Bob93447
CA, USA Status: offline
Gentlemen, In my humble opinion, the stress cracks and other problems with fin weakness are exactly why the Seawind should be flown as an electric. A good electric motor and esc weigh about 12 oz. Compare that to a good .61 with muffler, 20+ oz., engine mount, throttle servo and tank, 4+ oz., plus a full load of fuel, 14 oz. So on takeoff the electric has a good 1 1/2 lbs. less on the pylon and if you've balanced your prop, one heck of a lot less vibration. Yes, by the time you add batteries the all up weight is pretty much the same, but the batteries can be mounted to hull and act a bit like the lead in the keel of a sailboat, causing the plane to want to float level and to taxi without digging the tips in a badly. Just one way of overcoming the structural limitations of this beautilful airplane. Bob 93447
