Servo help please
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Radio Equipment >> Servo help please
Page: [1]
Login
Servo help please - 10/26/2002 1:50:46 AM
carrera-RCU
Status: offline
just got myself a new Hitec HS-525MG servo to use for the steering on my Schumacher XTR...all fine for about 2 minutes....now the servo will not respond at all whatso ever to any inputs from my controller....it just sits there gong into little spasms, going from lock to lock and vibrating...etc....it does this in both steering and throttle channels. neither of my futaba 3003 servos are having this problem when tested.
only thing i can think of is that it's a bit thundery outside so theres a bit of static in the air....but both futaba servos are working fine.....help please.
thanks
_____________________________
'don't cry because its over, smile because it happened'
       Post #: 1
Servo help please - 11/22/2002 8:00:47 PM
RURC
Status: offline
First make sure that the wiring is correct. I have hi tech servos and futaba radio gear in my XTR and my Top Speed 1/8. I have had no glitches. Check that the radio dose not have a cut in the antenna. Now on my Schumacher cat 2000 buggy with all futaba, i had glitches galore. I had to replace the servo. that servo works without a fault in my RC-10. Don't ask me why. With the way the set is stacked up I would really replace the servos not just plug in others. You need to totally replicate the condition. Change it out 1 part at a time. Nitros are not known for glitches like electrics. Keep the "bad" part. It will most likely work fine in something else. It is usually a combination that will not work together. The problem with my Cat I mentioned will replicate itself if I put the receiver and the servo together in my RC-10. Good luck keep me informed.
3 Phase Racing / Schumacher
Max Amps / Tekin Racing
(in reply to carrera-RCU)
       Post #: 2
Servo help please - 11/26/2002 9:00:18 PM
carrera-RCU
Status: offline
thanks for the reply....sorted the problem....just sent the hi-tec servo back and got myself a tasty Futaba S9402 coreless servo...cost twice as much as the hi-tec, but it's taken all the abuse i've thrown at it so far...
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU1
