Ed Cregger
GA, USA Status: offline
The really good thing about the Magnum .91 four-stroke engine, or any Magnum engine for that matter, is the excellent warranty service they present, should you need it. I am very satisfied with my Magnum engines, having owned, operated and flown them for nearly a decade now, IIRC. They take a little while longer to break-in, on the average, but it is nothing really protracted or prolonged. Just be prepared to run them on the bench, or in your model elevated up on a card or picnic table for four or five tanks of fuel, or less. Also use fuel with at least some castor oil in it, even if you have to add four ounces yourself. After the engine settles in a bit, you will have an engine that runs and handles very similarly to the original OS version from which it was cloned. Ed Cregger
_____________________________
Artisan "Flying models since the Fifties - I'll get the hang of this yet!!!"
