RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  867 868 [869] 870 871 872 873 874 875 876   next >   >>
Login
RE: Welcome to Club SAITO ! - 5/2/2012 11:14 PM
w8ye
Score: 318
Last Login: 5/25/2013
Status: offline
If you are going to be this way - you must listen carefully to your engine - land and adjust the needle valve on a slight lean mixture infraction caused by the sun going behind a cloud or flying through a thermal.
I always feel of my engines when I land and have noticed them sometimes very dry when using a fuel with marginal oil content.
A four stroke can feel very dry to wiggle the prop on shutdown and you can still find some residual oil in the crankcase. I don't think the residual oil in the crankcase to be a good indication of your fuel's oiling capacity.
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 21701
RE: Welcome to Club SAITO ! - 5/3/2012 12:45 AM
mike109
Score: 148
Status: offline
G'day
In my club there are castor and non castor users. A few of the non castor users have no problems. They tune properly. But some others cook engines. They don't tune properly. The castor users (I'm one) don't cook engines but we do occasionally have blocked carbys when an engine was stored without being run completely dry and the fuel residue in the spray bar dries out and forms a plug. I'd rather have this problem than a cooked engine. The solution is usually to block the muffler and turn the engine over with the starter.
I have a Saito 120 in bits which was given to me to sort out. It has large black vertical stripes on the bore and I suspect it was close to being seized. It came from a non castor user who was notorious for lean tuning. It also has the muffler pipe threads ripped out, the mounting holes all over size and totally rusted bearings. Some people just have too much money and take no care of their engines.
So I guess it boils down to this. If you can tune you can use synthetic only fuel and have no problems. If you can't or are learning then a little castor is good insurance. After 50 years or so, I am still learning so I use castor.
Mike in Oz
"I just had no control. Must be the radio." Club Saito #597 Kadet Brotherhood #66
Hide Signatures
(in reply to w8ye)
       Post #: 21702
RE: Welcome to Club SAITO ! - 5/3/2012 1:18 AM
Tarasdad
Score: 135
Last Login: 3/31/2013
Status: offline
I re-tune my engines every flight session and check them before every flight to see if they need tweaking. I know others who follow the Ronco "set it and forget it" method and who are always complaining about poor performance. While I agree that castor can save an engine it is no substitute for basic good tuning habits (no pointed fingers or the like, just a statement of my own beliefs - heck, if I was to point fingers I'd have to start with my own dumb self).
Tarasdad
Club Saito #680; 2x Saito .91, Saito .80, Fox .50, Fox .25, Fox .19; Apprentice 15e; Tiger 60; Super Chipmunk
Hide Signatures
(in reply to mike109)
       Post #: 21703
RE: Welcome to Club SAITO ! - 5/3/2012 2:44 AM
blw
Score: 655
Last Login: 5/26/2013
Status: offline
I flew my 56 for almost 2 years without touching the needles. It gave good rpms in winter and hot, humid summers. A broken in, well tuned Saito will always be close once you get there. Any adjustments to the needle valves should require a trip around the traffic pattern a few times so you can listen to the engine. Land, adjust, test fly as necessary.
There are a number of things that can make an engine suddenly run lean. An engine running on 10% synthetic may not stand a chance if a pinhole develops. Minimum chances of it happening, but it does. Just another small reason for a little bit more protection.
Mike, filling the crankcase and cylinder with glow fuel helps too.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to Tarasdad)
       Post #: 21704
RE: Welcome to Club SAITO ! - 5/3/2012 3:27 AM
w8ye
Score: 318
Status: offline
But you ran Omega fuel
Original AMA #31261
Hide Signatures
(in reply to blw)
       Post #: 21705
RE: Welcome to Club SAITO ! - 5/3/2012 3:43 AM
FNQFLYER
Score: 110
Status: offline
I wonder how many people here use tachometers (tacho's to us here in OZ).
How many people have read the Saito instructions re oil type and content for the 56, not many I bet.  With O/t at the comps we have CD supplied fuel and the bun fights over having 20% synthetic as per Saito) for the 56 still rage.  Most CD's still like to mix castor in their fuel.
