yallaair
quote:
quote: ORIGINAL: davidbegg Hi, thank you for your suggestion. The engine is well run in, using the correct techniques (i.e.not 4 stroking , stopping let it cool, running at full speed and so on) The engine has had in excess of 8 litres of fuel through it(over 2 of your gallons) so it must be well and truly run in. The engine was actually more reliable while it was being run in, the more use it had the more unreliable it became. I have sent the engine to Asmund in Norway which is about as far from NZ as you can get, but he reckons he has never had a failure in getting an engine to run correctly yet. I engine to me in it previous condition was just junk so I have my fingers crossed he is successful. Thank you again for your suggestions. Cheers David I have had a small overhaul of the engine now and it runs great on the ground. It tachs 14200 rpm on MAS 9-8, which is about as good as it gets on this one. This is the old series with round sylinder housing, not the newer more powerful XLS series with the square shape. Testflying will follow as soon as the weather allows. I will try to post a video of it running as soon as I get around to do it ( I need some help from a friend because I am completely disabled when it comes to posting pictures and videos) Hi Here is a vid of the "problem-engine". As far a I can see, there is no issues with this engine. It's not powerhouse, but it runs fine. It runs on a local brand 15/15 synth oil mix. http://www.youtube.com/watch?v=mf4gZEYnM9Q
_____________________________
Darn the ground..... and the jumping trees
