RE: Welcome to Club SAITO !    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  868 869 [870] 871 872 873 874 875 876 877   next >   >>
Login
RE: Welcome to Club SAITO ! - 5/10/2012 3:50 AM
the pope
Score: 101
Last Login: 6/19/2013
Status: online
The ground did that plane a favour . I would have landed that thing straight away , flying around while its flying like that aint good . Reminded me of a dog that drags its @rse on the groung . Good luck with the next one, cheers the pope
Hide Signatures
(in reply to FNQFLYER)
       Post #: 21726
RE: Welcome to Club SAITO ! - 5/12/2012 1:24 AM
Homer712
Score: 100
Last Login: 5/2/2013
Status: offline
Quick question to those of you that have a lot more experience with Saito then myself. I have two Saito engines, both less then a year old. An FA-62 and an FA-72. In the manual, both engines are listed as having a 7 mm prop shaft. If I use my Fox metric prop reamer and ream out an APC prop to 7 mm, the prop will fit perfectly on the 62, but will not slide onto the 72, even if I try to force it on with the prop nut. To get a prop to slide onto the 72 I need to ream it out to 5/16". Any one else run into this? Is there a misprint in the Saito manual?
_____________________________
Cub Brotherhood #57
Club Saito #802
Hide Signatures
(in reply to the pope)
       Post #: 21727
RE: Welcome to Club SAITO ! - 5/12/2012 1:34 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Homer712
Quick question to those of you that have a lot more experience with Saito then myself. I have two Saito engines, both less then a year old. An FA-62 and an FA-72. In the manual, both engines are listed as having a 7 mm prop shaft. If I use my Fox metric prop reamer and ream out an APC prop to 7 mm, the prop will fit perfectly on the 62, but will not slide onto the 72, even if I try to force it on with the prop nut. To get a prop to slide onto the 72 I need to ream it out to 5/16''. Any one else run into this? Is there a misprint in the Saito manual?
Since 5/16" is about .002" smaller than 8mm I would suspect that your 72 has an 8mm prop shaft.
It may well be that although they both have 7mm prop nut threads, they do not have the same sized shafts.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to Homer712)
       Post #: 21728
RE: Welcome to Club SAITO ! - 5/12/2012 2:05 AM
KenD
Score: 100
Status: offline
The FA-72 prop shaft is 8mm, the threaded portion is 7mm.
KenD
Club Saito Member #773
AMA 64943
IMAA 23743
Hide Signatures
       Post #: 21729
RE: Welcome to Club SAITO ! - 5/12/2012 2:10 AM
Homer712
Score: 100
Status: offline
Boy, this is always the place to come for answers. Thanks guys. I reamed out an APC prop to 8 mm and it slid onto the 72 nice and snug.
Cub Brotherhood #57
Club Saito #802
Hide Signatures
(in reply to KenD)
       Post #: 21730
RE: Welcome to Club SAITO ! - 5/12/2012 7:35 AM
Ernie Misner
Score: 130
Last Login: 6/12/2013
Status: offline
If I remember correctly the 72 and 82 do have 7mm threads but the prop itself sits on a larger shaft where the threads end. You just have to keep on reamin'......
Ernie Misner
Hide Signatures
       Post #: 21731
RE: Welcome to Club SAITO ! - 5/13/2012 12:38 AM
mike early
Score: 125
Last Login: 6/18/2013
Status: offline
The cylinder wall and the piston on my .91 are scored in one small area. Is the cylinder wall coated with some other metal? Or can I try to buff it out?
Saito Club Member #578
P-40 Brotherhood #62
Hide Signatures
(in reply to Ernie Misner)
       Post #: 21732
RE: Welcome to Club SAITO ! - 5/13/2012 2:32 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: mike early
Is it scored or does it have streaks?
If you can't feel it W/a fingernail it isn't scored.
If it is scored, it's toast.
The cylinder wall is hard crome plating over aluminum. (AAC aluminum piston/aluminum cylinder/chrome lined bore)
Hide Signatures
(in reply to mike early)
       Post #: 21733
RE: Welcome to Club SAITO ! - 5/13/2012 2:33 AM
orthobird
Score: 105
Status: offline
just installed my new saito fa 100 GK on a twist 40.
what a beauty.
turned engine on, very easy.
what a beautiful sound
running 15% nitro with 19% oil
pics to come.
avoid crashing!!
Hide Signatures
       Post #: 21734
RE: Welcome to Club SAITO ! - 5/13/2012 2:37 AM
orthobird
Score: 105
Status: offline
maiden flight this monday, weather permitting.
this is my second saito engine.
Click to see fullsize image.
Click for fullsize
Click for fullsize
avoid crashing!!
Hide Signatures
(in reply to orthobird)
       Post #: 21735
RE: Welcome to Club SAITO ! - 5/13/2012 3:02 AM
mike early
Score: 125
Status: offline
quote:
ORIGINAL: SrTelemaster150
It's toast. can feel it with finger. far worse than what a fingernail requires...
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 21736
RE: Welcome to Club SAITO ! - 5/13/2012 4:45 AM
SeamusG
Score: 199
Last Login: 4/10/2013
Status: offline
Should I be concerned ...
During the disassembly of my Saito FA-82a I removed the drive flange and tapered collet. A gentle tap of the exposed threaded shaft of the crank end on a soft composite wood surface freed the crank from the case. The main bearing came with the crank. It's very easy to seat the crank/bearing into the case and remove with my fingers. Both bearings turn smoothly and without noise.
Like I said - should I be concerned?
Click for fullsize
Hide Signatures
       Post #: 21737
RE: Welcome to Club SAITO ! - 5/13/2012 6:27 AM
FNQFLYER
Score: 110
Status: offline
Had a YS 63 like that once (being the operative word).  The bearing spun in the case and the rest is history. If it isn't a firm to tap fit I use some locktite glue on it and then guarrenteed not to cause a problem.  When you buy the locktite also buy a bottle of debonder saves tears later on
Club Saito member 710
Hide Signatures
(in reply to SeamusG)
       Post #: 21738
RE: Welcome to Club SAITO ! - 5/13/2012 7:03 AM
Ernie Misner
Score: 130
Status: offline
Saito 100 on the 40 size Twist??? Far out man! .... but will it balance? Watch out for that plastic spinner on a powerful 4-stroke. Don't stand near by and wear your safety equipment. Let us know what it's like with all that power.
Ernie Misner
Hide Signatures
       Post #: 21739
RE: Welcome to Club SAITO ! - 5/13/2012 12:22 PM
Old Fart
Score: 158
Status: offline
You are so funny ernie,safety equipment in a fun zone??
Watch out for the ground eh?
Hide Signatures
       Post #: 21740
RE: Welcome to Club SAITO ! - 5/13/2012 1:53 PM
orthobird
Score: 105
Status: offline
yes, still slighlty tail heavy at 4 inches aft from LE, but at 4.5 inches, it balances out.
there is a post in rc universe that i stumbled upon last night where someone did same combo.
http://www.rcuniverse.com/forum/m_6048187/anchors_6048470/mpage_1/key_/anchor/tm.htm#6048470
Click for fullsize
< Message edited by cshahrdar -- 5/13/2012 2:31 PM >
avoid crashing!!
Hide Signatures
       Post #: 21741
RE: Welcome to Club SAITO ! - 5/13/2012 5:38 PM
mudboger07
Score: 100
Last Login: 5/28/2013
Status: offline
I need some info from the experts, A friend has a brand new saito 125 that will not complete one flight without the valves coming out of adjustment, we have readjusted them both intake and ex, flew one flight and they are out again, we disasembled the top end cleaned and even added lock tight (blue) and still they come out of adjustment, does anyone have any ideas why this would happen?
Ken
Ken
Club Saito #732
Hide Signatures
       Post #: 21742
RE: Welcome to Club SAITO ! - 5/13/2012 5:47 PM
JohnB96041
Score: 110
Status: offline
Never heard of valve getting out of adjustment that quick. Describe the "out of adjustment" in more detail. I have 3 Saito 1.25 engines. Did the breakin according to the manual, ran about a gallon of fuel through the engines while flying, adjusted the valves and have not had to do it again, so far. Three years of flying. Are you sure that you are adjusting the valves according to the manual? Did you set the lock nut after adjusting? Was the gap still what is should be after locking the lock nut? The settings can slip when tightening the locknut and it will open the gap.
