RE: Can you start a heli's blades mid-air?
Tower Hobbies
Logged in as Guest
  Printable Version
JR Venture w/webra.32and DX7 RTF
Seller:  lawnmower man
Details:   $425.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Full Scale planes, cars, helis, boats >> Helicopters - Full Scale >> RE: Can you start a heli's blades mid-air?
Page: <<   < prev  1 [2]
Login
RE: Can you start a heli's blades mid-air? - 9/1/2007 4:24:08 AM
r/cheliman
Status: offline
THis Situation of a Heli spinning up from dead stop in mid air is truely possible provided a few things. The helicopter would have to have slide out of the plane backward while the plane is moving at a high speed. As a principle of physics the heli would be moving forward at the same rate of speed as the plane due to it is inside of it. When the heli exits the plane the air passing by the rotr blades would cuase them to begin spinning before the heli reached terminal velocity. In fact the motor wouldn't even have to be running to make a successful landing due to The principle of autorotation ( the blades being spun by the passing air would cause them to create lift given that the heli was facing farward when it fell out). This principle is used when the turbine on a helicoprter fails. It can be used in all situations as long as the helicoper is at least 100ft up and has forward momentum. Know could James Bond pull this off, when even experienced pilots have trouble doing it, thats a different story all together.
(in reply to Hooker50)
       Post #: 26
RE: Can you start a heli's blades mid-air? - 7/21/2008 10:10:04 AM
jimmy 1987
Status: offline
I dont think it is possible.... but wat i do know is a mate of mine was doin helicopter lessons and one thing they need to practise is flying and cutting the engine in mid flight..... so i must be possible once ur moving and been flying but not when u just drop out of the sky.
(in reply to r/cheliman)
       Post #: 27
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