Me I follow the manufacturers recommendation, use a tachometer for tuning and my ears, though they are failing in the mid range (common fault with baby boomers and aircraft engineers in particular).
However competitions are different where one is out to extract the max performance possible to beat the pants of the "Mexicains/ Cockroaches", then all bets are off.
BTB for the Ozzies, blue skies little wind and typical FNQ weather for this time of the year.
Club Saito member 710
Hide Signatures
(in reply to w8ye)
       Post #: 21706
RE: Welcome to Club SAITO ! - 5/3/2012 4:47 AM
blw
Score: 655
Status: offline
Jim, yes I did run only Omega with a couple oz of Morgan's castor.
Coach Pat Dye
Hide Signatures
(in reply to FNQFLYER)
       Post #: 21707
RE: Welcome to Club SAITO ! - 5/3/2012 6:16 AM
StangFlyer
Score: 100
Last Login: 5/20/2013
Status: offline
Oh my... a thread right up my alley. I have owned many types of RC engines. Started with O.S. and soon went to Saito. I have also owned a Quadra and a ZDZ inline 80cc Twin. I am currently fixing to get a monster motor for my Monster Don Smith Mustang. However staying with the thread, my O.S.'s were good, but nothing compares to my Saito's. Well, Except for my O.S. Gemini 160 Twin and my O.S. Pegasus 320 flat four. My Saito's have consisted of a Saito Radial 450, (2) 180's, (2) 150's, A very awesome running 72. Do you think I could get Saito to make me an inline 880, (four 220 jugs) for my Don Smith? Now wouldn't that be sweet? What a nice little thought huh?
Happy Modeling Everyone. And remember, If'n ya ain't inverted, Ya ain't doin' it right!!!
Hangar 9 150 Mustang, Saito 180
Goldberg Sukhoi, Saito 180
40 year old Top Flite Mustang, Saito 72
Matt Chapman Cap 232, O.S. 70
Oh and many others too.... :-)
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to balsa brain)
       Post #: 21708
RE: Welcome to Club SAITO ! - 5/3/2012 8:26 AM
radial1951
Score: 105
Last Login: 5/24/2013
Status: offline
Hi Stangflyer,
I really don't think four Saito FA220 cylinders will be man enough for that job.
Saito don't make anything over 75cc, so you're out of luck for a decent engine for your monster P-51. Or are you...?
Well this one's a bit noisy, but it's ok...   http://www.youtube.com/watch?v=AmYbW4o5PRk
If the above won't do the job, then you should talk to Detlef about one of his Phoenix V-4s.
http://www.rcscalebuilder.com/forum/forum_posts.asp?TID=14640&PN=1&TPN=70
The perfect replacement for a Packard-Merlin...
Regards, RossG
radial1951
_____________
quote:
ORIGINAL: StangFlyer
Oh my... a thread right up my alley. I have owned many types of RC engines. Started with O.S. and soon went to Saito. I have also owned a Quadra and a ZDZ inline 80cc Twin. I am currently fixing to get a monster motor for my Monster Don Smith Mustang.... Do you think I could get Saito to make me an inline 880, (four 220 jugs) for my Don Smith? Now wouldn't that be sweet?
< Message edited by radial1951 -- 5/3/2012 8:51 AM >
Hide Signatures
(in reply to StangFlyer)
       Post #: 21709
RE: Welcome to Club SAITO ! - 5/3/2012 8:38 PM
SRQFlyer
Score: 100
Status: offline
Hi All,
I just picked up a Saito FA45 [marked as series "G"] intending to use it - maybe in an oldtimer. Well, I was surprised to see that it appears to have never been run or even mounted. There is absolutely no gum or soot anywhere on the valves or at the exhaust port. The plug hole appears to never have had a plug in it also. There is some very slight rust on the prop washer, nut and shaft and on the inside of some of the bolts' sockets.
I like to run my engines, especially all my Saitos. I thought that maybe a "collector" might be interested in this one, considering the condition? There is no box or paperwork or tools. Let me know (PM best) if anyone wants it for display before I "test" it!
