Eclipse 7 to be issued in Jan. 2003
Tower Hobbies
Logged in as Guest
  Printable Version
Low profile on/off switch with external charging jack
Seller:  k4lpcm
Details:   $14.99   |  9/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Eclipse 7 to be issued in Jan. 2003
Page: [1]
Login
Eclipse 7 to be issued in Jan. 2003 - 10/26/2002 4:03:06 AM
Rani34
Status: offline
Would the new Eclipse 7 to be issued in Jan 2003 have:
FM and PCM combined capability or there would a newer model with only PCM capability?
Would the PCM receiver be significantly more expensive compared to your Supreme Universal model?
Rani
       Post #: 1
Eclipse 7 to be issued in Jan. 2003 - 10/26/2002 4:13:28 AM
MikeMayberry
Status: offline
The new version of the Eclipse will be both FM and PCM capable. The new "Q" PCM receiver will cost more than the FM but I don't know exactly how much at this time.
FYI: "Q" stands for quick. The new QPCM receiver will have the fastest responce of any PCM reciever on the market.
Mike.
(in reply to Rani34)
       Post #: 2
Eclipse 7 to be issued in Jan. 2003 - 12/17/2002 3:34:54 AM
John Wells
Status: offline
Hi Mike, will we be able to upgrade our existing Eclipse radios?
JW
       Post #: 3
Eclipse 7 to be issued in Jan. 2003 - 12/17/2002 9:36:37 PM
MikeMayberry
Status: offline
Yes.
       Post #: 4
Eclipse 7 to be issued in Jan. 2003 - 12/17/2002 11:35:05 PM
hilleyja
Status: offline
[QUOTE]Originally posted by MikeMayberry
Yes. [/QUOTE]
When will this service be available? Is there a cost for this and if so how much?
_____________________________
Jim Hilley
AMA #671825
RCCA# 758
Twist 150 Brotherhood #14
       Post #: 5
Eclipse 7 to be issued in Jan. 2003 - 12/17/2002 11:49:58 PM
adrian-RCU
Status: offline
what about the crow problem will the new model have the upgrade
       Post #: 6
Eclipse 7 to be issued in Jan. 2003 - 12/18/2002 2:12:46 AM
MikeMayberry
Status: offline
We have not determined how the upgrade will be implemented yet. When we do it will be posted on our website.
No, there have been no major software changes other than adding QPCM and a couple minor changes. The model name shows up at start up and the trims automatically display on the when accessed.
Mike.
       Post #: 7
Eclipse 7 to be issued in Jan. 2003 - 12/18/2002 5:30:52 PM
adrian-RCU
Status: offline
great thanks but looking forward to software update we like our eclipse and when it can handle crow with throttle it will be with the 9 futaba and others
       Post #: 8
Eclipse 7 to be issued in Jan. 2003 - 12/19/2002 4:58:19 AM
David_Moen
Status: offline
Add my voice to those looking for crow in the acro mode! I was holding off my purchase decision to see if this feature would be added.
Given that there are open mixes available on this TX wouldn't it be possible to set up crow "manually"?
       Post #: 9
Eclipse 7 to be issued in Jan. 2003 - 12/19/2002 5:19:49 AM
MikeMayberry
Status: offline
Crow on one switch is not possible but you get it to work with two.
Mike.
       Post #: 10
Eclipse 7 to be issued in Jan. 2003 - 12/19/2002 8:07:21 PM
adrian-RCU
Status: offline
interesting- we will check this two switch to crow with throttle out
       Post #: 11
Eclipse 7 to be issued in Jan. 2003 - 12/20/2002 12:30:30 AM
David_Moen
Status: offline
If it can be done with 2 switches, can the setting then be saved as a "flight condition".
       Post #: 12
Eclipse 7 to be issued in Jan. 2003 - 12/26/2002 7:36:01 AM
bamapilot
Status: offline
I also think another item is very important - the ability to use two channels for elevators. There are a couple of ways to do it - but none are close to acceptable to me. Very poor programming that needs to be changed.
       Post #: 13
Eclipse 7 to be issued in Jan. 2003 - 12/26/2002 11:19:05 PM
David_Moen
Status: offline
Why would you need to run seperate channels for elevators? Obviously you would have two elevator servos, but why wouldn't running them off a Y-cable be satisfactory?
       Post #: 14
Eclipse 7 to be issued in Jan. 2003 - 12/26/2002 11:59:07 PM
hilleyja
Status: offline
[QUOTE]Originally posted by David_Moen
Why would you need to run seperate channels for elevators? Obviously you would have two elevator servos, but why wouldn't running them off a Y-cable be satisfactory? [/QUOTE]
You can't run dual servos for elevator with a Y-cable unless one servo is setup to run in a different direction. This is possible with re-wiring or a reversing device.
If you run each servo from a separate RX channel and you either have mixing available or "ailevator" function you don't need the reverser. The ideal is the "ailevator" function because then you can set up each servo to its physical neutral, travel extents, and in-the-case-of digital servos the deadpan. You want to do this so you can get each elevator half to operate exactly as the other -- prevents the elevator from acting like an airlon. Some really experienced flyers also like to add some extra functionality like coupling the elevator halves with the airlons, etc.
Jim Hilley
AMA #671825
RCCA# 758
       Post #: 15
