RE: Canard Stick Plans
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Vintage & Antique RC >> RE: Canard Stick Plans Page: <<   < prev  1 [2]
Login
RE: Canard Stick Plans - 5/10/2007 7:44:46 AM
burtcs
Status: offline
Skitimberlake: Wish I could have been there. High Adventure...
Tom: Love the photo's, well done. Even the scalloped elevator looked good. Did your model require much lead in the nose?
I used to have, well I guess I still do since it's out in the barn (in one piece), a SIG Tri-Star. In truth the model flew well the two (count em) times I was able to get it off the ground with the engine running and was just right for me with an OS 15FP. Where it was terrible was in the ground handling and weight department.
The model bounced around like crazy on takeoff often resulting in a prop/ground strikes and it needed 6 oz. of lead in the nose just to balance. It would sometimes flip because of aileron/nose gear coupling and has grind marks on the canopy top. The fuse needs to be stretched about 6 inches (radio gear plus a nose wheel servo in front) and the landing gear needs to be heavier.
I liked this model though. Any thoughts on this bird? It looks pretty robust...
regards - Steve B.
(in reply to Love To build)
       Post #: 26
RE: Canard Stick Plans - 6/11/2007 9:11:39 PM
Skitimberlake
Status: offline
Skitimberlake here. Update on my Canard Stick. It is now in some pieces (but repairable with effort) as a result of an "experiment".
It flew pretty well stock (see previous posts), but I had trouble holding up nose in slower roll rate rolling circles. If my roll rate was fast at 1 per sec or thereabouts, I could manage them. RESULT - Big circle, lots and lots of faster rolls than I desired.
So I decided to put on a FRONT mounted "flying rudder". I mounted it directly on the nosewheel gear. I did the sum of aerodynamic moments about the plane's CG and sized the front flying rudder to be such that I had about twice as much fin area times distance from CG hanging behind the CG (those twin vertical fins) as I did front flying rudder area times its moment arm to the nosegear. Although I recognized that front rudder is inherently unstable (no proper restoring force for a yawing movement), I thought I had enough rear fin area in rear to compensate. (front rudder was about 20.6 sq inches)
Weeelll, shucks, it did not happen that way.
Plane took off fine, did one aileron turn to right fine, and on initial aileron left turn made downwind, it started to yaw right & roll and become unstable. (I believe the yaw to the right was initiated by its "normal" adverse yaw that was exhibited previously, which then became accentuated OOC by front flying rudder.) Max "rudder" movement had little effect to correct or restore stability. Plane wanted to sort of flat spin spin and couple a rolling moment in with the spin. I "saved" it twice, but the third recovery just did not happen. 'Twas an interesting 8 or 9 seconds or so after the problem manifested itself. Instant adrenaline rush. Hope I don't get poison ivy from retrieving the plane...
Well I mused all day and the eve about how my calculations were off. What I realized today was that in using Van Putte's approximations, fuselage side area was ignored. If I include fuselage side area as equiv to an effective vertical fin, I find that instead of the 20 sq in or so of front rudder that I used, I could only stand about 9 sq in for front rudder to achieve neutral stability (sum of moments = 0). Ooops !
So, I do plan to rebuiild and repair, and reinstall another front flying rudder, this one about 2/3 smaller (6 - 7 sq inches). Look for reports n the fall.
Suggestions anyone ?
Skitimberlake
(in reply to canard addict)
       Post #: 27
RE: Canard Stick Plans - 6/12/2007 4:26:57 AM
Bad_Daddy
Status: offline
Hanging in my garage is my mostly-finished, greatly modified version of an RCM plans model called the Sdrawkcab. It is a canarded Biplane, with a tractor prop just forward of the main wings and twin vertical rudders. The prop you see in the link was a dummy, hanging on the back of the fuse. I think all mine needs is fuselage covering and mounting the electronics and motor. I wonder if those plans are still here, or if I'll need to contact RCM for another set. But then the problem is that I changed the stagger of the main wings by 2 inches, rounded the fuselage, changed the "nose" considerably, removed that dummy tail, added more sweep to the canard, . . . . .
Ain't flying great?!?!?
_____________________________
Just remember, if it was easy, everyone would be a TopGun pilot.
bad0daddy
(in reply to Skitimberlake)
       Post #: 28
RE: Canard Stick Plans - 6/15/2007 7:58:31 PM
Bob Paris
Status: offline
Hay Tom,
That is very nice work...and I would love to see a picture of the finished model. I'm back home from Asia...and I pulled my kit out. Yep...I bought the kit years ago...and told myself...one day I just may build this one.
If I could work full time in my hoby shop...for 20 years...I would not run out of models to build. I wonder if anyone else is in the same boat as I am ?
I am willing to sell a full kit, in near perfect condition...I'm willing to sell it for $100.00 plus shipping from Hawaii. Send me a P.M.
Soft landings always,
Bobby of Maui
AMA 15016
(in reply to Tkeith9512)
       Post #: 29
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.813RCU3
