flycfii
IL, USA Status: offline
quote:
ORIGINAL: MJD quote:
ORIGINAL: flycfii I thought that was more for fuel economy and to avoid fouling plugs, and rich mixture was for power, throttle response and reliability on takeoff, landing etc. Then again, I did ground school 1-1/2 times but only have about three hours stick time full scale, and that goes back a while! So what do I know. Mike D. As far as it goes you are correct, but if you ever find yourself "high and hot", you'd better lean it out before takeoff. Lycoming actually recommends a lean-of-peak (!) when using turbine inlet temperature, but Usually I go by EGT and "feel". There's always one cylinder that will let you know when you're good.
_____________________________
#26 Club Saito RIP, W.R.
