RE: Welcome to Club SAITO !
Tower Hobbies
Logged in as Guest
Users viewing this topic: isaacslaw
  Printable Version
Touchstart Remote Controlled Autostart Engine .61 ASP COLLECTORS !!!!!!!!!!!!!!
Seller:  vidal_felipe
Details:   $499.00   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Welcome to Club SAITO !
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: Welcome to Club SAITO ! - 9/15/2005 12:08:33 PM
SigMan
Status: offline
oops! sorry Bill...my bad !
_____________________________
Club Saito Member #1
AMA# 542304
(in reply to bigphil)
       Post #: 201
RE: Welcome to Club SAITO ! - 9/15/2005 12:31:12 PM
PlaneKrazee
Status: offline
< Message edited by Skypilot_one -- 9/30/2005 5:27:19 AM >
KB1DTB
AMA11123
       Post #: 202
RE: Welcome to Club SAITO ! - 9/15/2005 1:01:28 PM
William Robison
Status: offline
Phil:
I don't make a big thing out of my name being misspelled anymore, I used to be really picky about it. Now, so long as official documents get it right I'm happy.
Oh well.
Bill.
< Message edited by hobbsy -- 9/19/2005 3:33:00 AM >
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
       Post #: 203
RE: Welcome to Club SAITO ! - 9/15/2005 1:16:52 PM
William Robison
Status: offline
All manglers of my name:
Apologies acccepted.
Bill.
< Message edited by William Robison -- 10/30/2005 6:37:07 AM >
(in reply to William Robison)
       Post #: 204
RE: Welcome to Club SAITO ! - 9/15/2005 1:23:27 PM
William Robison
Status: offline
All:
Current member list is here in post numbers 77 and 78. Number 77 is in alphabetic order, #78 is in numeric order.
Bill.
       Post #: 205
RE: Welcome to Club SAITO ! - 9/16/2005 4:28:44 AM
khodges
Status: offline
William-or Bill, or Will, or Mr. Robison, when you speak of "mushroomed" cams, are you speaking of a shape that increases the length of time the valve is fully open? I know this is somewhat different from duration, which I mean to be the time the valve begins to open until it is fully closed again. Does this improve scavenging as much as it does total airflow?
When I was roadracing (motorcycles) back in the '80's, we messed with cam grinds, overlap, and modifying the total timing (valve) to change the power band to suit track conditions.
When is Saito gonna get with the plan and come out with a 4- or 5- valve design? The top end would be pretty busy at 11 grand, wouldn't it?
The "other" RobiNson--Will Robinson, of "Lost in Space" from the '60's WARNING! WARNING! You are in grave Danger, Will Robinson--remember the robot?
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
       Post #: 206
RE: Welcome to Club SAITO ! - 9/16/2005 4:56:22 AM
William Robison
Status: offline
KH:
Not mushroomed cams, but the tappets. The increased diameter of the cam end of the tappet will increase the valve duration and overlap with no other change. In the first attached picture the plain tappets are in the left column, what I call "Mushroomed" tappets are on the right.
This composite shows all the external differences between the old style big block engines and the "High Cam" versions. Also shown is the original "S" cam, just used for a short time in the original FA-120S. If you see a 120 with a curved intake pipe instead of the cast pipe it's an "S" model, the hot one. The later "S" 120s had the cast pipe and a normal cam, but still with the wide headed tappets so they were still a bit hotter than the early ones.
Second picture is the hot "S" 120. See the intake? Third picture is the standard 120 cylinder next to the "S", both shown with the intake pipe. Finally, current production FA-120S showing the return to the cast intake.
Bill.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to khodges)
       Post #: 207
RE: Welcome to Club SAITO ! - 9/17/2005 12:54:13 AM
William Robison
Status: offline
All:
Just found another picture of the hot version of the FA-120S, shows the intake pipe better, and you can see the muffler that came with it. Second picture is the outlet end of the muffler. Exhaust restriction? What's that?
Haw.
Bill.
Click for fullsize
Click for fullsize
       Post #: 208
RE: Welcome to Club SAITO ! - 9/18/2005 1:06:27 PM
beelzebubishere
Status: offline
This is just WRONG!
My new Saito 56 came in from Cheif this week, but was busy, and didn't open the package till Friday.....I'm supposed to put THIS, in a model airplane?
It's a....JEWEL...it oughta be on display somewhere....and I'm gonna cover it up in a J-3 cowl....this is just wrong....now I want another one, or 2....well, let's just say MORE!
