gouda
MN, USA Status: offline
That is a great idea, I'll follow suit. Where did you get the material? Or could any silicon be used? Would a process like this work? >> Cover the fuse root area with a clear wrap, then appling the silicon to the wing root, joining the two parts and allowing the material to cure. Then dis-assemble and trim the excess silicon. I don't think gluing a o-ring material on the root would work very well. In order for it not to cause a issue, it would have to be very small dia (like noted) and if the glue caused it to harden or get brittle, it would lose it's sealing ability. I'm assume you mean round o-ring material. In re-reading the post, maybe you meant flat material...???? Just some thoughts.
_____________________________
Do you know your UPS man's first name? If not, you don't have enough "stuff".