Hide Signatures
(in reply to mudboger07)
       Post #: 21743
RE: Welcome to Club SAITO ! - 5/13/2012 5:57 PM
mudboger07
Score: 100
Status: offline
quote:
ORIGINAL: JohnB96041
Hey John, This is the first one we have had do this, and we both have quite a few saitos, we made sure after sdjusting the valves they were still in adjustment, we set the lock nut and rechecked. The gap was the same after setting and after seting the lock nut, sometimes it will hold for one flight but most of the time after just a few minutes it comes loose the the point there is over a 60 thousand gap I dont have the manual in front of me but if i remember correctly they set at 4 thousants. also the lock nuts are not loose or any other part of the valve train is loose, Im starting to wonder if something liek the rocker arm is bending? I do know the push rod is straight.
Ken
Club Saito #732
Hide Signatures
(in reply to JohnB96041)
       Post #: 21744
RE: Welcome to Club SAITO ! - 5/13/2012 6:14 PM
JohnB96041
Score: 110
Status: offline
Just a thought. If you have had the push rods out of the engine, were they put back in the same direction. I don't know is there is a difference in the ends of the push rods, but there could be. I would call HH tech support and get some help. A cracked rocker arm would really do the trick. You should be able to see if the rocker arm is bent or bending. Look for a crack on the bottom side of the rocker arm near the retaining pin.
Hide Signatures
       Post #: 21745
RE: Welcome to Club SAITO ! - 5/13/2012 7:09 PM
mudboger07
Score: 100
Status: offline
Will do John, its stumped us too, both of us are really good at engines thats why were so stumped...lol we havent seen anything broke, looked bent etc.  its got us totally stumped.
Ken
Club Saito #732
Hide Signatures
       Post #: 21746
RE: Welcome to Club SAITO ! - 5/13/2012 7:12 PM
retransit
Score: 125
Last Login: 6/16/2013
Status: offline
This may be a bit simplistic, but did you adjust the valves on compression stroke?
Bob
Fleet Brotherhood #1
Club Saito #800
Hide Signatures
       Post #: 21747
RE: Welcome to Club SAITO ! - 5/13/2012 7:21 PM
SeamusG
Score: 199
Status: offline
This is an FA-82a pic to demonstrate the difference in the push rod ends. If the rounded ends (not the pointed ends) were installed towards the rocker arms, no way would (could) they stay in the "hollow" of the rocker adjusting screw. When they become disconnected from the adjusting screw the gap jumps to 1/8" from .0025".
Click for fullsize
Hide Signatures
(in reply to retransit)
       Post #: 21748
RE: Welcome to Club SAITO ! - 5/13/2012 10:59 PM
mudboger07
Score: 100
Status: offline
quote:
ORIGINAL: JohnGilmore
John, ya the pointed in are facing the rocker arms, thats whats wierd, like i said weve never had this kinda issue before, its probably ganna be something simple that were over looking, he just ordered all new valve train parts so well see when he gets back from joe nall.
Ken
Club Saito #732
Hide Signatures
       Post #: 21749
RE: Welcome to Club SAITO ! - 5/13/2012 11:06 PM
radial1951
Score: 105
Last Login: 6/10/2013
Status: offline
Hi Ken
Some thoughts on your problem. Let's assume:
1.   At the end of the flight, the adjusting screws and lock nuts are still tight and have not moved. (You might be able to check this by degreasing the parts and trying a tiny dab of correction fluid on the screw, nut and rocker. If it sticks ok, you will see if any component has moved during the run).
2.   The rockers aren't brocken, the tips of the valves and rocker tip are not suffering massive wear, and the same for the pushrods i.e.  they are the same length after the run.
3.   All other engine screws are tight and nothing else is apparently loose.
NOW, the problem moves down to the components activating the pushrods i.e.  Tappets (Part 38) ;  Cam Gear (Part 35) ;  Cam Gear Shaft (Part 36).
If this problem has occurred quite a few times, any wear on those components will be more than obvious!
Regards, RossG
radial1951
______________
quote:
ORIGINAL: mudboger07
Ken
Hide Signatures
       Post #: 21750
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.875RCU1
