Mustang Fever
MI, USA Status: offline
I have had two Magnum .15s, a 91RFS and a 91 XLS. The only problem child was the 91 XLS. It was way tight out of the box, to the point where the starter would not turn it over sometimes. I sent it back with complaints, and they said it was ok and sent it back to me. It lasted a little while, and then the con rod separated from the piston or crank, whatever, the piston didn't go up and down when the crank was turned. I sent it back for warranty and got a new one, and it's a sweetheart. I added 6 oz extra castor oil to some Wildcat 15% for break in, and am still using it for flight. I have it in a Hangar 9 Sopwith Camel turning a 15x5 prop, which is way to much for that airplane, but it flies loverly at half throttle and all day on a 12oz tank. I did drill and tap the various muffler pieces so I could bolt it all together with small 4-40 screws, as it kept coming apart. The 91RFS is in a GP Triplane, and it's a great running engine on 30% heli and a Perry shaker pump. (The tank is so big in the Fokker that it wouldn't draw fuel at idle. If I had it to do over again I'd put a 10 or 12 oz tank in there.) The 15s were used on small Mustangs and Sig Wonders and always ran great. I would never buy another one, though, due to the front mounted needle. Something about getting hit in the face with pieces of my fingers bothers me. The OS 15CVA is the best 15 on the market, anyway, and has a rear needle. I have a Hobbico Nexstar on order for a club trainer, and a Magnum 46 XLS for it. I'm building a Laddie Mikulasko Arrow, and it will have a Magnum 46.
_____________________________
Bob Hunt
