JettPilot
Joined: 4/18/2005 From: Paradise, USA Status: offline
quote:
ORIGINAL: RC-FIEND quote:
What you have just said, is that in that state power DOES control altitude! agreed, I do it all the time , and it isn't easy but makes for the smoothest landings and all I am doing is copying the real airplanes, as we all know, they depend on thrust 100% for landings. Pitch controls your altitude. You can have all the power in the world, if you are pitched down you will only hit the ground faster. You obviously need power to climb, but more importantly you need to pitch UP to climb first, and if there is enough energy the plane will climb. A plane will NEVER climb pitched down, power or not. Pitch controls altitude. (given there is enough airspeed and you dont stall.. Duhhh..) Airliners fly in cruise and also do automatic approaches by using Autothrottles to control the speed, and by using the autopilot to control pitch and roll to keep the airplane on glidepath. Boeing, Airbus, and McDonald Douglas all use thrust to control speed on thier airplanes, and pitch to control the altitude, what a novel idea I guess all the aerospace manfacutrers of the world got it all wrong and should be looking at redisigning their autoflight systems, because according to Garp and RC-FIEND they got it all backwards
< Message edited by JettPilot -- 9/7/2005 2:00:48 AM >
_____________________________
THE TRUTH ABOVE ALL ELSE...
