jetlag
SC, USA Status: offline
Steven Clearly, mounting an OS.61FX inverted on a Seawind will ruin the top of the fuse from the fuel siphoning. I imagine the idea to mount it inverted came from trying to keep as much mass close to the centerline of the airplane for 'better handling'. I have built several Ace Seamasters, and their engines (all 2-strokes) were all mounted at 90 degrees. Those planes fly fabulously (for Seamasters). Those engines, however, are forward of the cg, if that matters much here. I have several YS 4-strokes mounted upside down and don't experience the fuel drippage, perhaps because of the supercharger/carb. design. I've not mounted an OS or other 4-stroke inverted, so I can't say if they would leak. If I were you, and I wanted to keep the .61 in the plan, I'd mount it sideways...only the muffler is grossly visible, but a pitts muffler might blow all kinds of stuff at the fuse! Exhaust oil should not (did not on mine) harm the finish...I use Omega 15% and 30% heli fuel (mainly for the YS's) with no Castor oil, only synthetic. As for the silicone solution at the wing tips, I fit an uncrinkled piece of Saran wrap completely over the wing root at the fuselage. Be sure to cut a slit for the spar and the used holes there, one each side for the sx wires and antirotation pins; make sure it's nice, smooth, and wrinkle-free...Take a wing and fairly liberally spread silicone on the root, run the wires through the fuse holes, and slide it down the spar up to the fuse...tighten the knurled knob down as if you are going flying...you want the sil. to squeeze out of the joint...wipe off excess...let dry for 24 hours. When you pull the wing back off, the saran will be sticking to the silicone...just gently peel it off. Wipe off gross exess with a rag...residual excess comes off easily once dry (or you could use a little lacquer thinner while the silicone is wet). Then Voila! The silcone stays with the wings and seals up next to the fuse nicely. Do the canopy similarly...that is, silicone on the canopy superstructure, Saran over the 'sealing foam' arond the opening on the fuse...attach as if your getting ready to fly it...leave it alone for 24 hours. As for auto wax as a protecta |
