iflynething
NC, USA Status: offline
The guy I bought my Triton from acutally said that he doesn't even trust using the cycle function. He said that if you wanted to cycle a battery, just use the charge function, then discharge, then charge, or whatever you have to do. I don't know why the cycle function doesn't work properly, but the LHS guy said he doesn't trust those numbers. I konw sometimes when I get everything right, the cycle function works just fine. I first use the charge function and completly charge the battery. Then I use the DISCHARGE>CHARGE function and that gives me very reliable results. If I just do charge>discharge or discharge>charge, then I don't get the right number, but if doing the above sequence, then I get the good stuff! ~Michael~
_____________________________
Michael Carr Funtana, S100, Fut. 3050 / Rap 30, OS 32, JR 537, Fut. 401
