RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD Page: <<   < prev  1 [2]
Login
RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD - 9/24/2005 8:26:38 AM
Flyin4Funflyin
Status: offline
thanks yogi, if you need anything else, post it and well try and help
thanks loads
martin
(in reply to Max1)
       Post #: 26
RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD - 10/9/2005 3:18:53 PM
R Plante
Status: offline
saito 91 on 30% heli apc 15x6 at 9200 rpm
all up weight 7lbs 10 oz dry 8lbs 3 oz wet
cant help with weights as it s assembled but will check hobby shop next time
(in reply to Flyin4Funflyin)
       Post #: 27
RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD - 10/9/2005 9:10:34 PM
Max1
Status: offline
Thank you so much for your help R Plante..........have a great weekend.........Max1
(in reply to R Plante)
       Post #: 28
RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD - 10/20/2005 1:51:13 AM
Colyn
Status: offline
Sorry to hijack the post boy's but just ordered my harrier 90 I am going to build as light as poss...going with a os 91 fx and Hitec hs 5245 mg servos and a hs 85 micro for the throttle, this will save over 7 oz's over the std servos and saito 100 set up the os makws like 2.8 horse!!!!!!! the same as the saito 180!!!! do you guy's think that i will have to add weight to tail/nose to balance???? There is little point in saving weight like this and then having to add weight to balance. Got any idea's what was your set up like to balance did it come out without adding weight??? Thanks Colin.
(in reply to Max1)
       Post #: 29
RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD - 10/20/2005 2:48:04 AM
Max1
Status: offline
you need to go to the 3d flying section........there you will find the post who has a harrier 90 ? you will find the answers you are looking for.........hope this helps you.........maybe when you get your harrier 90 you can get the weights from :
wings
stabilizer+ elevator
fuselage (incl. RC and fuel)
as engine I have taken the 90 Saito 4 stroke ca. 600 gr
what kind of prop? diameter? pitch ?
your weight overall?
the more information we can help Yogi149 with the better the Seagull Harrier 3D .90 ARF for our AFPD will be........thanks Max1
(in reply to Colyn)
       Post #: 30
RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD - 10/20/2005 5:35:48 PM
Ian.W
Status: offline
quote:
ORIGINAL: Colyn
Ive flown an OS powered one, came over the quoted weight and was very under powered
_____________________________
Ian Watson
Team Flightpower
(in reply to Colyn)
       Post #: 31
RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD - 11/2/2005 8:55:05 PM
Flyin4Funflyin
Status: offline
hi Max
Hows it doing?
Martin
(in reply to Ian.W)
       Post #: 32
RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD - 11/2/2005 8:56:10 PM
Flyin4Funflyin
Status: offline
prop 17*6
       Post #: 33
RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD - 11/2/2005 9:29:14 PM
Max1
Status: offline
Hi Martin doing fine....just waiting for our Harrier 3D hehe.............i am sure it will be very nice....take care and have a great week to everyone....Max1
       Post #: 34
RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD - 11/14/2005 1:44:31 PM
Max1
Status: offline
Hi Yogi149.........hope everything is going great for you and that you had fun on your holiday.......just checking to see how the Seagull Harrier 3D .90 was doing..........we all know how busy you are and hope you are doing great..........take care Max1
(in reply to Yogi149)
       Post #: 35
RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD - 2/19/2006 1:18:16 AM
smartmove
Status: offline
Any progress on the Harrer 90 for AFPD?
My models (old and new) http://rcaeros.com/gallery
(in reply to Max1)
       Post #: 36
RE: NEED YOUR HELP-Seagull Harrier 3D .90 ARF for AFPD - 2/19/2006 2:28:24 AM
Max1
Status: offline
smartmove here is a picture that Yogi149 sent me jan. 2006 in a email he sent where he has started the Harrier..........I took the side pictures that Yogi149 needed and sent them to him........I know Yogi149 is very busy and that he will get it done as soon as he can for all of us.......so as soon as it comes it will be know in the sim section of the Harrier...........hope this helps.....have a great weekend.....Max1
Click to see fullsize image.
Click for fullsize
< Message edited by Max1 -- 2/19/2006 11:20:30 AM >
(in reply to smartmove)
       Post #: 37
Jump to:
