mzd -> RE: Electric Lanc Build (5/30/2006 1:02:15 PM)
Few a things I've learnt along the way. My first few flights were with a 7 cell 2.4A/hr Nicad pack. It only just flew. Heart was in my mouth all the way. These flights were done with only wings covered. Once I knew it flew, then I finished it. If you fly at scale speeds, all controls (including throttle) take time to respond. Fly it onto the ground. If you back off the throttle too early, the sink rate will catch you out. Have wiped out the under carriage twice so far. Have just put ply plates in the wheel wells glued to ply dihedral braces and leading edge, and installed a more springy set of legs. With my LiPo setup, I'm pulling around 35Amp for take off and climb, throttling back to around 20Amp for cruise, flight time a good 15min. Bear in mind that mine only weighs 2.1kg. If I was building now, I would probably choose the Tower Pro BM2410-12 outrunners. Can now get them with controllers for less than I bought the Aeronaut's alone and have loads of power to spare. It has an incredible presence in the air and the four gearboxes whining sound awesome.