Jim
AMA 106594, CG Ult 10-300 Bro #38, Club Saito #699 (45, 50, 56, 2x72, 82, 91, 120, 2x 150)
Hide Signatures
(in reply to radial1951)
       Post #: 21710
RE: Welcome to Club SAITO ! - 5/3/2012 8:48 PM
Hobbsy
Score: 650
Status: offline
I recon it looks like this one, its a keeper but probably not a collector yet. Nice find.
Woops, ignore the fact that this one has the rocker covers removed.
Click for fullsize
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to SRQFlyer)
       Post #: 21711
RE: Welcome to Club SAITO ! - 5/3/2012 8:56 PM
SRQFlyer
Score: 100
Status: offline
Hobbsy,
Yep - that's the one. If I decide to run it - maybe a wide-blade 11x6 prop? If I remember right, these weren't real powerful.
Jim
Hide Signatures
(in reply to Hobbsy)
       Post #: 21712
RE: Welcome to Club SAITO ! - 5/3/2012 9:27 PM
Hobbsy
Score: 650
Status: offline
It has more power than the .40 than you would think. That 11x6 should be perfect.
Hide Signatures
       Post #: 21713
RE: Welcome to Club SAITO ! - 5/7/2012 2:39 AM
orthobird
Score: 105
Status: offline
hello
i need help
advice
i have a saito FG 36 that was, yes, i said, was
on a DYnaflite super decathlon.
today was its last flight,
RIP
it was, however, the best flight to date.
over 6 minutes of flight before dreaded nose dive into farm field.
i shut engine down right before impact.
during the CSI and autopsy,
i have removed the engine and ispected it.
i do not see a bent valve pushrod cover,
however, after removing the spark plug, it is very difficult to turn the crankshaft, i still can, but it is not smooth
i do see both valves do open (not at same time) as i rotate the crankshaft.
does anyone have any advice.
this is a video of the flight:
http://www.youtube.com/watch?v=fPU_L7U0UUI&feature=channel&list=UL
avoid crashing!!
Hide Signatures
       Post #: 21714
RE: Welcome to Club SAITO ! - 5/7/2012 2:58 AM
earlwb
Score: 584
Status: offline
It is very likely that the crankshaft was pushed back slightly within the crankcase. When the engine is hot from running, it is easy for it to happen. You need to disassemble the engine some, then heat the crankcase to expand it but still have the bearings more cool, then reseat the crankshaft forward. You'll likely need to reseat the drive washer and collet too. While you are at it, after reseating the crankshaft, check the crankshaft tip to ensure it didn't get bent on you too.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to orthobird)
       Post #: 21715
RE: Welcome to Club SAITO ! - 5/7/2012 3:34 AM
orthobird
Score: 105
Status: offline
ok earl
thank you so much
it seems to me like that is it
the crankshaft itself was not bent
as the plane went into earth exactly perpendicular to the earth.
i will do it
thanks again.
i will update you on progress
avoid crashing!!
Hide Signatures
(in reply to earlwb)
       Post #: 21716
RE: Welcome to Club SAITO ! - 5/7/2012 3:44 AM
Mein Duff
Score: 105
Status: offline
In watching your last flight video... I wonder also if your model was tail heavy or you weren't using adequate rudder in your turns?
Also it seems you were flying quite a distance away while doing wild manouevers....not a good recipe
Good luck fixing the engine, Earl's advice is a good place to start.
Fleet Brotherhood #5
Half A Wing, Three Engines and A Prayer
Hide Signatures
       Post #: 21717
RE: Welcome to Club SAITO ! - 5/7/2012 5:31 AM
orthobird
Score: 105
Status: offline
thank you all
the engine is fixed.
1.  cleaned engine thoroughly with WD40
2. wiped it down clean
3.  removed the muffler
4.  removed the spark plug
5.  removed the carb intake
6.  removed crankcase cover
7.  upon doing so, the crankshaft moved freely.
