RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  866 867 [868] 869 870 871 872 873 874 875   next >   >>
Login
RE: Welcome to Club SAITO ! - 4/29/2012 6:16 AM
Ernie Misner
Score: 130
Last Login: 5/22/2013
Status: offline
Have you used the crock pot method of cleaning them up before?
Ernie
Hide Signatures
(in reply to Tarasdad)
       Post #: 21676
RE: Welcome to Club SAITO ! - 4/29/2012 4:38 PM
Tarasdad
Score: 135
Last Login: 3/31/2013
Status: offline
Nah, I'm more the toothbrush-and-elbow-grease type. I enjoy breaking an engine down and cleaning each part along the way. Just more fun!
_____________________________
Tarasdad
Club Saito #680; 2x Saito .91, Saito .80, Fox .50, Fox .25, Fox .19; Apprentice 15e; Tiger 60; Super Chipmunk
Hide Signatures
(in reply to Ernie Misner)
       Post #: 21677
RE: Welcome to Club SAITO ! - 4/29/2012 5:05 PM
earlwb
Score: 584
Last Login: 5/23/2013
Status: offline
I did try the crock pot method, but I think I used the wrong type of antifreeze for it to work well. So my results were not all that good.
But since I have the engine torn down, if it is grungy, I'll use Dawn Power Dissolver on the aluminum parts and scrubbing with a toothbrush etc.
Do test the DPD on a small part of a engine first to be sure it doesn't stain the metal on you. Some aluminum alloys can discolor from using it.
I also don't leave it on to soak as long as the instructions say too.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
       Post #: 21678
RE: Welcome to Club SAITO ! - 4/29/2012 6:35 PM
blw
Score: 655
Last Login: 5/21/2013
Status: offline
The crock pot does a better job faster, but I think a lot of people enjoy sitting with DPD and a brush too. I've left it on Saitos and Evolutions for up to 45 minutes without any discoloring.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to earlwb)
       Post #: 21679
RE: Welcome to Club SAITO ! - 4/30/2012 3:08 AM
Tarasdad
Score: 135
Status: offline
Stripped the first of the two .91s down today. As I thought, absolutely filled with old, gummy, baked on castor residue. Got the bearings out and the front feels okay but not so sure about the rear. Soaking and scrubbing it in fresh fuel to see if that helps or not. Hoping so because if it needs bearings that isn't going to happen for a while. Just got to finish cleaning it up and see what happens.
Well, they were free so I really can't complain, can I?
Tarasdad
Hide Signatures
(in reply to blw)
       Post #: 21680
RE: Welcome to Club SAITO ! - 4/30/2012 3:21 AM
Mein Duff
Score: 105
Status: offline
A set of new bearings from RCBearings.com would be under $10 for the set probably...unless the old ones are pristine when cleaned.
Fleet Brotherhood #5
Half A Wing, Three Engines and A Prayer
Hide Signatures
       Post #: 21681
RE: Welcome to Club SAITO ! - 4/30/2012 6:28 AM
Tarasdad
Score: 135
Status: offline
Front bearing is okay, rear is toast. When I buy new ones I'll buy both. I can always find a use for the old front bearing, all kinds of little projects it can be used for.
Tarasdad
Hide Signatures
(in reply to Mein Duff)
       Post #: 21682
RE: Welcome to Club SAITO ! - 4/30/2012 6:45 AM
Ernie Misner
Score: 130
Status: offline
A soft wire wheel on the bench grinder cleans and shines mufflers up ASAP. The key is using a soft wire wheel, they are right next to the hard ones on the shelf. No, it doesn't scratch them and actually sets the stage for polishing them if you want to do that.
Ernie Misner
Hide Signatures
       Post #: 21683
RE: Welcome to Club SAITO ! - 4/30/2012 1:31 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Tarasdad
Why do people insist on running castor in Saitos?
After having issues W/sticking exhaust valves/cam lobe wear running castor/synthetic Byron's 4 stroke fuel, I switched to all synthetic Cool Power & have had zero issues since. My engines run on Cool Power stored for 14 years were oiled through the breather & rocker boxes & fire up. No problems. The synthetic oil in Cool Power protects adequately from rust & does not gum up.
