Bodge
Joined: 2/14/2004 From: Northampton, UNITED KINGDOM Status: offline
Chevy, That's the advantage of the 61 - it's fairly light. Once you start to go larger, with ASP/Magnum at least, you immediately jump up to 91 weight. With the 65, 70 and 80 weighing within 10 grams of the 91, you might as well use the 91 for everything... If I remember correctly, I belive the 61 was pulling a 13 x 4 at 9,800 rpm on 5% fuel. Performance wise it is very similar to the 46 two strokes - and weighs about the same. It's a much nicer engine to fly with than the 46 and responds well to the throttle in a hover. I don't think it will have the performance of an OS 50, though. Certainly my ASP 52 2 stroke would leave it standing.
_____________________________
Mick