8.  placed engine in heavy duty vise
9.  used heat gun to heat rear aspect of cranckase, directly over crankshaft
10. after 20 seconds or so, i used a large tamp, and gently gave 2 blows, and the gap in between the crankcase and shaft taper collet, immediately was restored.
11. cleaned it all up and put everything back together.
12.  thank you all
regarding the flight:
this plane is very difficult to control, i was not trying to do wild maneuvers, this is just the nature of this plane, it is wild.  most difficult plane i have ever flown, but this was by far the best flight it had, over 6 minutes, until its death.
the plane was balanced front to rear and the CG was at the recommended area.  you should have seen this plane on its first flight.  it was really tail heavy,  it was a miracle i was able to land it.  since then, i had moved all servos as far froward, and placed two battery packs directly under gas tank.  with this, i was able to remove the 16 ounces of extra weight i had placed under nose of bird after the 1st flight.
this airplane was a major learning experience for me, this was the 10th plane i have had.  but this one, i built myself from a dynaflite, and one mistake was that i built plane on a cheap plastic fold down table.
i have just purchased a 10 foot long work bench table from a company in california with a solid thick wood top that should be very flat.
i have learned that a true and straight bird begins on the bench, and the one i had to build at first was a bad one.  this plane was never true.
thanks again for all comments, now i have to find a new bird for this engine, i was thinking of getting the RC guys sup decathlon.
avoid crashing!!
Hide Signatures
(in reply to Mein Duff)
       Post #: 21718
RE: Welcome to Club SAITO ! - 5/7/2012 11:14 AM
Tarasdad
Score: 135
Status: offline
Yep, a straight build makes flying a whole lot easier.
Glad to dee your engine is back in working order. I really love the sound of my Saitos and would love to get some of their gassers but just can't afford 'em. I know if I did have one and it ws in a crash like that I'd be a wreck as well as the plane!
Tarasdad
Hide Signatures
       Post #: 21719
RE: Welcome to Club SAITO ! - 5/7/2012 6:44 PM
mike early
Score: 125
Last Login: 5/19/2013
Status: offline
That plane might have had too much elevator throw or something.
Saito Club Member #578
P-40 Brotherhood #62
Hide Signatures
       Post #: 21720
RE: Welcome to Club SAITO ! - 5/7/2012 10:05 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: mike early
That's what I was thinking too much control surface throws.
I like to program in some exponential. It helps eliminate the control sensitivity but still allows positive control if you need to get out of a tight spot.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to mike early)
       Post #: 21721
RE: Welcome to Club SAITO ! - 5/7/2012 10:42 PM
blw
Score: 655
Status: offline
You made the effort to build it, so don't knock on your hard work. It looked pretty good in the video. It seems to me that the model was unstable and on the verge of snapping out of control all the time.
Coach Pat Dye
Hide Signatures
       Post #: 21722
RE: Welcome to Club SAITO ! - 5/7/2012 11:30 PM
mike early
Score: 125
Status: offline
quote:
ORIGINAL: SrTelemaster150
Good point. Less throw and more expo perhaps.
Hide Signatures
       Post #: 21723
RE: Welcome to Club SAITO ! - 5/9/2012 1:02 PM
Old Fart
Score: 158
Status: offline
Maybe true.To me it looked like the pilot flew it one minute and not the next.The fg36 sure sounded good.
Watch out for the ground eh?
Hide Signatures
       Post #: 21724
RE: Welcome to Club SAITO ! - 5/10/2012 12:00 AM
FNQFLYER
Score: 110
Status: offline
I had a model, my first build in Malaysia (a Pilot Zlin as I remember) and it performed the same way with almost the same result, it landed flat and rekitted itself.  When we checked the engine thrust line we found 2 degrees up thrust (and that was assuming the firwall was installed in true vertical.  Made for an interesting flight and an expensive purchase of an ajustp jib for futire building, no further troubles in that area in the ensuing 20 + years.
A good solid bench with flat surfaces to build on are first the building blocks to good models.
I have noted that bit about the crak shaft, haven't done it that way but I will definitely check it out shoud the situation necessitate it
Hide Signatures
(in reply to Old Fart)
       Post #: 21725
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.281RCU1
