 829 830 831 832 833   next >   >>
Login
RE: Welcome to Club SAITO ! - 9/19/2011 1:09 PM
Hobbsy
Score: 650
Last Login: 5/21/2013
Status: offline
The carb in this case sees no pressure, the pressure is between the regulator valve and the tank. The carb still operates in response to low pressure pulses caused by the venturi action. The regulator responds to the same low pressure pulses, the demand.
_____________________________
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to Nikolas K)
       Post #: 20626
RE: Welcome to Club SAITO ! - 9/19/2011 2:47 PM
Nikolas K
Score: 100
Last Login: 5/14/2013
Status: offline
Ok, now I understood it! Thank you Hobbsy!
Saito Club Member #763
Hide Signatures
(in reply to Hobbsy)
       Post #: 20627
RE: Welcome to Club SAITO ! - 9/19/2011 3:56 PM
gkamysz
Score: 120
Last Login: 2/6/2012
Status: offline
Cline, or Iron bay, or OS carb regulators supply fuel to the carb at slightly below atmospheric pressure. Study the design. I was also under the impression that YS four stroke fuel injection systems are simply demand regulators. This is NOT the case. Carefully study the design. YS uses mechanical fuel injection systems. Rather simple, but effective for glow fuel.
Greg
Hide Signatures
       Post #: 20628
RE: Welcome to Club SAITO ! - 9/19/2011 5:57 PM
w8ye
Score: 318
Status: online
Some people bias the regulator atmospheric pressure reference with exhaust pressure which gives a positive pressure related to engine speed and power output. Pe Reivers did some of this.
He made his own pump/regulators by converting old Walbro carbs.
http://prme.nl/home/regulated_fuelsupply/a_regulated_fuel_supply.html
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to gkamysz)
       Post #: 20629
RE: Welcome to Club SAITO ! - 9/21/2011 12:55 PM
Old Fart
Score: 158
Status: offline
Thanks for the link i'm reading it now,cheers
Watch out for the ground eh?
Hide Signatures
(in reply to w8ye)
       Post #: 20630
RE: Welcome to Club SAITO ! - 9/21/2011 4:50 PM
hsukaria
Score: 185
Status: offline
Ok, so there are good options regarding pumps and regulators. But when do you need them? What symptoms or problems with the engine operation cause someone to need more than just exhaust pressure to the tank?
Content, but not Complacent.
Saito Club Member #765
Hide Signatures
(in reply to Old Fart)
       Post #: 20631
RE: Welcome to Club SAITO ! - 9/21/2011 7:12 PM
w8ye
Score: 318
Status: online
I think the discussion came up as a result of someone wanting to run gas in a glow Saito carb?
I have not biased a regulator with muffler pressure. I've always found regulation to be adequate when just using atmospheric static pressure.
Gasoline runs twice the air/fuel ratio as glow fuel. Therefore the flow of gasoline is more sensitive because you are using less of it. Therefore the need for a constant pressure.
A pump and regulator would be indicated on a glow engine when you are running a tank not directly behind and centered on the needle valve or when you are not running muffler pressure to the tank.
Original AMA #31261
Hide Signatures
(in reply to hsukaria)
       Post #: 20632
RE: Welcome to Club SAITO ! - 9/21/2011 8:14 PM
NM2K
Score: 161
Status: online
To me, the only true fuel injection is direct injection. Yes, what some folks call fuel injection is not carburetion, but it isn't true fuel injection either. We need another name. Any suggestions?
Ed Cregger
"Practice makes prefect"
Hide Signatures
(in reply to w8ye)
       Post #: 20633
RE: Welcome to Club SAITO ! - 9/21/2011 8:31 PM
w8ye
Score: 318
Status: online
I remember some years ago about references to a "Pressure Carb"
Original AMA #31261
Hide Signatures
(in reply to NM2K)
       Post #: 20634
RE: Welcome to Club SAITO ! - 9/21/2011 9:22 PM
spaceworm
Score: 143
Status: offline
quote:
ORIGINAL: NM2K
Ed Cregger
In the auto sector, fuel injected into the manifold by a single injector was/is called manifold injection. Fuel injection by multiple timed injectors just outside of the intake valve was/is called port injection. Fuel injected by separate injectors directly into the combustion chamber is called direct injection. I think VW calls the latter TDI, and is what Diesel engines employ.
At least that has been my understanding. Comments anyone?
Hide Signatures
(in reply to NM2K)
       Post #: 20635
RE: Welcome to Club SAITO ! - 9/21/2011 11:17 PM
hsukaria
Score: 185
Status: offline
Manifold injection was also called Throttle Body Injection (TBI). It was an improvement over a carburator because of improved fuel control and does not use a venturi. A venturi causes a vacuum in the intake manifold for fuel suction, but also causes power loss because it lowers the cylinder pressure.
Port Fuel Injection injects fuel just upstream of the intake valves. It is an improvement in performance and emissions over throttle body injection. But still suffers from fuel puddles accumulating on the back of the intake valve.
Direct fuel injection started out in diesels, but is now also used in the latest gasoline engines. It provides the best fuel control, and power. The biggest benefit of gasoline direct injection is that when the fuel is injected at the compression stroke, it actaully causes a rapid cool down of the compressed air, allowing for reduced pumping losses by allowing the air to cool down and condense right before combustion.
As mentioned before, the fuel injection in model engines would be the throttle body (or manifold) injection. If done properly, besides helping with fuel control, it can help with increasing power by eliminating the carb venturi.