An FA 150 that was torn down after having 25+ gallons of cool Power run through it had no detectable wear in the cylinder or cam lobe. I fail to see where castor is needed for these engines especially when the possible issues W/its use are considered.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 21684
RE: Welcome to Club SAITO ! - 4/30/2012 1:48 PM
Hobbsy
Score: 650
Status: offline
These two valves ran in my high compression Saito 1.50 from 1992 to 2006 and never saw fuel without castor, in fact the first two seasons of its life it ran on Fox 15% fuel with 20% castor as did my Enya .46MKII. Neither engine ever had coked up valves nor did the valves ever stick.
Click to see fullsize image.
Click for fullsize
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 21685
RE: Welcome to Club SAITO ! - 4/30/2012 2:36 PM
radial1951
Score: 105
Last Login: 5/19/2013
Status: offline
There are certainly differing opinions here (and everywhere else) regarding the use of castor oil, especially in 4-strokes. I have several different brands of engines, a few Saitos, including 2 radials, but happen to have an OS FS81a (sorry). This is from the OS User Manual:
The FS -81 should be operated on a methanol based
fuel containing not less than 18% (volumetric) castor oil,
or a top quality synthetic lubricant (or a mixture of both)...
It seems that OS don't have a problem running even straight castor oil in their 4-strokes. I wonder why the Saitos are different...
Regards, RossG
radial1951
_____________
ORIGINAL: Hobbsy
[/quote]
Hide Signatures
(in reply to Hobbsy)
       Post #: 21686
RE: Welcome to Club SAITO ! - 4/30/2012 3:53 PM
blw
Score: 655
Status: offline
The rust issue is sometimes a hit and miss deal.
Coach Pat Dye
Hide Signatures
(in reply to radial1951)
       Post #: 21687
RE: Welcome to Club SAITO ! - 5/1/2012 11:28 PM
Ernie Misner
Score: 130
Status: offline
You won't see much castor carbon build up with out overly lean runs. Most folks would have witnessed the cam lobe wear with straight synthetic fuel it seems like. Could the Byrons 4-stroke fuel have possibly been one of the 4-stroke fuels that is quite low in overall oil content?
Ernie Misner
Hide Signatures
(in reply to blw)
       Post #: 21688
RE: Welcome to Club SAITO ! - 5/2/2012 12:27 AM
Ernie Misner
Score: 130
Status: offline
Heres a good demo on Saito bearing replacement. He uses the .82 here. I posted this as a new thread in the Engine forum as well. Thanks to Paul Swany and the Profile Bros. here.
>>> Edit - heck, the Profile Brotherhood's links won't work here. So if you are interested just go to the Profile Brotherhood's web site forums, Engines, and scroll down to Saito 82 bearing replacement thread.
http://www.****/forum/viewtopic.php?f=18&t=16472
Ernie Misner
< Message edited by Ernie Misner -- 5/2/2012 5:37 AM >
Hide Signatures
       Post #: 21689
RE: Welcome to Club SAITO ! - 5/2/2012 3:08 AM
Rv7garage
Score: 128
Last Login: 4/26/2013
Status: offline
Just a couple shots of a pretty Saito twin in its natural environment
#26 Club Saito ***CUB BROTHERHOOD*** #86
My full-scale build: www.rv7garage.blogspot.com
Hide Signatures
       Post #: 21690
RE: Welcome to Club SAITO ! - 5/2/2012 3:19 AM
Tarasdad
Score: 135
Status: offline
I remember the manual that came with my FA-80 recommending against castor oil. I used fuels with synthetic only and had no issues whatsoever. It's only when fuel with castor in the mix was used that I had issues. Now my Fox engines on the other hand....
Tarasdad
Hide Signatures
(in reply to Rv7garage)
       Post #: 21691
RE: Welcome to Club SAITO ! - 5/2/2012 3:23 AM
orthobird
Score: 105
Status: offline
WOW wow wubzy,
i am in love!!
what a beauty!!
wait a minute here, is that a glow ignition system?
that is way too cool!!
avoid crashing!!
Hide Signatures
       Post #: 21692
RE: Welcome to Club SAITO ! - 5/2/2012 3:38 AM
Rv7garage
Score: 128
Status: offline
Hide Signatures
(in reply to orthobird)
       Post #: 21693
RE: Welcome to Club SAITO ! - 5/2/2012 3:47 AM
blw
Score: 655
Status: offline
There was a Horizon induced contradiction on the castor issue. Saito always recommended using castor.
Coach Pat Dye
Hide Signatures
       Post #: 21694
RE: Welcome to Club SAITO ! - 5/2/2012 9:57 AM
Tarasdad
Score: 135
Status: offline
The instructions with my engine were from Japan, not the newer ones from Horizon. Saito-Engines.info has the relevant quote from them on their "Fuel" page. This doesn't appear in the instructions included with Horizon distributed engines, only in the original Saito instructions.