Hide Signatures
(in reply to spaceworm)
       Post #: 20636
RE: Welcome to Club SAITO ! - 9/21/2011 11:45 PM
earlwb
Score: 584
Status: online
quote:
ORIGINAL: hsukaria
Actually they did that with the glow engines already. The combat, speed and hi-perf FF engines used bladders that you inflate with fuel. The bladders developed a lot of pressure too. The intakes on the engines then used a large intake hole with no venturi, since they don't draw fuel the intake can be made larger, and the needle valve assembly usually wound up being a 1/2 length/size unit on one side and it sprayed the fuel directly into the intake with no obstructions inside.
The pylon racers did it to some extent as well (at least until idle rules in some classes were implemented).
OS went all the way and marketed a real fuel injected 4 stroke engine for a while, with a real fuel pump, fuel injector and a ECU unit.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
       Post #: 20637
RE: Welcome to Club SAITO ! - 9/22/2011 1:46 AM
hsukaria
Score: 185
Status: offline
quote:
ORIGINAL: earlwb
quote:
ORIGINAL: hsukaria
I've been told about the OS fuel injection before. I bet it wasn't cheap, but OS is never cheap.
Hide Signatures
(in reply to earlwb)
       Post #: 20638
RE: Welcome to Club SAITO ! - 9/22/2011 1:57 AM
flyingagin
Score: 114
Status: offline
quote:
ORIGINAL: hsukaria
quote:
ORIGINAL: earlwb
quote:
ORIGINAL: hsukaria
I have have looked but have not seen or heard anymore than what I have seen here. Not interested in owning one just curious. I like motors. Any I only have a rubber band motor budget
pics? links? data?
"As for Me and My House, We Will Serve the Lord"
Club Saito Member 775
Hide Signatures
       Post #: 20639
RE: Welcome to Club SAITO ! - 9/22/2011 2:10 AM
Hobbsy
Score: 650
Status: offline
Test post
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 20640
RE: Welcome to Club SAITO ! - 9/22/2011 12:02 PM
Old Fart
Score: 158
Status: offline
I'm sure happy i read all these posts it's a lively conversation.I'm going to start off running a vp20 pump and exhaust pressure.
Hide Signatures
       Post #: 20641
RE: Welcome to Club SAITO ! - 9/22/2011 12:24 PM
earlwb
Score: 584
Status: online
quote:
ORIGINAL: flyingagin
pics? links? data?
It is pretty awesome in that the ECU controls the engine, so there are no needle valves to adjust. If it wasn't for the cost, it might have revolutionized the glow engine market especially with beginners.
OS advertisement for them http://www.os-engines.co.jp/english/2007spring-summer/fs200sfi/index.htm
OS had a .91, 1.60 and a 2.00 fuel injected engine.
Tower Hobbies still has some parts even.
http://www3.towerhobbies.com/cgi-bin/wti0005p?&I=OSMG0941&P=OW
OS had a 2 stroke 1.60 with FI:
OS FS091FI in use.  it is not mine though. Sorry.
AMA # 928076
Hide Signatures
       Post #: 20642
RE: Welcome to Club SAITO ! - 9/22/2011 1:34 PM
w8ye
Score: 318
Status: online
Life wasn't so simple as fly out of the box with the OS FI engines as you had to follow a procedure to establish the limits of the fuel mixture algorithm about as often as you would need to adjust the needle valve on a regular carb engine. You would get along with the same limits all summer but in the fall as the weather started getting a little cooler, you would have to set the limits up again.
Original AMA #31261
Hide Signatures
       Post #: 20643
RE: Welcome to Club SAITO ! - 9/22/2011 1:46 PM
flyingagin
Score: 114
Status: offline
WOW those are some awesome engines> Beautiful
OH well rubber band motors for me.
I will stay with my Saito .65 and ST, and OS that I have.
Hide Signatures
       Post #: 20644
RE: Welcome to Club SAITO ! - 9/22/2011 3:59 PM
Kostas1
Score: 330
Status: offline
quote:
ORIGINAL: w8ye
But it was a really nice and innovative idea anyway, right;
<==**Check my gallery for more pictures**
Club Saito member #706
Hide Signatures
(in reply to w8ye)
       Post #: 20645
RE: Welcome to Club SAITO ! - 9/22/2011 4:02 PM
hsukaria
Score: 185
Status: offline
Those fuel injected engines are awesome. But I'm sure only the professional competition guys would spend that kind of money (or you are crazy about engines).
I'm just happy I was able to replace a piston ring on one of my cheaper 2-strokes last weekend. I will bench run it soon to break it in. Simple pleasures.
Hide Signatures
(in reply to flyingagin)
       Post #: 20646
RE: Welcome to Club SAITO ! - 9/22/2011 5:01 PM
Hobbsy
Score: 650
Status: offline
As you can see my pictures posted some time after I actually posted them. The YS 1.15 finally has the regulator where it should have been all along. The 1.70 has the fuel injection pump on the intake pushrod and the mixture is controlled by the carb barrel
Hide Signatures
       Post #: 20647
RE: Welcome to Club SAITO ! - 9/22/2011 5:20 PM
hsukaria
Score: 185
Status: offline
quote:
ORIGINAL: Hobbsy
The picture on the right has a servo pigtail wire. Does that connect to a receiver and eliminates the throttle servo? The FI also controls the throttle?
Hide Signatures
       Post #: 20648
RE: Welcome to Club SAITO ! - 9/22/2011 5:26 PM
Hobbsy
Score: 650
Status: offline
I suspect that would be a throttle position sensor to make the fuel injection more accurate, that's just a guess though.
Hide Signatures
       Post #: 20649
RE: Welcome to Club SAITO ! - 9/22/2011 5:31 PM
Hobbsy
Score: 650
Status: offline
PS. I just did some more digging and that engine is a new 1.75 that is, "comming soon" there is no explanation for the wire.
Hide Signatures
       Post #: 20650
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