I'll keep to a castor free environment for my Saito engines.
Tarasdad
Hide Signatures
(in reply to blw)
       Post #: 21695
RE: Welcome to Club SAITO ! - 5/2/2012 11:54 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Tarasdad
The instructions with my engine were from Japan, not the newer ones from Horizon. Saito-Engines.info has the relevant quote from them on their ''Fuel'' page. This doesn't appear in the instructions included with Horizon distributed engines, only in the original Saito instructions.
The instructions I received W/my 1st FA 150 back in '97 recommended against castor. The newer manuals do not make such a recommendation.
Castor is old technology & some are resistant to change. There's just no reason for it in a ringed 4-stroke.
It's like people using synthetic oil in their cars & still cling to the 3,000 mile oil change belief.
Copy/paste from Saito-engines.info "fuel page" (bolding of text below added for emphasis)
A fuel with 10 to 15% nitro is fine, however higher nitro content (up to 30%) is suggested by Horizon Hobby to be OK (see also the section ‘Special Tricks’). More nitro does provide more power but the fuel cost does substantially increase with higher nitro.
Nitro content greater than 15% is not necessary. If you can afford to buy fuel with 20-30% nitro a bit more power is available, however you might be better off buying a larger engine, or a lighter model, if you are that desperate for more power.
The oil content recommended by Saito and Horizon Hobby is 20%. Horizon Hobby state that oil that is a blend of castor and synthetic is acceptable. Saito instructions (that no longer accompanies engines sold in the US) say the following: “Since the four-stroke engine has high exhaust temperature and carbon is apt to accumulate when castor oil type lubricants are used, avoid using fuel containing them.” This seems to imply Saito recommends fuel with no castor at all. It is not clear that 20% total oil content is really needed as 15-18% seems to work fine and is common with commercial fuels labeled for 4-stroke engines. It is really also unclear that all-synthetic, or a blend of castor-synthetic, is preferred; both are probably OK, however no more than 5% castor with the remainder synthetic oil is usually recommended. Byron 4-stroke fuel has a total oil content of 16% with about 3% castor and the remainder synthetic.
I have heard from some European Saito flyers who are mixing their own fuel with 10% total oil content. No adverse effects have been reported. However 15% to 20 % is a safer blend.
In summary, any commercial 2-stroke or 4-stroke fuel should be fine, provided you make sure the castor oil content is low, with mostly synthetic oil. The only difference between commercial 2-stroke fuels and 4-stroke fuels is the total oil content (4-stroke fuels typically have 2-3 % less total oil content compared to 2-stroke fuels).
[Saito Home Page]
Hide Signatures
       Post #: 21696
RE: Welcome to Club SAITO ! - 5/2/2012 1:30 PM
mike early
Score: 125
Status: offline
I use Wildcat and it's 80-20% synthetic-castor blend. It's wonderful. With changing weather conditions, I sometimes run it too lean and have never experienced any damaged from that.
Saito Club Member #578
P-40 Brotherhood #62
Hide Signatures
       Post #: 21697
RE: Welcome to Club SAITO ! - 5/2/2012 9:35 PM
blw
Score: 655
Status: offline
I'm sure some folks can run low oil content and synthetic and get away with it. Let's face it, some people aren't too interested in tuning their engines right, or they get it wrong until they learn. That's when engines get burned up with synthetic only fuel. Look at the old 72 with the old style backplate and chronic air leaks. The engine would unpredictably run lean. Bill Robison had some pretty good evidence of early cam wear with fuel without castor.
Coach Pat Dye
Hide Signatures
(in reply to mike early)
       Post #: 21698
RE: Welcome to Club SAITO ! - 5/2/2012 9:44 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: blw
So in other words, a properly tuned engine that is running properly does not need castor.
Better to tune properly than run an oil mix that will eventually gum things up as assurance that one doesn't burn up an engine W/poor tuning.
Hide Signatures
(in reply to blw)
       Post #: 21699
RE: Welcome to Club SAITO ! - 5/2/2012 11:11 PM
blw
Score: 655
Status: offline
You wouldn't need to worry about the gumming issue if a small percentage were used. Taking the right steps when storing engines goes a long way too.
Coach Pat Dye
Hide Signatures
       Post #: 21700
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.234RCU1
